is there a writeup for xcal2 firewire? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-31-2013, 06:11 PM   #1
BoostedFord
BoostedFord's Avatar
Fan#: 95085
What I Drive: 2002 Silver ZX3
Points 2,719, Level 31
Points: 2,719, Level: 31 Points: 2,719, Level: 31 Points: 2,719, Level: 31
Level Up 80% Completed
FF Reputation: 2 BoostedFord Good Standing Member
im looking but cant find it i have a 9pin cable and a xcal to i want to wire into the AEM but i cant figure out how and i dont wanna mess soemthing up doing it wrong no clue were to start?????
Focus Revolution
Boosted Zx3 @ 20psi spinnin 327whp
"cant find em grind em"
BoostedFord is offline
Old 08-31-2013, 06:25 PM   #2
kwg2371
kwg2371's Avatar
Fan#: 82857
What I Drive: 03 screming yellow SVT #1841
Points 3,827, Level 39
Points: 3,827, Level: 39 Points: 3,827, Level: 39 Points: 3,827, Level: 39
Level Up 18% Completed
FF Reputation: 3 kwg2371 Good Standing Member
yup http://www.focusfanatics.com/forum/showthread.php?t=202640
HatchNation #36
FF 13 best audio
FF 13 3rd place best in class SVT
FFW 13 best focus
FFW 13-14 best in class SVT
kwg2371 is offline
Old 08-31-2013, 07:11 PM   #3
BoostedFord
Fan#: 95085
cant connect with ecu :(
Focus Revolution
Old 08-31-2013, 08:45 PM   #4
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
Points 2,468, Level 30
Points: 2,468, Level: 30 Points: 2,468, Level: 30 Points: 2,468, Level: 30
Level Up 12% Completed
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
I get that error message when 1) the key isn't on or 2) the xcal isn't plugged into the OBDII port
If you're using the 9 pin DIN:
Cut one end off of the 9 pin cable
Plug the xcal2 into the OBDII port
Plug the other end into the top of the xcal2
Using a volt meter, find the 2 wires (on the end you cut) that read between 0-5v. Either of those should work
Connect one of those to the white wire on the AEM
Ground to a clean grounding point
In your software you should now be connected to either analog 1 or 2, depending on which 9pin wire you used.
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
