Head Gasket Questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2013, 09:38 PM   #1
Toother1321
Fan#: 111111
What I Drive: 2003 Red ZX3
Points 195, Level 3
Points: 195, Level: 3 Points: 195, Level: 3 Points: 195, Level: 3
Level Up 90% Completed
FF Reputation: 1 Toother1321 Good Standing Member
Well the saga that is my $600 fun project car continues. Yesterday I was driving, got off the highway, noticed smoke, immediately turned off the car and was lucky enough to coast it into a shop. Before I got to the shop I got the dreaded spray of water/coolant from under the hood and I knew right away the head gasket was gone. I just can't afford the 1300 I was quoted to fix it. So I'm going to have a go at it myself. Time is no issue, shes not my daily driver. So if it takes me a month, so be it! In short, I LOVE MY 10 YEAR OLD CAR!!! I've owned it for less than a year but it is the most fun car I've ever driven. I got this car being a life long fan of racing, and having very little mechanical skills. I'm already super proud of what I've learned and done mechanically (not even a small amount compared to most of you) and although i'm upset at the repair, I'm excited to take on a new challenge. Any help with the following questions would be GREATLY appreciated!!!
1. When the shop did the diagnostic to confirm the head gasket leak they used water to test instead of antifreeze. They then told me I shouldn't take it home and let it sit because the block would freeze (duh). Obviously a ploy to try and get me to keep it there to be fixed. I then told them to drain the block, and fill they system with antifreeze. I'm assuming there will still be some small amounts of pure water in there. Should I turn on the engine and let it run for a little to make sure antifreeze gets into the system?
2. What could cause the overheat in the first place. It has a 2 month old water pump, and the shop said they could not find any sign of what caused the car to over heat. There were no visible leaks during testing. They thought it could possibly have been the head gasket going bad that caused the problem. How likely is that and where else should I look?
3. Is it possible to do the repair using the haynes manual? Or am I way over my head? Like I said I'm not really concerned about how long it takes. I can be very thorough as there is no timeline. I would just like to know if there is any reason I simply won't be able to do the repair in my home garage.
Thanks for the help guys. I appreciate it. And if anybody is in the eastern PA area and would like to swing by my place to help work with me on the project, I would be more than happy to buy a few brewskis and have my wife cook up a nice dinner!!
Take Care,
Steve
Toother1321 is offline
Old 09-11-2013, 10:01 PM   #2
JFrye
JFrye's Avatar
Fan#: 54896
What I Drive: 2000 ZX3, 99 Dodge 3500 w/Cummins
Points 1,749, Level 24
Points: 1,749, Level: 24 Points: 1,749, Level: 24 Points: 1,749, Level: 24
Level Up 49% Completed
Forum Activity 3%
FF Reputation: 3 JFrye Good Standing Member
Buy-Sell-Trade Rating: (6)
How many miles are on the car? It could be possible that the head gasket failed by itself. Previous owners could have ran it low on coolant, and got it hot, but not hot enough to do instant damage. I assume this is a Zetec, and a common issue on these motors is the plastic thermostat housing likes to crack and form a small leak that isnt always noticeable. That too could be a cause for it to get hot. Im sure you can do this with the Haynes manual, but one thing I highly recommend is to get on Massive Speed System website, and order their timing belt tool. Its like $35 and will help you to ensure that you get it back in time the right way.
If you have more questions, just ask, and Im sure everyone will do what they can to help you figure it out along the way.
00 Silver ZX3. Zetec, ATX w/3.90 gears. 14" orange steelies. Eibach Sportlines, Massive Strut Bar, BBK 65mm TB, 4 to 1 Header followed by 2.5" into 3" exhaust.
Hatch Nation #31
JFrye is offline
Old 09-11-2013, 10:12 PM   #3
Toother1321
Fan#: 111111
Points 195, Level 3
I should have mentioned 113k on the car. Is this timing belt time since i'm going into the engine anyway? and yes it is a Zetec 2003 zx3
Old 09-11-2013, 10:45 PM   #4
JFrye
JFrye's Avatar
Fan#: 54896
Forum Activity 3%
If youre taking the head off to put a head gasket on it, then yes you should do the timing belt, and water pump while your there. Make sure you get the timing belt kit which also includes the tensioner and idler pullies as well.
Hatch Nation #31
JFrye is offline
Old 09-11-2013, 11:10 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
So am I reading this correct in that, they basically found nothing they can prove is wrong?
Pay for their time thus far (diagnosis and shop supplies) and be on your way.
Think about it.
If you see spraying from under the hood but there are no external leaks under testing, then it's a rather safe bet nothing is broken.
Your next process is to verify the cooling fans are working properly.
iminhell is offline
Old 09-11-2013, 11:30 PM   #6
Toother1321
Fan#: 111111
Points 195, Level 3
iminhell,
are you suggesting maybe even the head gasket isn't blown? I used to have an mg midget and the head gasket blew under almost the exact same circumstances. Thats why I wasn't that surprised when they told me that it was blown. I'm going to pick this thing up tomorrow. Is there a link on the forum that I could follow to learn about checking the fans?
When I pick it up, I'm going to ask them specifically what they did to test it. Thermostat housing, water pump, radiator, hoses, and now cooling fans are all things I'm going to ask them about, can anybody think of anything else that I should ask them about their "diagnostics". I want to add it did blow the overflow cap. Not sure how I forgot to put that in the first post but that was also one of my first tip offs that there was a serious problem
Old 09-11-2013, 11:44 PM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
I don't think you need to ask anything about diagnosis.
If it's all sorts of wet on the outside and they can't find an external leak ...
Odds are the radiator cap went bad, the engine got hot and puked coolant all over.
Replace the radiator cap (the black guy on the overflow tank) and go from there. It's a $13 part that may just be the cure all.
iminhell is offline
Old 09-11-2013, 11:56 PM   #8
JFrye
JFrye's Avatar
Fan#: 54896
Forum Activity 3%
With my Cummins, the head gasket would only leak externally when it was upto operating temps. Once it was cooled down it wouldn't leak. Lets be honest, nobody wants to work on a hot ass car that's steaming and smoking from under the hood. If the shop he took it to couldn't find a head gasket issue when its cold doesn't mean its not there. Just something to think about.
Basing that on the fact that my 99 Cummins held 15psi of pressure on the cooling system when it was cold. When warmed up, it had a small leak at the corner of the head. Once. We removed the head we discovered boil spot throughout the head gasket.
Hatch Nation #31
JFrye is offline
Old 09-12-2013, 02:52 AM   #9
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
Anybody check for coolant in the oil? A compression check may well confirm the gasket good/bad. May have just blown the cap as he says, I sure wouldn't be yanking head without positive proof it needs doing.
amc49 is offline
Old 09-12-2013, 06:51 AM   #10
Toother1321
Fan#: 111111
Points 195, Level 3
picking up the car today. I am going to run the three tests I found on this website to try and make sure it absolutely is a blown head gasket. In short it said do the following....
Check for milky oil,
Check for back pressure with overflow cap off,
Check compression,
I purchased a compression tester at autozone on my way in to work this morning. I'm using the second posters post on THIS THREAD to check the compressoin. The third guy down says to have the throttle to the floor. is this necessary?
Thank you for all the help so far! You guys are awesome! I'll update tonight
