2004 focus...blower fan not working? - Page 2 - Focus Fanatics
Old 09-23-2013, 09:49 PM   #11
sekss
Fan#: 119059
What I Drive: Car
FF Reputation: 1 sekss Good Standing Member
Originally Posted by FocusKnot View Post
I wish the OP would answer the question about whether or not the fan runs in position 4. That would help us narrow down the problem for him.
totally forgot about this thread.
I don't remember if the fan only runs when in position 4. I dont' think I went that far in troubleshooting it.
I ended up getting an aftermarket resistor from a car parts place even though the fan did work again in all speeds. look at a few youtube videos on replacing the resistor.
So far so good...been a few days..
sekss is offline
Old 09-27-2013, 06:28 AM   #12
sekss
Fan#: 119059
What I Drive: Car
well this sux.
blower stopped working yesterday, doesn't matter if the switch is at 1 2 3 or 4. I pound on the glove box compartment with my fist and it started working again.
So it's not the resistor since I replaced that.
Replace the blower??????
sekss is offline
Old 09-27-2013, 08:36 AM   #13
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
When I pulled mine and cleaned it, I noticed that the space between the contacts on the armature were filled with carbon from the brushes. You may be able to clean those out with a nylon brush (toothe brush) and restore function.
spiller is offline
Old 09-27-2013, 09:20 AM   #14
FocusKnot
Fan#: 117505
What I Drive: 2004 Red SE Wagon 2.0 Zetec Auto
FF Reputation: 1 FocusKnot Good Standing Member
Because it doesn't work in position 4, it is not the resistor block (but you have already replaced that anyway).
Since pounding on the glove box seems to make it work sometimes, you have an intermittent connection somewhere. Try pounding on the switch and then the blower motor directly (not the glove box). I suspect it is the brushes in the blower motor.
If the motor brushes are worn out, they can be replaced (check spiller's suggestion too). You can also oil the bearings while you have it apart.
FocusKnot is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
