Dash lights and tail lights not working - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-11-2013, 09:34 PM   #1
msfaulk
Fan#: 118737
What I Drive: 01 ford focus blue
FF Reputation: 1 msfaulk Good Standing Member
Hello,
I've got an 01 Focus and my dash lights just stopped working. Odometer light works, and the radio works. But the rest of the lights don't. If the key is on, the headlights work and the fog lights work but the tail lights do not. If I turn the key off then none of the lights work, even the headlights and there is no buzzer to alert me the lights were left on. The break lights work when the break is pushed and all blinkers work as well as revers lights. Just not the dash lights and the tail lights. I've checked all the fuses and they were fine. Anyone come across this or something similar? Thanks.
Mike
msfaulk is offline
Old 09-11-2013, 09:49 PM   #2
JFrye
JFrye's Avatar
Fan#: 54896
What I Drive: 2000 ZX3, 99 Dodge 3500 w/Cummins
Points 1,735, Level 24
Points: 1,735, Level: 24 Points: 1,735, Level: 24 Points: 1,735, Level: 24
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 3%
FF Reputation: 3 JFrye Good Standing Member
Buy-Sell-Trade Rating: (6)
Are you sure you checked all the fuses? In the past Ive had the same issue, and solved it with a blown fuse to the instrument cluster.
00 Silver ZX3. Zetec, ATX w/3.90 gears. 14" orange steelies. Eibach Sportlines, Massive Strut Bar, BBK 65mm TB, 4 to 1 Header followed by 2.5" into 3" exhaust.
Hatch Nation #31
JFrye is offline
Old 09-11-2013, 10:27 PM   #3
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
Forum Activity 10%
FF Reputation: 1 Leora83 Good Standing Member
Is it a hatch or wagon? Check the wiring harness between the gate and body for breaks. When your taillights go out the dashlights go too so you know you're invisible from behind.
Very common problem with that age of Focus.
Leora83 is offline
Old 09-11-2013, 11:10 PM   #4
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,780, Level 54
Points: 6,780, Level: 54 Points: 6,780, Level: 54 Points: 6,780, Level: 54
Level Up 15% Completed
Forum Activity 47%
Activity: 47% Activity: 47% Activity: 47%
Buy-Sell-Trade Rating: (23)
^This
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 09-11-2013, 11:29 PM   #5
msfaulk
Fan#: 118737
It's a 4 door sedan ZTS. I checked all the fuses that were associated with any lights with a multimeter to make sure they were good. I'm not sure what a gate is though. A couple weeks ago the dash lights didn't work when I turned the lights on, so I turned them off and back on and they worked. I didn't think anything of it until now. Guess I'll start in the trunk and work my way forward on the harnesses.
msfaulk is offline
Old 09-12-2013, 12:41 AM   #6
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 47%
There is a harness that passes through from the trunk lid/hatch into the body. Pull the boot back and inspect the wires for cracks/missing insulation. Many electrical gremlins arise from that one area.
Hatch Nation #140
Old 09-12-2013, 08:11 PM   #7
msfaulk
Fan#: 118737
freemind, I had to cut away the rubber insulation, but I didn't see any wire cracked or damaged. They were all very pliable. I did see some bad corrosion on one of the license plate lights. I'll have to check that out tomorrow. I did find two wire harnesses on the left wheel well in the trunk. Unfortunately the wiring diagram I have doesn't show them, so I'll have to look at each color and determine what should be hot and see if my problem is before or after these harnesses. What a pain.
msfaulk is offline
Old 09-12-2013, 08:25 PM   #8
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 47%
Do you have a ZX3/5 or sedan?
Hatch Nation #140
Old 09-12-2013, 09:05 PM   #9
JFrye
JFrye's Avatar
Fan#: 54896
Forum Activity 3%
He said he was a 4 door sedan ZTS.
Have you had the tail lights out recently or anything? I know on my hatchback, I had a problem before of the wire getting pinched behind the assembly, and causing shorts.
Hatch Nation #31
JFrye is offline
Old 09-14-2013, 05:09 PM   #10
msfaulk
Fan#: 118737
Ok, so I changed all the bulbs and nothing. Checked all the wiring and didn't find a single break. Like I said they were all pliable. I completely removed the license plate lights, cleaned all the corrosion and still nothing. I checked for voltage on the wires that should be hot coming from the switch to the tail lights and there was no voltage. I checked for voltage at the fuse box for the tail lights and there was voltage. So I moved on to the switch. I got voltage going to the switch with an org/blk wire as the wiring diagram says I should. But when you turn the switch on there should be voltage on the org/yel wire and the org/blk wire coming out but there is not. Org/yel go to the 7.5A fuse then down to the tail lights. The org/yel goes to the central timer module and the license plate lamps. Since there is no voltage coming from these wires when the switch is on, could it be a part of the switch is bad. The diagram shows two parts. Thanks.
msfaulk is offline
