new zetec turbo kit - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-07-2013, 12:05 AM   #21
SVT54
Fan#: 119231
What I Drive: 2003 Black EAP SVT Focus
Points 47, Level 1
Points: 47, Level: 1 Points: 47, Level: 1 Points: 47, Level: 1
Level Up 94% Completed
FF Reputation: 1 SVT54 Good Standing Member
Originally Posted by Turbo Turtle View Post
only thing not picture i believe is the dump tube. not finished with that yet but it will be simply dumping straight down next to the downpipe
Have you fitted one with a dump yet? Just curious if the dump tube will interfere with the O2 and WB?
SVT54 is offline
Old 10-07-2013, 11:27 AM   #22
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: Miata, STi, GSXR1k
Points 20,705, Level 90
Points: 20,705, Level: 90 Points: 20,705, Level: 90 Points: 20,705, Level: 90
Level Up 72% Completed
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
it will not interfere. i plan to do the dump tube this week. i have been busy putting a clutch in the miata last week. if it is not able to go straight down as pictured i will put a bend in to move the dump tube away from the o2's. that will be no big deal.
Tim
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 10-07-2013, 12:23 PM   #23
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
he changed it b/c he had aftermarket hid lights of some kind and had stuff mounted where my pipe goes through
I have that same problem with my topspeed piping. the mach headlights back cover doesn't fit.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 10-07-2013, 01:04 PM   #24
Turbo Turtle
Fins Up!
Fan#: 32772
if i had some of the headlights i would try to build the piping to clear them. same for the foglights. but with out having them i cant guess to make it clear every possible combination of parts
Turbo Turtle Garage
Old 10-07-2013, 02:48 PM   #25
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,433, Level 100
Points: 50,433, Level: 100 Points: 50,433, Level: 100 Points: 50,433, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
You've done good so far Tim
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 10-25-2013, 12:28 PM   #26
Funkymonk
Funkymonk's Avatar
Fan#: 120157
What I Drive: 2001 White ZTS
FF Reputation: 1 Funkymonk Good Standing Member
Sorry for the noobish questions, I'm trying to get a turbo on my car and I'm trying to find the best (and hopefully cheapest kit) I can find.
Would this kit affect the exterior of the car in any way? (besides being able to see the intercooler through the front bumper.)
Would I need to move the car battery to the back or will it be possible to reinstall it in the front afterwards.
And lastly, What other parts would I need to complete my turbo set-up (boost controller? Boost timer? gauges?)
Thanks
Funkymonk is offline
Old 10-25-2013, 01:08 PM   #27
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
You won't need to move the battery just cut a joke on inner fender wall
FF MODERATOR
RIFF CREW
Old 10-25-2013, 02:05 PM   #28
Turbo Turtle
Fins Up!
Fan#: 32772
weather or not you have to move the battery with my kit will depend on the type of air filter you run on the turbo. the cold side charge piping will clear the batter. it requires you to cut a small section of the inner fender behind the headlight. it can not be seen once the pipe is installed and if cut cleanly wouldnt be noticed if the kit was removed later.
the intercooler is the only thing you will be able to see from outside the car. i may be able to get the intercooler in black if your looking to hide it
this kit is not a complete kit it simply comes with the parts the have be fabricated to install a turbo such as manifold, downpipe, wastegate pipe, intercooler piping, intercooler, couplers, oil lines, oil pan, maf housing. it would require you to get a turbo, wastegate, blow off valve, fueling, tuning, gauges. this allows people to go as cost effective or high end as they choose and maybe save money getting some parts used.
a boost controller or turbo timer are not required to run a turbo on any car. a boost controller is only necessary if your going for very high boost levels that cannot be attained by simply changing the wastegate spring. a turbo timer isnt necessary at all IMO b/c its only job is to let the car run after you shut it off to cool the turbo. how often are you shutting the the car off after boost with out letting it run a couple minutes any way. you never do a wot run down the drag strip and shut it off as soon as you cross the line
Tim
Turbo Turtle Garage
Old 10-25-2013, 03:10 PM   #29
Funkymonk
Funkymonk's Avatar
Fan#: 120157
Okay awesome and what type of turbo should I get? I've seen a lot of Foci with T3/T4 turbos.
What type of air filter would you recommend?
I've been doing a lot of research and been getting a lot of mixed messages and you seem to be the person who is most knowledgeable.
Old 10-25-2013, 10:26 PM   #30
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
vibrant 3 inch shorty filter is durable and worth your while
FF MODERATOR
RIFF CREW
