Small ball bearings fell out of knuckle? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-17-2013, 01:15 PM   #1
tiajuana999
Fan#: 119011
What I Drive: 2003 Ford Focus ZTS
FF Reputation: 1 tiajuana999 Good Standing Member
I just recently changed my CV joint drivers side, and as I pulled the hub outta the knuckle, ball bearings slightly smaller than a dime came falling out, and the plastic housing for these bearings was shot to shit. Does anyone know what this bearing is called and where can I get it..I temporarily put them back in with grease to keep them in place...car is fine for now, but I'm worried! Thanks
tiajuana999 is offline
Old 09-17-2013, 02:38 PM   #2
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,445, Level 65
Points: 9,445, Level: 65 Points: 9,445, Level: 65 Points: 9,445, Level: 65
Level Up 32% Completed
Forum Activity 8%
those would be wheel bearings and should definitely be replaced immediately.
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is offline
Old 09-17-2013, 11:56 PM   #3
tiajuana999
Fan#: 119011
Thanks for the reply...I do know what wheel bearings are, and they are sealed in a metal housing like any other modern bearing....these are literally ball bearings sitting open so you can touch them and roll your fingers over them but in a plastic (0)(0)(0)(0) housing. Every time I search wheel bearings it shows the modern type we all know so well. There is even a groove cut into the hub so these balls can rotate around the hub.
Old 09-18-2013, 11:43 AM   #4
reamkeeper
reamkeeper's Avatar
Fan#: 15415
What I Drive: 2013 Fiat 500 Sport Cattiva
FF Reputation: 4 reamkeeper Good Standing Member
Sounds like the wheel bearing to me, the outter seal may be gone, hence you can see the actual bearings. I suggest either posting pictures here or bring it to a mechanic, but I wouldn't be driving it.
KKCO
reamkeeper is offline
Old 09-18-2013, 12:01 PM   #5
tiajuana999
Fan#: 119011
That actually sounds possible..especially if the seal was plastic or something cheap that could have disintegrated and fell out while I was driving. Because if it was a bearing like the hub bearing with the steel casing..I would've found that casing still inside the knuckle. Thanks
Old 09-28-2013, 03:49 AM   #6
amc49
Fan#: 96610
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
There is no groove cut in hub so yours is damaged...........................you're talking wheel bearing there and there better have been a steel casing, none built without it.
Wheel and hub bearing are the same thing.
amc49 is offline
Old 09-28-2013, 10:14 AM   #7
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,750, Level 76
Points: 13,750, Level: 76 Points: 13,750, Level: 76 Points: 13,750, Level: 76
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Pull the spindle off & press out the old wheel/ hub bearings & press in a new one.
felixthecat is offline
Old 09-28-2013, 11:21 AM   #8
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,702, Level 94
Points: 23,702, Level: 94 Points: 23,702, Level: 94 Points: 23,702, Level: 94
Level Up 36% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
when you pull the hub flange out, part of the bearing race stays on it which exposes the bearings. I just did one on a Honda last night where someone had cross threaded a lugnut and it snapped off when I tried to remove it. Unfortunately I didn't have enough room to push out the stud so I had to remove the hub. none of the balls fell out and it went back together nice and tight, but I know exactly what you mean.
I do have to ask why the hub was removed to replace the axle?
mikebontoft is online now
