When hot, car runs rough... stalls. Poor gas milage - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2013, 11:32 PM   #1
bssop
Fan#: 18345
What I Drive: 2003 Green ZTS
FF Reputation: 1 bssop Good Standing Member
Here is my issue.
2003 ZTS 177,000 miles :)
Recent replaced parts:
New plugs/wires
Fuel Filter
IAC
New downstream O2 sensor * (Today)
Some non related (windows/ window regulators/ switch) but my cash flow is low as a result.
Needs a new timing belt.
So... I've had this issue for years, only during hot weather months but I have to have it fix since I drive long distance for work along with college now. But, it wasn't doing this during the hottest months of the year, unlike it normally does.
Car runs fine for about 25 miles, then a lose of power for the next 20 miles... If you try to pass on the interstate, good luck! Then at 50 miles comes the fun part... When going up a hill, it will try to down shift and when it does, it will SLAM... HARD!!! Next hill, it wont shift, 3 miles later... stalls and fails to shift (in lower gears). Wait 5 minutes, I can start it and go a couple miles and make my destination.
When the temperature cools (along with the car), It will run but the hard down shifting happens.
Codes????
Yep... P0420
So I did the cheep thing first and replaced the O2 and the code hasn't came back (after 80 miles) BUT the car ran like crap for 30 miles and the same on the way home. Feels like it "jolts" when you have the cruise on and get above 60 mph. Still shifts hard.
Oh and my gas milage stinks... I get 200 miles on a tank!!! Mostly Highway.
So... I was leaning bad cat but the hard shifting is throwing me off. Is there anything else I should look at first?
Thanks!
bssop is offline
Old 09-19-2013, 11:34 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,642, Level 94
Points: 23,642, Level: 94 Points: 23,642, Level: 94 Points: 23,642, Level: 94
Level Up 30% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
how old is the fuel filter?
mikebontoft is offline
Old 09-19-2013, 11:41 PM   #3
bssop
Fan#: 18345
Newish (less then 5,000 miles)... forgot to add that.
(Will edit it now)
bssop is offline
Old 09-19-2013, 11:55 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,678, Level 86
Points: 18,678, Level: 86 Points: 18,678, Level: 86 Points: 18,678, Level: 86
Level Up 66% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
Well based on the assumed MPG you're getting, which I'm figuring at 20MPG, you should be throwing another P0420 shortly.
The threshold is ~25%. If I assume you should be averaging 28MPG; take 20/28 = ~28% rich.
And if this is with a new O2 sensor that isn't currently throwing a code, and may not ever. I have to ask what brand you went with?
The other input for fueling would be the Mass Air Flow Sensor. Getting dirty gradually could throw the fueling off yet the computer wouldn't pop a code because it's reading what it thinks is correct.
So I'd say also clean the MAFS with some maf cleaner spray.
Then it's maintenance stuffs. Plugs, wires, PCV, oil change, check tire pressure, trans flush/filter, etc.
iminhell is offline
Old 09-20-2013, 01:10 AM   #5
bssop
Fan#: 18345
It was a Bosch.
bssop is offline
Old 09-20-2013, 07:15 AM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
Swap it with NTK.
iminhell is offline
Old 09-20-2013, 11:42 AM   #7
bssop
Fan#: 18345
New problem!!
Shortly after starting this morning. Drove a tenth of a mile to the first stop sign.
Hard to break (goes to floor)
RPM's are at 3000
Did this once a week ago, same situation, cold start... early stop.
bssop is offline
Old 09-20-2013, 11:05 PM   #8
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,023, Level 74
Points: 13,023, Level: 74 Points: 13,023, Level: 74 Points: 13,023, Level: 74
Level Up 44% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 09-20-2013, 11:11 PM   #9
greygoose8732
greygoose8732's Avatar
Fan#: 65707
What I Drive: 01' Liquid Grey S2, 03' Black SVT
FF Reputation: 1 greygoose8732 Good Standing Member
Clogged cat? PCV hose collapsing? I would start buy checking that PCV hose it plugs into the back of the air intake. It will collapse at the bend coming off the intake.
greygoose8732 is offline
Old 09-22-2013, 12:05 PM   #10
bssop
Fan#: 18345
PVC hose looks good... I always check it first since it was one of the very first issues I had to fix with my car :)
Still no CEL since the O2 sensor change, car still runs rough. Doing routine fluid changes (oil and trans) today.
bssop is offline
