Resolving A Slight Engine Misfire? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-17-2013, 11:16 AM   #1
tdfuller
Fan#: 62403
What I Drive: 2002 Grey Ford Focus SE
Points 655, Level 13
Points: 655, Level: 13 Points: 655, Level: 13 Points: 655, Level: 13
Level Up 10% Completed
FF Reputation: 1 tdfuller Good Standing Member
2002 Ford Focus SE - Zetec 16 Valve DOHC - 89,500 miles:
For the last five days: has had an occassional engine misfire during accelerations and sometimes during idle.
What are some of the usual culprits?
I don't see anything under FAQ/Archives, here are some details:
  • I replaced the plugs and plug wires with Motorcraft yesterday (first time) which greatly reduced the frequency and severity of the misfires but has not eliminated it.
  • Two weeks ago I replaced the fuel filter with a Motorcraft
  • Two weeks ago I changed transmission fluid, filter, and filter gasket
  • Two weeks ago I thoroughly washed the car, including the engine compartment, being careful not to spray the air filter housing, fuse box, and battery. The manual doesn't say to cover the spark plug covers. I found some water dribbling out of at least one of the old spark plug covers when I removed it from the top of the plug!
  • The old plugs definitely had some moisture, some gunk, and quite a bit of corrosion that was likely contributing to the misfire.
I filled up the Focus with a full tank of gas five days ago, just before the misfires started at a different gas station than I usually go to -> Is it possible in 2013 to still get "bad" gas that can cause misfires?
Should I go ahead and replace the ignition coil?
Thanks for any tips.
tdfuller is offline
Old 09-17-2013, 11:51 AM   #2
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
my SPI was misfiring bad for awhile, like, couldn't accelerate at all due to it. I had replaced the plugs and that fixed it greatly, but the ultimate culprit ended up being the coil pack. check for cracks on it, etc, and you will know. don't do what I did and take it in, it's a super easy fix, and cheap if you can find a used one in a scrap yard/ebay. literally unscrew it and unplug a few things, and reverse to put it back in. this should help, and if not, the problems will be worse, but atleast youll know
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 09-17-2013, 01:47 PM   #3
tdfuller
Fan#: 62403
Thanks. I have had no warning or no check engine light. But, I'll have my eye on the ignition coil pack. I may wait until I burn through my current tank of gas though, to make sure "bad" gas was not a contributing factor. The 3-wire pigtail connector coming out of the ignition coil pack will be checked. It looks ok, but I am going to wiggle it while the engine is running to see if that might be an issue as well.
tdfuller is offline
Old 09-17-2013, 02:32 PM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
Moved to General Technical Chat.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 09-17-2013, 02:51 PM   #5
tdfuller
Fan#: 62403
Thanks for the move to technical.
tdfuller is offline
Old 09-17-2013, 07:44 PM   #6
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
Forum Activity 14%
FF Reputation: 1 Leora83 Good Standing Member
My bet is on the coil, too. 4 T25 bolts, a wiring harness, and 4 leads, and you're done.
If you're lucky, none of the bolts are seized, or were stripped by some hamfisted fool trying to change it earlier.
Leora83 is offline
Old 09-17-2013, 09:11 PM   #7
tdfuller
Fan#: 62403
I've had the Focus since new. So, the coil assy should be factory installed.
I am going to wait to burn through my tank of gas, in the unlikely possibility that "bad" things in the gas were contributing to misfire since the time of last full refill seemed to coincide with misfires.
Also, I resolved a non-working trunk bulb today. It was traced to a wire break at the bend in the left side of the trunk grounding the circuit. Since those wires were repaired, it seems like the misfires are almost completely gone and when they do occur are very slight.
I'll post more developments when they occur.
Thanks for the tips.
tdfuller is offline
Old 09-17-2013, 11:33 PM   #8
calebstubstad
Chef Boyardee
Fan#: 103240
highly doubt anything with the trunk lighting would have much to do with the engine ignition, but who knows. Maybe just a lucky coincidence, mine went away for awhile after I gave her some WOT therapy
[HOONIGAN]
Old 09-27-2013, 06:03 PM   #9
tdfuller
Fan#: 62403
PROBLEM SOLVED!
Got the coil assy and replaced it. All misfires are gone and the Focus is running as well today as it did new 11 years ago.
... By the way, when the part was en route, I ran to Advance Auto and used their OBD code detector. It said "misfire cylinder 2." Since I had already replaced the plugs and wires, I presume that was the ignition coil for cylinder 2 and I guess the code machine will not say, "you have a bad coil assembly."
When I took the old coil pack assy out, and flipped it over, there was a hairline crack extending along the side of the base with the same side as the plug for cylinder 2. Not sure if that had anything to do with the old one failing.
tdfuller is offline
Old 09-28-2013, 01:23 AM   #10
Leora83
Fan#: 69136
Forum Activity 14%
Yes, it did.
You'll get random misfire codes, then eventually Ignition Coil Module A (or B, C, D, E). So it will tell you, eventually.
Make sure to check that wiring harness, especially the middle wire, for problems...otherwise your expensive new coil might start throwing codes within a week or two and you might think it's defective.
Leora83 is offline
