2004 Focus Rally Build - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 03-16-2014, 08:25 PM   #81
fclevelandwrx
fclevelandwrx's Avatar
Fan#: 118803
What I Drive: 2001 Red ZX3 Stage rally car
FF Reputation: 1 fclevelandwrx Good Standing Member
Originally Posted by MaxAtk View Post
Still plugging along. Final engine assembly.
Last thing I'll post til I get a response… What kind of cams did you use I am thinking about building my engine but I want it to run reliably and not put too much too the wheels. If you're looking for something to do to your car (this goes for all focus peoples that rally) look into making one of these:
Name:	trans break one.jpg
Name:	Trans Break 2.jpg
fclevelandwrx is offline
Old 03-16-2014, 08:32 PM   #82
FocusZTSRS
Rally Rev #00
FocusZTSRS's Avatar
Fan#: 99835
What I Drive: 2012 SE Hatch (RALLY00)
Points 24,400, Level 95
Points: 24,400, Level: 95 Points: 24,400, Level: 95 Points: 24,400, Level: 95
Level Up 5% Completed
FF Reputation: 3 FocusZTSRS Good Standing Member
We talking a Kaaz and a 4.75 Final drive?
Rally Revolution #00 (Leader)
2012 Blue Candy Metallic SE Hatch
2001 ZTS Rally Car
[HOONIGAN]
Riley
FocusZTSRS is offline
Old 03-16-2014, 08:39 PM   #83
fclevelandwrx
Fan#: 118803
Yeah but if you want to get the maximum amount of grip you need to get a clutch based lsd the gear based kaaz and quaiffe just don't do the trick and when you run into a super low to zero traction environment with a gear driven lsd surprise you now have an open diff. If you want advice on the lsd and final drive there is actually a man who specializes in mtx75 transmissions named Terry* Haines I'm pretty sure and he owns Haines motorsports and they can make you one hell of a trans.
Old 03-17-2014, 10:26 AM   #84
MaxAtk
Fan#: 118232
What I Drive: 2004 White Focus Rally
Points 592, Level 11
Points: 592, Level: 11 Points: 592, Level: 11 Points: 592, Level: 11
Level Up 84% Completed
FF Reputation: 1 MaxAtk Good Standing Member
For Cams I am running Cat Cams SVT Camshafts. Here are the specs:
14 Grind - hot street - dirt track. intake/exhaust camshaft data:lash ramp: 0.25mm/0.25mm duration @ 0.1mm: 277°/269° duration @ 1.0mm: 243°/236° valve lift: 12.00mm/11.50mm cam lift: 12.00mm/11.50mm lobe angle: 105°/105° timing @ 1.0mm: 17° / 46°43° / 13° valve lift @ TDC: 3.30mm/2.80mm
I am still about 3 weeks away from tuning as now I am waiting on the ECU to ship, so I do not have much real input on them as of yet.
MaxAtk is offline
Old 03-17-2014, 10:35 AM   #85
MaxAtk
Fan#: 118232
Also the KAAZ diffs are clutch based not torque/gear based.
FAQ: http://www.kaazusa.com/tech_faq.html
MaxAtk is offline
Old 03-17-2014, 11:47 AM   #86
fclevelandwrx
Fan#: 118803
That's the clutch based what's the other gear based diff?
That should be a beast!
Foard C.
RM-Autosports.com
Blue Branch Rally Team
Old 03-18-2014, 03:03 PM   #87
MaxAtk
Fan#: 118232
Originally Posted by fclevelandwrx View Post
That's the clutch based what's the other gear based diff?That should be a beast!
I believe the basic KAAZ diff is also clutch based. The SuperQ uses specially treated clutch discs to lengthen service life and the other feature is no break in is needed. They also tend to engage a little smoother and smooth out shock to the transmission components.
I think Torsen made the other gear based LSD.
MaxAtk is offline
Old 03-18-2014, 08:09 PM   #88
rallyrs
Fan#: 19498
What I Drive: 2004 French blue ZX3
Points 291, Level 5
Points: 291, Level: 5 Points: 291, Level: 5 Points: 291, Level: 5
Level Up 82% Completed
FF Reputation: 3 rallyrs Good Standing Member
Yeah..if we are still talking about the MTX-75 trans:
Quaife and Torsen are torque biasing -no clutch plates...gears-good street diff.
Edit..Forgot Mfactory has a torque biasing too..as well as the clutch type mentioned below...
Kaaz, Mfactory and Gripper are the clutch types....good race diff..especially on dirt!
Oh and it's actually Terry Haines who rebuilds the MTX-75's...
2004 French Blue ZX3, 2.3 Duratec,5-spd
2012 Slate Blue Mazda6 2.5 Duratec/MZR,slushbox
2005 Velocity Red Mazda 3S Sedan
2.3 Duratec/MZR,slushbox-sold
rallyrs is offline
Old 03-18-2014, 08:28 PM   #89
fclevelandwrx
Fan#: 118803
Fixed it for him, I was close at least.
With the quaiffe although still not as good as the clutch based you can shim it to make it work just as well… I may try that with one soon I'd like to see someone who has, apparently it makes the transitions feel rough which is why they're not sold like that for road use but in rally it's too loud in the car anyhow.
Foard C.
RM-Autosports.com
Old 03-19-2014, 08:48 AM   #90
MaxAtk
Fan#: 118232
While we were talking transmission and diffs I started to dive into mine.
Nice and filthy to start. Time for a hot bath of something or another. I think this engine had leaked all 4 quarts of oil on to this thing by the time I came across it.
Old Diff and final drive coming out.
Thankfully grandma must have driven this car. There is not a nick on any part of the transmission... at least she knew how to drive stick...
Also went to RallyX at Team O'Neil this past weekend. My friend let me drive his beater RallyX Subaru. Disappointed that no Ford's were there with the exception of a 2011 Fiesta. He had some of the best times, btw. It was a sheet of ice at least until the late afternoon...
Power, power....
MaxAtk is offline
