2004 Focus Rally Build - Page 5 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 12-13-2013, 04:39 PM   #41
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
FWIW, I believe that the bent design is superior in terms of bump steer. While such things might not matter much to you with the amount of travel you see, I thought it worth mentioning. I know that the Mk3 ST has some a bent end for that reason.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 12-13-2013, 06:31 PM   #42
Juggernaut Mtrsprts
Juggernaut Mtrsprts's Avatar
Fan#: 107925
What I Drive: '00 ZX3 rally car
FF Reputation: 1 Juggernaut Mtrsprts Good Standing Member
Thanks for the info! Can't say we've noticed negative handling changes or characteristics when moving from the pre 06 to 06 tie rods; other than not having them bend causing a somewhat more permanent toe issue :-P.
2000 ZX3 Group 2 Rally Car
Juggernaut Motorsports
Juggernaut Mtrsprts is offline
Old 12-14-2013, 08:31 PM   #43
cody.carr
Shlammed Life
cody.carr's Avatar
Fan#: 97521
What I Drive: 2000 Malibu Blue ZX3
FF Reputation: 2 cody.carr Good Standing Member
Buy-Sell-Trade Rating: (6)
please gawd put a roof vent in.. and do a how to..
2000 ZX3: ╠╬╝ Iceman CAI, Raceland Coilovers, SVT Header Swap
HOTM February '13 HN #06 RR #39
cody.carr is offline
Old 12-24-2013, 12:04 PM   #44
MaxAtk
Fan#: 118232
What I Drive: 2004 White Focus Rally
FF Reputation: 1 MaxAtk Good Standing Member
Thanks Juggernaut Motorsports for the tip on the tie rods, etc. Definitely a better solution than reinventing that wheel.
Cody, I did put a roof vent in, but it's very utilitarian. Just a box truck roof vent with some sealant and bolts. I may put a scoop on the exterior just for looks.
I do have a nice XMAS vacation planned and it includes assembling my short block
It will include: JE Pistons 11:1 CR 85mm Pistons, Eagle Rods, Polished Stock Crank, Clevite Bearings, all balanced. ARP Main Studs and Head Studs. Block was cleaned, blasted, bored and honed and the mains were align bored with the ARP studs installed.
Also started work on the wiring. Here is my box that houses the relays for all less critical items, like blinkers, brake lights, etc. Purchased a bunch of real nice mil-spec wiring for pennies on the dollar from a surplus company.
MaxAtk is offline
Old 12-26-2013, 09:04 AM   #45
Juggernaut Mtrsprts
Fan#: 107925
I should also mention that at our last event (Tallpines Nov. 30) I bent one of the cfm control arm rod ends on the driver side early in the day (causing the steering to get very heavy) which subsequently sheared on a rock ending our day earlier than expected. Currently I'm working on a solid arm design with with inboard adjustability or none at all and simply build two sets of arms to get the different camber settings I'd like. Just looking at and benchmarking wrc stuff.
Old 12-28-2013, 08:45 AM   #46
cody.carr
Shlammed Life
cody.carr's Avatar
Fan#: 97521
Could you post some pics? Inside and top?
Old 01-24-2014, 12:49 PM   #47
MaxAtk
Fan#: 118232
Sorry for the gap in coverage. I will write up a Rally Vent how-to for you Cody. I've got some new shots of the finalized rear subframe. Much more elegant than my crazy proof of concept one. Still finishing the welding so more gussets and jack plates need to go on. Finally going to assemble the short block tomorrow. Just didn't happen over XMAS break as I intended.
MaxAtk is offline
Old 01-24-2014, 12:59 PM   #48
MaxAtk
Fan#: 118232
Juggernaut, I've seen a bunch of rally arms from the late 90's early 2000's that used these type of weldable control arm bearings. If you can adjust camber from the top of the strut or just get the arms perfect. Then a set up using these may be a lot more robust. I've been collecting rally suspension photos for awhile but can't seem to find the one that uses this type of setup. I'll keep looking.
MaxAtk is offline
Old 01-26-2014, 01:29 AM   #49
TylerEstes
TylerEstes's Avatar
Fan#: 137737
What I Drive: 2001 black Focus SE
FF Reputation: 1 TylerEstes Good Standing Member
Originally Posted by MaxAtk View Post
TylerEstes is offline
Old 01-26-2014, 03:02 PM   #50
762racing
Fan#: 106398
What I Drive: 2004 Silver SVT
FF Reputation: 1 762racing Good Standing Member
Very nice build here!!
2004 Ford Focus SVT - SCCA RallyCross NER - Modified FWD #11
2004 Nissan 350Z - Drift Project
1980 Yamaha XS850 - Cafe Racer Project
762racing is offline
