Can an overfilled transmission cause ring and pinion problems and noise? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-26-2013, 10:00 PM   #11
amc49
Fan#: 96610
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
High chance it's bearing again, even more so if you just recently did it. If you did not buy the higher priced bearing even more so. The cheaper ones often don't even have grease in them. I've run across one that had none, it made slight noise that got worse from the first day I used it. After couple months I pulled it and bearing was bone dry, it had never had grease at all. The seals were still sealing and in perfect shape. Only thing that let it run that long was the parts were wetted with assembly oil.
If you do not buy the best wheel bearing you can get you are screwing up, and lifetime warranty on the crap part just means to you that you get to do it over for a lifetime.
amc49 is online now
Old 09-27-2013, 03:35 AM   #12
kaptinkool
Fan#: 117384
What I Drive: 2004 light green Ford Focus ZX5
FF Reputation: 1 kaptinkool Good Standing Member
Would a bad differential make noise in neutral?
kaptinkool is offline
Old 09-27-2013, 08:11 AM   #13
amc49
Fan#: 96610
Forum Activity 49%
Question already answered, if you start the posts you should at least read them. Not endearing yourself here at all.
amc49 is online now
Old 09-27-2013, 09:17 AM   #14
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
A wheel bearing is cheap, just get it replaced and see what happens. If it were me though, if I do one bearing, I'd do the pair while I'm at it.
FoMoCus is offline
