new zetec turbo kit - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-12-2013, 10:29 PM   #1
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,991, Level 91
Points: 20,991, Level: 91 Points: 20,991, Level: 91 Points: 20,991, Level: 91
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 9%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
new zetec turbo kit
thanks to all the people that have helped me along the way on the new zetec kit. i have finally settled on a design that offers every thing i think a focus kit needs.
for the manifold design i settled on a log manifold for my kit instead of the tubular b/c of the time and cost that goes into a manifold like that. it just isnt in the price rang of most focus owner's. if you want a tubular manifold it will have to be a custom piece requiring your car to be at the shop.
the manifold options will simply be schedule 40 mild steel or schedule 10 stainless. stainless being an extra $100 option. i prefer mild because it handles heat better than stainless. the manifold is a top mount that will clear up to a 35r frame turbo, allows you to use a 3" downpipe and still clears stock pcv, stock fans, stock thermostat housing, a/c compressor and lines, and power steering. both manifolds come with a standard 38mm 2 bolt wastegate flange unless you would like another then just let me know.
the oil lines will feed from above the tstat housing using a -3an line for feed and -10an return. the oil line kit will come with all fittings for engine, t3 turbo, and also comes with a oil pan with a return fitting. $50 core required for a pan.
the intercooler kit will include a 2.5" hotside and 3" cold side, 3" maf, and a bov flange of your choice. it will also come with all couplers and tbolt clamps. the 3" cold side piping is ran on the outside of the frame rail for the best flow and will clear the battery. the intercooler is a bar and plate 30x7.5x3 that has brackets to allow mounting with out modding the bumper.
the down pipe is 3" aluminized with o2 bungs and a t3 4 bolt 2.5" turbo outlet flange. if you are wanting to use a different exhaust housing i can send the flange you choose unwelded and you can simply weld it on or have any exhaust shop do it. i can not build a jig for every configuration so i chose the 4 bolt.
the wastegate dump tube is a simple 38mm 2 bolt dump unless you want some thing else.
the kit will also include an aluminum coolant log to replace the factory plastic one so it will clear the top mounted turbo
the kit does not include a turbo, wastegate, blow off valve, fueling, air filter, mafia, or tuning. i am just a fabricator and not an authorized dealer so i can not get these parts any cheaper than you. this will allow you to save more money by sourcing these separately.
all these parts can be separated as well, so if you already have an intercooler or something along those lines just let me know.
the price on the kit is $1400 with the mild steel manifold and oil pan exchange
Thanks
Tim
Turbo Turtle Garage
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 09-12-2013, 10:36 PM   #2
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 9%
here are some pictures of the kit. only thing not picture i believe is the dump tube. not finished with that yet but it will be simply dumping straight down next to the downpipe
Turbo Turtle Garage
Old 09-12-2013, 10:46 PM   #3
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 9%
This is a 35r on the manifold
these pictures show the intercooler kit but the intercooler in both is not the same. the first picture has the dimensions i wanted but had to be modded to get them. this is the size my new intercooler will be but will not have to be cut down like this one was. the second was a cheaper designed intercooler that i wasnt happy with but shows the piping routing well.
Turbo Turtle Garage
Old 09-12-2013, 11:18 PM   #4
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
fantastic! question thou. since ihave the pan and the cold side pipe how much would the kit be with the manifold hot side and downpipe. also wheres the picture of the aluminum coolant?
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 09-12-2013, 11:18 PM   #5
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
and with V band wastegate
FF MODERATOR
RIFF CREW
Old 09-12-2013, 11:32 PM   #6
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 9%
i'll get you the price soon. i'll need to look up how much the 38mm vband wg flanges would cost me vs the 38mm.
the alum coolant rail can be seen tucked under the upper core support.
Tim
Turbo Turtle Garage
Old 09-13-2013, 09:24 AM   #7
FocusZx3Oh
FocusZx3Oh's Avatar
Fan#: 10119
What I Drive: 2003 Turbo Svt
Points 5,134, Level 45
Points: 5,134, Level: 45 Points: 5,134, Level: 45 Points: 5,134, Level: 45
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 4%
FF Reputation: 2 FocusZx3Oh Good Standing Member
Are you going to have options to buy separate parts like manifold, down pipe, coolant tube and wastegate pipe?
2003 Turbo Orange Svt
FocusZx3Oh is offline
Old 09-13-2013, 10:05 AM   #8
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 9%
yeah like i said in the first post all the parts are priced separately so you can just let me know what you want and i can get it priced out
Tim
Turbo Turtle Garage
Old 09-19-2013, 11:11 PM   #9
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 9%
i have decided to drop 100 off the original price. decided to sell the kit for $1400
includes:
mild log manifold (available in stainless)
3" downpipe
wastegate dump tube for 38mm wg
oil line kit with oil pan (core on pan)
full intercooler kit (maf, couplers, clamps, bov flange, mounting bracket, & hardware included)
Tim
Turbo Turtle Garage
Old 09-20-2013, 12:33 AM   #10
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
this is by far a good deal I think after xmas ill be getting half the kit because I already have the other half lol
FF MODERATOR
RIFF CREW
