2013+ Focus ST FRPP Tune info - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 02-25-2014, 12:32 AM   #31
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,038, Level 66
Points: 10,038, Level: 66 Points: 10,038, Level: 66 Points: 10,038, Level: 66
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 24%
Originally Posted by HopnDude View Post
Then why would Ford or a Ford/Lincoln authorized dealer state that they would need to do the install to keep the warranty?! Why not any ASE Joe down the street?!
v You might want to re-read what I typed. v
I never said anything about swapping it back to the factory hardware for service work. My woman would not allow me to do shady stuff of that nature, and I'm not looking to get into any legal trouble.
Another question for you, since you seem so enthused and knowledgeable about this warranty information over a dealership. Why would Ford still do the 3 year 36K mile warranty (being the most crucial) and nothing beyond that?! If you own one (Focus ST) and purchased yours brand new (like I did) then you know what all is covered under the 3 different sections. 3 year / 5 year / 7 year. Why would they void everything after the 3 years?! If it's going to handle for the 3 years, then why would it not take it after that?! They will KNOW if you modify anything else; ECM logs, tool marks from changing parts, etc. They will know if you're hiding something.
I will probably do one thing that the dealer will NOT like. I'm putting a oil catch can on it. Not cutting that factory hose (it'll sit pretty in the glove box - not that it makes a difference) as I'll get all new hose and make a pretty little mounting bracket and place it somewhere I can drain it at easily and often. If they can find some reason that a oil catch can might ruin my vehicle, then by all means I'd like them to show me.
You'd have to swap the intercooler back to stock in order to install the stock grille shutter system as all of the available kits require the removal of said system.
You have to have it installed by the Ford dealership to properly activate the FRPP warranty in Oasis and initiate the transfer of the powertrain warranty from Ford to Ford Racing.
It can't be installed by joe blow and keep any warranty coverage intact as it would be the same as any other aftermarket performance modification which has the risk of damaging the power train as far as Ford is concerned. Especially if it wasn't installed and registered by a Ford Dealership.
The specific coverage provided by Ford Racing is quite limited in comparison to the power train and bumper to bumper warranty.
Look I'm not telling you not to buy it but if you read the specifics and have any actual mechanical issue with the power train after the initial period of time you may be in for a fight as your Ford dealer will likely put the blame on the tune, and FRPP will say they are not responsible at that point. You will likely never need the protection of the warranty, but if you do value the complete 5 year/60 k mile power train coverage or any extended service plan you'd be better off not modifying the car in this manner.
I don't get why you're so insistent that your dealer knows best when clearly they pointed to the exact same legal document which states the low limits of coverage under the FRPP warranty.
Ford Racing total aggregated liability per qualified vehicle under this LimitedWarranty is $8,000: Each covered component has its own aggregate value, which when combined shall not exceed $8,000 in total parts repairs, except in the Province of Quebec, where the cost of parts and labor are covered. The maximum liability for failed parts by component category under this Limited Warranty is as follows: engine assembly parts $5,000, transmission assembly $1,500, and rear axle assembly $1,500. Under this Limited Warranty, Ford Racing retains the right to replace any failed components with remanufactured parts for the life of the warranty.
I'm not even the first to point this out, but I guess you and your lawyer girlfriend know better than Ford's lawyers.
http://www.mustangevolution.com/foru...4/#post1685066 Others have mentioned this also.
http://mustangforums.com/forum/5-0l-...-warranty.html
http://www.svtperformance.com/forums...-warranty.html
This is the exact reason, why I decided not to go with the Track Key activation.
Ford does make you sign an agreement, for the change in Warranty.
NO Track Key = Ford Powertrain Warranty - 5 Year or 60k Miles
Track Key Active = Ford Racing Powertrain Warranty - 3 year or 36K Miles.
Just to keep playing devil's advocate, I think the fact that you even get any warranty coverage at all from Ford or Ford Racing for their power packs says a lot about how much they stand behind their work, but at the same time I cannot justify throwing away the 7/100k premium care ESP for the thrill of 90 lb-ft more torque and up to 40 more hp under the curve as it would be quite probable that Ford would deny a warranty claim for a failed engine due to the aftermarket tune as it can be demonstrated that it was the cause of the problem, or at least strongly suggested.
suss6052 is online now
Old 09-30-2014, 03:26 PM   #32
HopnDude
HopnDude's Avatar
Fan#: 144409
What I Drive: 2013 Tuxedo Black Focus ST
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 HopnDude Good Standing Member
Let me get out my shovel here......
Any way, so I finally got to see a dyno with the FRPP tune, not to mention someone posted one a few pages back (on this thread).
The one I seen was on 92 oct, ProCal/Plugs/Snorkel/Filter and was 248whp and 254wtq on a Mustang Dyno. So very close on the numbers with both!
As for warranty information, it has been changed along with Mountune parts now on the list.
HopnDude is offline
Old 09-30-2014, 08:23 PM   #33
okaythen
Fan#: 120373
What I Drive: 2014 Focus ST3 Tuxedo Black
Points 237, Level 4
Points: 237, Level: 4 Points: 237, Level: 4 Points: 237, Level: 4
Level Up 74% Completed
FF Reputation: 1 okaythen Good Standing Member
254tq? I think it's more than 350 tq.
what do you mean warranty info have been changed?
okaythen is offline
Old 09-30-2014, 09:31 PM   #34
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
It hasn't really changed (the terms and conditions are the same), but now that Mountune USA has come to an agreement with Ford Racing if you have Mountune parts installed by Mountune and registered with Ford Racing, or installed from your Ford Dealer the FRPP warranty is in effect for the MP275 kit components (intercooler, intake, and calibration), but not the downpipe or MR300 calibration.
Old 09-30-2014, 11:08 PM   #35
HopnDude
HopnDude's Avatar
Fan#: 144409
Points 51, Level 1
Sorry about that!
248whp / 354wtq
Didn't notice that.
HopnDude is offline
Old 10-20-2014, 11:01 PM   #36
TCOC rel1
TCOC rel1's Avatar
Fan#: 105626
What I Drive: 2014 ST Ticket Red
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 0 TCOC rel1 Newbie
So the FRPP M-14204-FST calibration and colder plugs will not void the warranty?
*snorkel delete, K&N E-2993, 1 1/4" New Mission Mod* ~2.5" Custom exhaust 12226 MagnaFlow muffler~ ^AMSOIL^ #93 Octane# ^Injected Engineering tune^
@2nd car 10th Gen Ford Lightning 445 HP@
TCOC rel1 is offline
Old 10-21-2014, 01:57 AM   #37
HopnDude
HopnDude's Avatar
Fan#: 144409
Points 51, Level 1
IF!......IF you have a certified/authorized dealer install it, no it will not void the warranty.
HopnDude is offline
Old 12-23-2014, 08:59 PM   #38
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,253, Level 77
Points: 14,253, Level: 77 Points: 14,253, Level: 77 Points: 14,253, Level: 77
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 15 Elizabeth Great Standing Member
OK so far it reads like the warranty will (partially) be in effect. However the $$ comes for Ford Racing as the warrantee payer. With the money limits mentioned, and only for 36mo 36,000 miles, Regardless of the more complete stock Ford warranty on engine components. (and totally OFF the radar of the extended Ford warranty one can buy)
So yes there is 'some' warranty with the Ford Racing. However it is not the same as the actual Ford standard warranty. And definitely is not covering any purchased extended warranty, or powertrain extended warranty found from Ford.
Any disagreement?
If it WAS the actual warranty, and covered buying the extended warranty in full i would get the Ford Racing Tune. However it clearly is not covering anything beyond 36/36. (even though the standard warranty does..or would have except you destroyed the standard warranty with your racing parts.)
IE after 36/36 you are SOL on any warranty related to having the tune: the motor, the tranny.. Big bucks right there.
Elizabeth is offline
Old 12-25-2014, 11:24 PM   #39
okaythen
Fan#: 120373
Points 237, Level 4
so after the tune the original warranty will be gone? so after 3/36 you are totally on your own right?
but so far does anyone have problems with the tune and went to dealer to get repair yet?
okaythen is offline
