Dogbone Mount - Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-05-2013, 04:37 PM   #1
haveaheath
Fan#: 118635
What I Drive: 2005 Focus ZX3
FF Reputation: 1 haveaheath Good Standing Member
Hey there folks. I'm new to the forum.
I drive a 2005 Ford Focus ZX3, manual trans, mark II. After reading some threads on this forum about vibration in the cabin, they led me to figuring out the dogbone mount on the rear of the engine was bad. I went to the nearest Ford dealership and purchased the mount. So thanks to the community here for helping me find that. I plan to change the it this weekend.
I've changed engine mounts on past cars I've owned, but never one that looked like this. Do you have to use a torque wrench to tighten down the bolts once replaced, and does any know the amount of pounds/force to use? Or will hand tightening with the just simply the ratchet suffice?
Much obliged!
haveaheath is offline
Old 09-05-2013, 06:27 PM   #2
RPMisChris
RPMisChris's Avatar
Fan#: 76276
What I Drive: 07 svt 2.3 swap thing
Points 5,336, Level 46
Points: 5,336, Level: 46 Points: 5,336, Level: 46 Points: 5,336, Level: 46
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 1 RPMisChris Good Standing Member
Buy-Sell-Trade Rating: (16)
Super easy just make sure u put the transmission bolt I'm first and then slide the other end into the subframe portion. If I remember right I torqued em down to 66 foot pounds.
RPMisChris is offline
Old 09-06-2013, 09:23 AM   #3
haveaheath
Fan#: 118635
66 foot pounds? That sounds like a lot. Are you sure it's not somewhere around 35 ft pounds for the roll restrictor?
Old 09-06-2013, 06:25 PM   #4
amc49
Fan#: 96610
Points 3,364, Level 36
Points: 3,364, Level: 36 Points: 3,364, Level: 36 Points: 3,364, Level: 36
Level Up 10% Completed
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
Just get 'em tight, I've never used a torque wrench there. That doesn't mean tight like a girl (no insult there!) though.
amc49 is online now
Old 09-08-2013, 12:23 PM   #5
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 1 AllCarFan Good Standing Member
i cant get my dogbone bolt out. It has soaked in PB Blaster for two days...a 24" breaker bar, 13mm socket.....nope. I just started to strip the head, so i stopped.
AllCarFan is offline
Old 09-09-2013, 08:16 AM   #6
haveaheath
Fan#: 118635
I found a thread on the forum here that said torque the bolts to 35 lbs, so that's what I ended up doing. The bolt on the top of the mount bracket was really tough to tighten down, so I hope that one if ok. I tightened with the 13mm gearwrench with the hand, but it was really tough to get some leverage. I'm HOPING that bolt holds.
I was able to get the bolts off without any big issues. I really had to get some leverage on the one tied to the frame, and still ended with bruised knuckles.
Ford has redesigned the dogbone mount, so I had to drive to 2 different dealerships, neither of which were in town, to find the correct mounting bracket. The original parts dealer at Ford failed to tell me this would be needed.
In the end, a 45 minute project turned in to over 3 hours, due to all the running around.
Old 09-09-2013, 04:25 PM   #7
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,893, Level 59
Points: 7,893, Level: 59 Points: 7,893, Level: 59 Points: 7,893, Level: 59
Level Up 72% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Ive not heard of this one being that tough to remove before...i mean it wouldnt be surprising if you lived in the snow/rust belt but not on a southern car.
Do you now anyone with an impact wrench?
rambleon84 is offline
Old 09-09-2013, 04:38 PM   #8
AllCarFan
Fan#: 102583
I think the shop that put my clutch in may have torqued this bolt down a little too much. I just don't want to strip the head
Old 09-13-2013, 02:11 PM   #9
darkknight9
darkknight9's Avatar
Fan#: 109076
What I Drive: 1995 Green Escort LX
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 2 darkknight9 Good Standing Member
Originally Posted by amc49 View Post
Just get 'em tight...That doesn't mean tight like a girl (no insult there!) though.
i cant get my dogbone bolt out...
Too tight.
Rally Revolution #74 Drive er straight sideways lad!
Saving for a Focus wagon for a daily
History: 1975 Chev 1 ton Camper Special, 1977 LTD II (Best car I've ever owned), 1985 Toyota Corolla, 1995 Ford Escort LX (current)
darkknight9 is offline
Old 10-17-2013, 03:44 AM   #10
Humphrey
Humphrey's Avatar
Fan#: 91540
What I Drive: 05 Ford Focus ZX3 w/ 2.0 Duratec
Points 1,620, Level 23
Points: 1,620, Level: 23 Points: 1,620, Level: 23 Points: 1,620, Level: 23
Level Up 20% Completed
FF Reputation: 3 Humphrey Good Standing Member
Could try heating the bolt with a torch as well as tapping it to knock lose some rust. If all else fails you could weld on a nut and try again if you strip it.
Humphrey is offline
