Dyno runs with stock speed limiter - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-31-2013, 08:04 PM   #1
Laminar
Laminar's Avatar
Fan#: 81298
What I Drive: 2013 SE
Points 475, Level 9
Points: 475, Level: 9 Points: 475, Level: 9 Points: 475, Level: 9
Level Up 50% Completed
FF Reputation: 2 Laminar Good Standing Member
I believe that a stock 5-speed car will hit the speed limiter in 4th gear before running out of revs. When doing dyno runs on a car with the speed limiter still in place, would you run in 3rd gear to ensure data collection from the entire rev range?
Laminar is offline
Old 08-31-2013, 09:08 PM   #2
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,231, Level 35
Points: 3,231, Level: 35 Points: 3,231, Level: 35 Points: 3,231, Level: 35
Level Up 21% Completed
FF Reputation: 2 Slo86GT Good Standing Member
3rd has been the usual choice.
The only difference is slightly lower whp number due to not being direct drive, and a bit more mechanical advantage also lowering figures slightly.
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 09-01-2013, 02:17 PM   #3
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2014 Fiesta ST
Points 41,392, Level 100
Points: 41,392, Level: 100 Points: 41,392, Level: 100 Points: 41,392, Level: 100
Level Up 0% Completed
FF Reputation: 2 _RED_ Good Standing Member
Before my tune all my dyno runs happened in 3rd gear.
Sent from my Galaxy S4
'14 Fiesta ST
234 HP / 274 TQ
SCT Tune & Injen Intake, Borla Catback
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is online now
Old 09-01-2013, 08:30 PM   #4
Laminar
Laminar's Avatar
Fan#: 81298
Points 475, Level 9
I'm not aware of any FWD transaxles that have a "direct drive." That happens in a RWD transmission when the input shaft goes straight to the output shaft skipping the countershaft, usually in 4th gear. The T5 does this:
The MTX75 has no countershaft, just input and output. No matter which gear you select, power is transferred from through both shafts to the differential.
Assuming that the dyno isn't using a static RPM-to-wheel speed ratio, this isn't true. A Dynojet will measure the power produced, then use RPM and wheel speed to back calculate engine torque. Differences in dyno results between gears can usually be explained by picking static ratios, inertia of the transmission's gears, or heatsoak.
Laminar is offline
Old 09-02-2013, 02:17 PM   #5
Slo86GT
Slo86GT's Avatar
Fan#: 88885
Heatsoak would cause higher gear's numbers to be lower. So that works against the known rise in power in lower ratio'd gearing on a dyno.
Inertia of transmission's gears wouldn't cause over 2% difference in readings common to 3rd vs 4th gear pulls.
Picking static ratios? You'll have to explain this one to me. Do you mean in the software configuration for calculations, or selecting which gear to dyno in? Isn't that the whole question here?
I will agree many transmission don't have a direct drive, or a 1:1 ratio, which will always show more power than using mechanical advantage through the system.
- Jody -
Slo86GT is offline
Old 09-02-2013, 08:53 PM   #6
Laminar
Laminar's Avatar
Fan#: 81298
Points 475, Level 9
Not just during the run but between runs.
If a dyno doesn't use a direct RPM pickup, the dyno operator can input a wheel speed to RPM ratio and let the dyno back calculate engine RPM. This introduces error.
This post and your previous post confused me. In what gear do you expect more power?
Laminar is offline
Old 09-02-2013, 09:31 PM   #7
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,268, Level 67
Points: 10,268, Level: 67 Points: 10,268, Level: 67 Points: 10,268, Level: 67
Level Up 55% Completed
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
FF Reputation: 26 suss6052 Great Standing Member
The manual should be dynoed in 4th gear as this is a gear ratio of 1.03:1, or the closest ratio to 1:1 on the straight 3.82:1 axle ratio.
The DCT is a bit trickier due to the split final drive, because 4th gear is 1.02:1, but it's on the 4.28:1 axle ratio where as 5th is 0.87:1 on the 3.85:1 axle ratio.
The MMT6 in the ST has a similar dilemma as 1-4 are on the 4.063:1 axle ratio vs 5 and 6 on the 2.955 axle ratio. 4th is 1.029:1 x 4.063:1, but 5th is 1.129:1 x 2.955:1.
So without entering the specific ratios or at least an engine speed vs road speed relationship it's much trickier to dyno a DCT or ST.
suss6052 is online now
Old 09-03-2013, 06:47 AM   #8
Laminar
Laminar's Avatar
Fan#: 81298
Points 475, Level 9
Why does that matter?
Laminar is offline
Old 09-03-2013, 10:29 AM   #9
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 42%
For accuracy you want to minimize the effect of gearing on the power results, and fourth gear is the closest the mtx75 gets to this ratio. There is also a greater frictional loss in gears with a higher torque multiplication such as a shorter gear.
Old 09-03-2013, 04:36 PM   #10
Slo86GT
Slo86GT's Avatar
Fan#: 88885
^^ Which is what I was getting at from the beginning.
- Jody -
Slo86GT is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
