2004 Focus Rally Build - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 11-07-2013, 10:04 AM   #21
cody.carr
Shlammed Life
cody.carr's Avatar
Fan#: 97521
What I Drive: 2000 Malibu Blue ZX3
FF Reputation: 2 cody.carr Good Standing Member
Buy-Sell-Trade Rating: (6)
that's one hell of a design for the rears. I wonder how that would react in a street setup... hermmmmm. subd for moar rally porn
2000 ZX3: ╠╬╝ Iceman CAI, Raceland Coilovers, SVT Header Swap
HOTM February '13 HN #06 RR #39
cody.carr is offline
Old 11-08-2013, 04:27 PM   #22
MaxAtk
Fan#: 118232
What I Drive: 2004 White Focus Rally
Points 592, Level 11
Points: 592, Level: 11 Points: 592, Level: 11 Points: 592, Level: 11
Level Up 84% Completed
FF Reputation: 1 MaxAtk Good Standing Member
A little more of an update on the rear suspension. In Gravel Rally mode, the suspension travel is a little over 9". This was maxing out the 3/4" high misalignment spherical bearing at max droop. So, I made a new set of lower control arms with a bend in it to take the load off the bearing. Also another note, the current sub-frame was made up to verify all the geometry. I'm going to make a more streamlined tubular one using bends, instead of cut angles and welds. This sub frame uses the stock sub frame mounting points. The new one on the drawing board will use some new mounting points.
MaxAtk is offline
Old 11-08-2013, 04:28 PM   #23
MaxAtk
Fan#: 118232
Another angle
Full Droop with 15x6 wheel
MaxAtk is offline
Old 11-08-2013, 04:30 PM   #24
MaxAtk
Fan#: 118232
Here is some steering column work. Pretty straight forward racing column with a 2:1 quickener thrown in the mix for now.
MaxAtk is offline
Old 11-08-2013, 04:37 PM   #25
MaxAtk
Fan#: 118232
Since all WRC cars run a McPherson set up in the rear whether it's tarmac or gravel I'm sure it would be fun on the street as well. Now whether it's worth converting a street car I don't know. The biggest knock on a McPherson set up is camber changes on extreme bump/droop. The longer your arms the less of a problem this is, and with shorter travel of tarmac suspension probably not a huge deal in performance. For tarmac set up, you can run a shorter damper and spring.
MaxAtk is offline
Old 11-08-2013, 04:47 PM   #26
cody.carr
Shlammed Life
cody.carr's Avatar
Fan#: 97521
So, how much love would you need from me to get my hands on one of these setups
Old 11-08-2013, 04:53 PM   #27
MaxAtk
Fan#: 118232
Once I finalize everything the components are pretty straightforward to make and I plan on publishing the dimensions. The biggest thing is welding in the strut towers but if you're comfortable cutting out your wheel wells, notching the frame a little and welding it in then I'm sure I can make a set of everything. I'll probably make another set of everything for myself as spares so maybe making a few sets could be more economical.
PM your info and I can keep you posted.
MaxAtk is offline
Old 11-08-2013, 04:56 PM   #28
MaxAtk
Fan#: 118232
Also, depending on the final sub frame you may have to rework the end of your exhaust system... TBD though...
MaxAtk is offline
Old 11-08-2013, 11:05 PM   #29
cody.carr
Shlammed Life
cody.carr's Avatar
Fan#: 97521
Pm'd
Old 11-14-2013, 11:25 AM   #30
furiouslyfaster07
furiouslyfaster07's Avatar
Fan#: 21624
What I Drive: Red 94 Mustang GT,GRAY 06 F-150 4X4
Points 1,353, Level 20
Points: 1,353, Level: 20 Points: 1,353, Level: 20 Points: 1,353, Level: 20
Level Up 53% Completed
FF Reputation: 3 furiouslyfaster07 Good Standing Member
subscribed!!!!! This looks like fun.
Focus Factor
Red 94 Mustang GT
Gray 06 F-150 4x4
The person who said "Money Can't Buy Happiness" probably didn't have any money.... Just Sayin.
furiouslyfaster07 is offline
