Passenger Door Mirror - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-14-2013, 08:08 PM   #1
Cruise
Cruise's Avatar
Fan#: 100721
What I Drive: 2008 Vermillion ClearCoat, SE
Points 376, Level 7
Points: 376, Level: 7 Points: 376, Level: 7 Points: 376, Level: 7
Level Up 52% Completed
FF Reputation: 1 Cruise Good Standing Member
After a little incident I had backing into my garage my passenger door mirror was slightly damaged. The mirror and the motor that moves it is undamaged, but the housing is a bit wopperJod.
As you may be able to see in the above image there is a gap between the housing and the car. What I want to know is: does anyone know how to get the black piece of trim off so that I may check to see if any connections to the mirror are broken, and any ideas you may have to get the housing to adhere to the car and at least look undamaged cosmetically.
Thanks
Cruise is offline
Old 09-17-2013, 08:37 AM   #2
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
for the interior black triangular trim piece just grip and rip. you will see a couple of nuts and your pig tail. now the connector for the pig tail might be a little lower behind the door panel i cannot remember. most likely the studs/bolts were pulled from the plastic mirror base. you may be able to press/glue them back in. its worth a shot
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
