Questions of drop in filter vs CAI (not a which is beter, just questions) - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 09-03-2013, 11:38 AM   #1
MichaelBeers
Fan#: 93055
What I Drive: 2012 Tuxedo Black Focus SE
FF Reputation: 1 MichaelBeers Good Standing Member
I just was reading about the snorkel delete and cutting of that piece or whatever. Everyone was saying you will get most benefits when you do a drop in filter. For the guys doing a drop in, what are you doing with the stock box? Are you just taking the lid off? Did you remove that weird tube thing under it? Or is everything the same as stock except the filter?
Also, besides cost, why all this instead of a CAI from fswerks or steeda or whoever? And if I got a CAI would I still benefit from removing the snorkel and everything?
I've never had a car with so much options/piping to delete or change. Just wanting to see what any why.
Thanks,
Michael
MichaelBeers is offline
Old 09-03-2013, 11:44 AM   #2
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
Thanks,
Michael
In my opinion the delete and custom snorkel is a cheap and viable option only issue is if you ever take the car for service due to any engine related issues you no longer have the stock unchanged factory pieces to put back on since they were cut and modified. In the case of a CAI or Shortram you still retain pieces to return the vehicle to 100% stock without concern of voiding your warranty when you bring the vehicle back.
Overall price is the concern. Performance Per Dollar might add up until you bring the car in for warranty. In the end more power can be had by a bolt on intake for more $$$.
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is online now
Old 09-03-2013, 12:04 PM   #3
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
FF Reputation: 46 dyn085 Great Standing Member
Not the most benefits per-se, but the best hp-dollar ratio. You have to do the snorkel delete/drop in together, or you don't see the full benefit of either.
I keep the stock box in it's original form.
No. This leads to heat-soak and hesitation in stop-and-go driving, which I do enough of to not want. Plus, imho, it sounds horrible.
That's the airbox resonator. Mine is currently removed with the box opening sealed to keep engine bay heat out. No real gains other than sound.
Basically. I'm pretty sure that you don't have to cut/remove the shroud underneath the snorkel either, but there's no data in either direction.
Depending on the CAI you're looking at, a lot. Many of the non-shrouded intakes experience the heat soak, and most all give up some of the low-end torque to make gains up higher in the RPM range.
Most likely not, and definitely not anything you're going to notice in either seat-of-the-pants or fuel mileage.
Thanks,
Michael
I broke your post up to answer each question individually. Fwiw, in the next day or so I should have my new drop-in so that I can remove my Steeda. I've also run the Typhoon and Griffin (Newmission) Mod, and nothing that I've had works as well on my commute and with my driving style as the drop-in/snorkel-delete. If I raced my car often, stayed in the higher RPM range, or did a lot of Interstate driving then I would feel differently.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 09-03-2013, 12:29 PM   #4
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
FF Reputation: 6 RonMaiden Good Standing Member
I concur with dyno;everyday driving is what's important to me so my ?s were answered in his one post.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is online now
Old 09-03-2013, 12:29 PM   #5
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
FF Reputation: 3 Juicedz Good Standing Member
The fun police might be lurking. Honestly though, this is why I went with steeda and ordered a second factory tube. I can swap out to stock in 10 minutes flat.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 168whp 153wtq
Juicedz is offline
Old 09-03-2013, 12:32 PM   #6
MichaelBeers
Fan#: 93055
I definitley don't want to lose low end.
I do both hwy and somewhat curvy mountain roads almost every day. In your opinion which would I benefit more from? Also if I did a drop in would just removing the snorkel do enough? Or should I try and remove that other piece. Cutting is out of the option incase I have to sell the car later one.
And thanks for the detailed response already!
Old 09-03-2013, 12:39 PM   #7
MichaelBeers
Fan#: 93055
Just saw where you said I probably don't have to cut/remove the shroud. Awesome. I think money wise I'll do a drop in and remove snorkel. I had the resonator removed at one time but put it back. Although I didn't plug the hole. I may have to do this so I won't be getting a cool "sound" from other CAI's.
Old 09-03-2013, 12:41 PM   #8
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Honestly, I think the majority of us are best served with the snorkel delete/drop in. If you did only/mainly highway mileage you would probably see an increase in mpg by doing the Griffin mod, but the problem with that, in my opinion, is that if you weren't satisfied with the results then a replacement box is pretty expensive. Trust me
I don't believe that the shroud has to be cut/removed. It's something that we were experimenting with to facilitate a better air transition. Realistically speaking, when the car is in motion there is already enough air available. Just removing the snorkel should suffice as there is no data that specifically shows otherwise.
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 09-08-2013, 07:59 PM   #9
MiTi91
Fan#: 115532
What I Drive: 2013 Tuxedo Black Titanium
FF Reputation: 1 MiTi91 Good Standing Member
@dyno85, how did you seal the air intake silencer hole. And do you have to seal it? Thanks.
MiTi91 is offline
Old 09-08-2013, 08:27 PM   #10
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
I used a piece of aluminum and sealed it to the box with some clear RTV
September '13 ROTM
2014 FiST-
dyn085 is offline
