Rear break adjustments - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2013, 03:42 PM   #1
Sammy
Fan#: 63608
What I Drive: 2001 Red Focus SE
FF Reputation: 1 Sammy Good Standing Member
Hello
I am changing the wheel break cylinders on my wife's 2001 Focus Street. I will bleed all four corners afterwards. I do have few questions:
1) Do the rear breaks have to be adjusted or are they the self-adjusting type? If adjustments are needed, can it be done with drums installed?
2) Besides the few spots where the shoes touch the plate, what else needs to be lubricated?
3) Do I need to do anything special with the parking brake/cable?
Thank you
Sammy is offline
Old 09-19-2013, 04:56 PM   #2
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,060, Level 34
Points: 3,060, Level: 34 Points: 3,060, Level: 34 Points: 3,060, Level: 34
Level Up 7% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
They self adjust, just collapse them before putting the drums on.
Where the shoes touch the wheel cylinders, and the bottom pivot.
Take the adjusters apart, clean them and a bit of grease where the parts slide.
Ed
emsvitil is offline
Old 09-28-2013, 03:43 AM   #3
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
I would NEVER grease the adjuster on these, it attracts dirt instantly and only a little makes them stop working. Not that they work much anyway after the initial set with new parts. You want those small teeth to stay clean as long as they can. BONE DRY is best.
You do not do any backing up, or anything else to self adjust them, simply press brake pedal down once or twice working brake and it's done.
If brake squeaks at slow roll then pull shoes off and grind the right angle of the brake shoe ends to a 45 degree or less and the noise will stop. Don't even need to do all four ends, only the top of front shoe and bottom of the back shoe. These cars are well known for rear squeak that can drive you crazy.
amc49 is offline
