Fittin To Flip A ZX3. Help? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-06-2013, 04:28 PM   #11
joecicalese
Fan#: 105573
What I Drive: 2001 Black ZTS
Points 1,221, Level 19
Points: 1,221, Level: 19 Points: 1,221, Level: 19 Points: 1,221, Level: 19
Level Up 21% Completed
FF Reputation: 4 joecicalese Good Standing Member
Originally Posted by _Just_Drive_ View Post
Dont I have to do some other mods to get the SVT header on it? What mm throttlebody are we talkin?
Assuming that I did all this, whats the tuner gonna cost me?
For the SVT header you will need to swap the oil dipstick for the SVT one (otherwise it's in the way), switch to the SVT flex pipe and catalytic converter or off road pipe, and if you don't plan to upgrade the exhaust right away you will need to modify the flange on the mid-pipe. The power steering line should also be moved or replaced using the relocation kit from CFM, as on the stock zetec it is too close to the header. I wouldn't go higher than 65mm on the TB. And Tom can advise on the big tuna'.
joecicalese is offline
Old 09-06-2013, 05:33 PM   #12
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
Points 2,469, Level 30
Points: 2,469, Level: 30 Points: 2,469, Level: 30 Points: 2,469, Level: 30
Level Up 13% Completed
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
First thing is deciding if you want to go the turbo or naturally aspirated route.
Call Tom (1turbofocus, posts 5 and 6) at the number in his signature and he can tell you the pros/cons of both.
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
Old 09-06-2013, 05:53 PM   #13
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,516, Level 100
Points: 52,516, Level: 100 Points: 52,516, Level: 100 Points: 52,516, Level: 100
Level Up 0% Completed
Forum Activity 62%
Activity: 62% Activity: 62% Activity: 62%
Buy-Sell-Trade Rating: (28)
Yes you have to mod or move the PS line and add a SVT dipstick but its all worth doing , there is no other header that will add half what the SVT header will add
I charge 399.00 and 20.00 for shipping for the xcal3 , full custom tune and free tune updates as you add more NA mods , you get my datalogging services where I can take over your laptop and set up the datalog list for you and do the first datalog like I was sitting in the car with you , you also get my help with any issues but I do that anyway lol
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-09-2013, 09:40 AM   #14
_Just_Drive_
Fan#: 118666
What I Drive: 2001 Matte Black ZX3
FF Reputation: 1 _Just_Drive_ Good Standing Member
Alright, I suppose the next question is where to get the SVT Header at. But I did just come across a problem...
My oil temperature is fluxuating depending on what I'm doing. When I'm driving its just fine, but when im just sitting idling it likes to go clear to the redzone. Any ideas?
_Just_Drive_ is offline
Old 09-09-2013, 09:52 AM   #15
joecicalese
Fan#: 105573
I think someone's got one in the buy/sell/trade forums (here). Either that or check for someone parting out an SVT in the Vehicles for Parts section.
As for the temp guage...the Zetec (except SVT) does not have an oil temperature sender, it only measures cylinder head temperature. The CHT sensor is a common part to fail. Check your coolant and make sure your fans are running. If it is only doing it at idle it is likely the cooling fan resistor.
Old 09-09-2013, 10:17 AM   #16
_Just_Drive_
Fan#: 118666
So is anything actually overheating or is it just a crazed resisitor or sensor?
Old 09-09-2013, 10:25 AM   #17
joecicalese
Fan#: 105573
Well, my money is on the resistor, check the forums for the repair, I believe it's an inexpensive piece to replace. I would start there. If you pop the hood when it's idling and can feel that the fans are running (don't burn yourself or lose a finger!) then it may just be the temp sensor.
Old 09-09-2013, 10:32 AM   #18
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
If the sender is bad, then it's giving you a false reading. If the resistor is bad, then it's overheating. As suggested, check to see if the low-speed radiator fan is running. It should kick on as soon as the temp gauge climbs from the center of the normal range. If it climbs past normal and you don't hear the fan kick on, it is most likely the low-speed fan resistor.
See here ->http://www.focusfanatics.com/forum/showthread.php?t=114907
Hatch Nation #90
TboneZX3 is offline
Old 09-09-2013, 12:17 PM   #19
_Just_Drive_
Fan#: 118666
Thanks guys, I appreciate all the feedback really. Good to know people have a good idea what they're talking about!
So I'm gonna have to paint this little beater to make it look decent. If I just want to do a one-sided black with clearcoats, what am I lookin at?
