Throttle body made out of plastic... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-03-2013, 11:09 PM   #1
lAj0828
Fan#: 117929
What I Drive: 05 Grey ZX4
FF Reputation: 1 lAj0828 Good Standing Member
I found out today that the throttle body on my Duratec is plastic. I cleaned my maf sensor today and I tightened the clamps on my cai. Well it turns out that the clamp on my throttle body was too tight. My gas pedal was extremely tight due to the fact that the plastic on the throttle body was warped just enough to restrict the movement of the plate. After about 45 minutes of trying to find the problem I figured it out. So if you are installing a new cai DO NOT OVER TIGHTEN THE CLAMPS!! It was kind of funny i couldn't let out the clutch without stomping on the gas and burning the tires. I am just happy that i didn't drive like that and end up with bits of plastic and metal in my engine.
lAj0828 is offline
Old 09-06-2013, 06:28 PM   #2
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
Radical, you should've been cutting through the rubber CAI tube to do that.
amc49 is offline
Old 09-07-2013, 07:17 AM   #3
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 1 AllCarFan Good Standing Member
pics?
Never heard of such a thing.
AllCarFan is offline
Old 09-08-2013, 10:10 PM   #4
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
FF Reputation: 1 VillageT Good Standing Member
I installed a CAI on my 2005 and had the same issue. It took a while to figure out the problem but loosening the clamp at the hose at the throttle body inlet cured the hanging throttle issue. Tightening the clamp distorts the throttle body causing the throttle to hang up (this does not require excessive tightening). You have to run that clamp fairly loose but not enough to let dirt into the system.
VillageT is offline
Old 09-08-2013, 10:50 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 99%
1st time I heard that. ^^^^^^ As you learned not to over tighten clamps/bolts.
felixthecat is online now
Old 09-09-2013, 03:54 AM   #6
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,573, Level 100
Points: 35,573, Level: 100 Points: 35,573, Level: 100 Points: 35,573, Level: 100
Level Up 0% Completed
Forum Activity 8%
Thottle body on the zetec is also plastic. The SPI is metal.
You can get a larger throttle body from FSwerks if your interested thats metal. (65mm IIRC)
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is offline
Old 09-12-2013, 01:54 AM   #7
lAj0828
Fan#: 117929
Yeah I guess you live and learn. I don't know if I would be interested in an aftermarket throttle body. From what I have read you only see gains on turbo setups. I was so worried about leaks and dust that I just went overboard. I just tightened the clamp in quarter turn increments until I could feel restriction in the gas pedal. I adjusted it accordingly.
lAj0828 is offline
Old 10-20-2013, 08:17 PM   #8
wickedgreyzx3
Fan#: 34204
What I Drive: 2006 ZX3 Liquid Grey
FF Reputation: 17 wickedgreyzx3 Great Standing Member
You'll be hard pressed to find maybe, 6 cars with anything but a plastic throttle body after 2000.
Modifying cars is retarded. Buy a bike instead.
wickedgreyzx3 is offline
Old 10-21-2013, 09:12 AM   #9
Phestezio
Phestezio's Avatar
Fan#: 97562
What I Drive: 2007 Oxford White ZX3
Points 1,268, Level 19
Points: 1,268, Level: 19 Points: 1,268, Level: 19 Points: 1,268, Level: 19
Level Up 68% Completed
Forum Activity 7%
FF Reputation: 4 Phestezio Good Standing Member
I would just buy the CFM 67mm throttle body, i'm still NA and I noticed a huge difference in throttle response and driveability, you would see more gains with a turbo setup but even NA it is a great thing to buy, an aftermarket one is the only way to get rid of that plastic, which was a big reason for me
Phestezio is offline
Old 10-23-2013, 08:49 AM   #10
amc49
Fan#: 96610
Forum Activity 11%
To get rid of plastic you must get rid of the car. Today's car requires relearning a few things and learning others first time, like the qualities of plastic parts. LOL.............
amc49 is offline
