First Visit to Ford with Real Transmission Issues - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-03-2013, 12:28 PM   #1
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 21,152, Level 91
Points: 21,152, Level: 91 Points: 21,152, Level: 91 Points: 21,152, Level: 91
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
Some may feel this doesnt apply to this section of the forum but considering the mods and the power the car makes I think it is fair to say it belongs here.
So Today my Focus is at Ford with 17,000 Miles on the clock (alot of city driving since I have moved to philly)
I have had the I,H,E combo on for quite some time now, I believe over a year at this point.
Car is still making pretty good power and apparently tuning is now availible which means even more power is availible.
Lately I have been noticing massive slips and heavy jerking under weak acceleration/partial throttle. Car seems fine at WOT granted the power it puts down after 2nd seems much weaker than at first when the mods were done.
Obviously now I have the vehicle at Ford and they have already asked me questions about mods. My only saving grace is the vehicle has not been tuned. So I told Bob the Service writer very politely that the mods are in direct violation of the warranty on the Engine and If I was having mechanical issues related to the engine that my mods would free them of any liability according to Fords warranty policies. In the case of the transmissions failure to shift at certain times, extreme jerkiness through the gears at low rpms and loud grinding in any gear under load; up slight inclines, that they would have to prove beyond a reasonable doubt those parts cause all of those issues.
The car was also never in to get the Transmission reflashed because I was never having issues and that old saying applies "If it isnt broke dont fix it".
Just wanted to inform you guys on the situation.
I am Sorry I have been neglecting the forums so much but if you ever need to contact me. Private Message me, it goes straight to my phone.
Have a great day and I will be adding more when I can.
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is online now
Old 09-04-2013, 03:28 PM   #2
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
Ford did the TSB transmission update on the PCM and ECM. Car seems a little better on drive-ability but still seems to be slipping under partial throttle.
The service writer stated that if the problems continued that they would bring it back in and pull the transmission for replacement.
Hopefully this Update has settled the problems if not I will going back in.
I will update this next week if I decide to take the car in.
Old 09-04-2013, 04:18 PM   #3
MG_MK3
MG_MK3's Avatar
Fan#: 114522
What I Drive: 2013 Blue Candy Focus Hatchback SE
Points 502, Level 10
Points: 502, Level: 10 Points: 502, Level: 10 Points: 502, Level: 10
Level Up 4% Completed
Forum Activity 2%
FF Reputation: 0 MG_MK3 Newbie
So your foci is a DCT vs the stick? Good luck to you, hopefully that fixes the major problems.
2013 "Blue Candy" Focus Hatchback SE/DCT
AEM CAI | Steeda RMM | ST wing | TTR UMM
2.5 inch straight pipe | 3SDM 0.05 18"x8.5J | KSport Kontrol Pro's
Instagram @miKeyGilmore #MK3SLöCUS
MG_MK3 is online now
Old 09-04-2013, 06:06 PM   #4
Bliky
Bliky's Avatar
Fan#: 95135
What I Drive: 2012 Sterling Gray Focus Titanium
Points 3,377, Level 36
Points: 3,377, Level: 36 Points: 3,377, Level: 36 Points: 3,377, Level: 36
Level Up 18% Completed
FF Reputation: 4 Bliky Good Standing Member
I've had mine in for trans problems. They've done a couple updates and some "resets". After every one the car seemed fine for a couple hundred miles then goes back to the part throttle slipping. I haven't been able to get my dealer to even take the trans out as every time it's in they do the "reset" and everything seems fine. They give it back THEN problems start happening. From everything I can figure that when that slipping happens that's mechanical. I'm almost 100% sure my car needs a clutch replacement. Guess when the DCT tune comes out we will find out.
'12 Sterling Grey Titanium Hatch - Moonroof / Winter Package / DCT / 17' Alloy Wheels
MK3 Manual Transmission Swap: http://bit.ly/1ondtuV
Bliky is offline
Old 09-21-2013, 07:53 PM   #5
EZLivin
Fan#: 119123
What I Drive: 2013 White Focus SE
FF Reputation: 1 EZLivin Good Standing Member
I had the same problem.....
I had the exact same problem with my 2013 SE Focus. I have had it into the dealership FIVE times already. They have done the TSB transmission flash once and have done the clutches twice on the car. There is a problem with a seal in the housing that starts leaking and gets oil on the clutches. I have to admit since they have done the work, it doesn't slip but the car doesnt drive the same way. It shifts much harder than before. I only have 13.5k miles on my car! I am working with Ford right now on a buyback (which is pretty lame because I have some good plans for this car) but I just don't have as much confidence in it. My girlfriend drives a 2012 SEL with 27k miles and the transmission finally just gave out today. It gave her an error message that stated "Transmission malfunction Service now." And I didn't mistype this; it literally was spelled this way lol. The car lost power and stopped accelerating. Ford did great on everything but the tranny on this car. Good luck with it!
EZLivin is offline
Old 09-21-2013, 08:23 PM   #6
MG_MK3
MG_MK3's Avatar
Fan#: 114522
Forum Activity 2%
curious to know how its holding up with the power you are putting down...
Old 09-23-2013, 02:13 PM   #7
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2014 Fusion Titanium AWD Moonroof
FF Reputation: 2 OPsDad Good Standing Member
My 2013 Titanium Sedan with DCT is in for the third time in 2 weeks for symptoms that sound pretty much like those described on this thread. It also makes a chattery sound under light acceleration, in addition to stutter/lunge at take-off under light throttle, like when in the driveway, exiting my garage, etc. They said that new firmware came out this weekend to deal with this issue. Previous updates fix it for about 200 miles and then it comes back. If it does it again, I'm going to start the dialogue with the dealer about buy-back, and IF that happens, I'll pay the difference and get an ST.
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
Old 09-24-2013, 09:17 AM   #8
spiikey1
Fan#: 111130
What I Drive: 2012, Focus Trend Hatch Silver
Points 1,365, Level 20
Points: 1,365, Level: 20 Points: 1,365, Level: 20 Points: 1,365, Level: 20
Level Up 65% Completed
FF Reputation: 1 spiikey1 Good Standing Member
ive had similiar issues wtih mine, when turning the wheel it'd make noises, assuming its the clutch. Took it to ford they said its wearing in the clutch, nothing to worry about.
http://www.youtube.com/watch?v=54_3_qF2xhQ
this vid is not my car but its a good example of whats happening
spiikey1 is offline
Old 09-24-2013, 10:16 PM   #9
spiikey1
Fan#: 111130
Hi guys i called ford today regarding this issue... They said the reflash stated above is something that has a 10% chance of working depending on how bad the clutch/trannsmision is...
Furthermore they said that by next week they will have a clutch tcb..watever that may be.. but they told me basically one is a reflash on the computer of the car... the other is involving slight mechanical work.. this problem seems to be common but this fix apparently has a 95% chance of fixing the problem.. Maybe go into your ford dealers and get it checked...
It is under the new car warranty after all so its free!
spiikey1 is offline
Old 10-06-2013, 11:36 AM   #10
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
FF Reputation: 6 CunFFS13 Good Standing Member
Are you ready for the second, the third..... The endless number visit to the Ford dealer?
Good luck!
CunFFS13 is offline
