Simple Focus Mk3 audio upgrade - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-11-2013, 01:37 PM   #41
vampirefish
vampirefish's Avatar
Fan#: 80519
What I Drive: 2013 Silver Focus SE HB 5spd
FF Reputation: 1 vampirefish Good Standing Member
This is a great post! I'm going to start with speakers first then an amp...
2013 Ford Focus SE 5spd HB
vampirefish is offline
Old 11-11-2013, 10:13 PM   #42
2kwik4u
Fan#: 102523
What I Drive: '12-Sonic Blue-5dr/5spd/203A/Roof
FF Reputation: 1 2kwik4u Good Standing Member
Originally Posted by mavic View Post
heres a few pics of the gear i received so far,
still waiting on the alpine power pack, monoblock amp
and 6 channel rca line converter
That's a nice looking enclosure. Do you have a part number for that? I like that setup, and have a feeling it will be less expensive than having one built to my specs, or building my own.
2kwik4u is offline
Old 11-11-2013, 10:56 PM   #43
mavic
mavic's Avatar
Fan#: 120115
What I Drive: 2012 ford focus SEL white 5sp M
Points 619, Level 12
Points: 619, Level: 12 Points: 619, Level: 12 Points: 619, Level: 12
Level Up 38% Completed
Forum Activity 2%
FF Reputation: 1 mavic Good Standing Member
http://www.sonicelectronix.com/item_...TS-SWX251.html
enclosure loaded with the sub
http://www.sonicelectronix.com/item_...-TS-SW251.html
sub 200watts rms
http://www.sonicelectronix.com/item_...-SW2501S4.html
sub 300 watts rms
http://www.sonicelectronix.com/item_...UD-SW100D.html
sub box
http://www.pioneerelectronics.com/PU...lles/UD-SW100D
sub box specs
mavic is offline
Old 11-11-2013, 10:57 PM   #44
mavic
mavic's Avatar
Fan#: 120115
Forum Activity 2%
the box is volume is only .35 cubic feet
make sure you get a sub that works with that, or just use the pioneer shallow mount subs
mavic is offline
Old 11-11-2013, 11:14 PM   #45
mavic
mavic's Avatar
Fan#: 120115
Forum Activity 2%
here's a sub that could work
http://www.sonicelectronix.com/item_...SearchClickout[query_id]=6869988&SearchClickout[Ignore]=1
but it's minimum volume is 0.4 cubic feet, slightly over that the pioneer's call for
mavic is offline
Old 12-29-2013, 09:24 PM   #46
ospreyfe55
Fan#: 114283
What I Drive: 2013 Tuxedo Black Focus SE
FF Reputation: 1 ospreyfe55 Good Standing Member
I have been reading up on this thread and have booked marked it so I can go back and read up on this install. I will doing this soon but wanted to ask about where to tap in signal for the sub/amp setup in the trunk. I haven't quite decided on door speakers but I will be using the Alpine KTP-445U Amp and Parrot harness adapter. I have looked into getting the LCI2 for the rear sub output but where should I tap into the rear speakers for the input into the LCI2. Should I tapped into them directly out of the HU or after the in indash Alpine amp? Also I know that there is some mixed opinions on this but I currently have a Rockford Fosgate Amp that has a high level speaker input. Could I just use that instead of spending the cash on the LCI2. I also have been told that the Focus tends to lower the bass output the higher the volume level so apparently the LCI2 adjust the bass level. Also as far as my sub set up I will only be installing 1 Kicker L5S10 sub.
ospreyfe55 is offline
Old 12-29-2013, 11:05 PM   #47
Lite12
Lite12's Avatar
Fan#: 118069
What I Drive: 2013 Race Red Focus SE 5dr
Points 118, Level 2
Points: 118, Level: 2 Points: 118, Level: 2 Points: 118, Level: 2
Level Up 36% Completed
FF Reputation: 1 Lite12 Good Standing Member
As it stands with the Alpine 445U, Parrot harness, Alpine PLT-5 powered sub & stock door speakers I'm quite happy. Will surely improve once I get the door speakers replaced. I have the LCI2 tapped after the 445 amp and it's nice that the bass don't fade out past the 18 mark on the HU vol level.
2013 SE 5dr w/sport appearance, race red, 5mt
Amber LED frt markers, LED backups
Lite12 is offline
Old 12-29-2013, 11:08 PM   #48
ItsMcCoy
ItsMcCoy's Avatar
Fan#: 116137
What I Drive: '07 Focus ST DSG SAP
Points 1,391, Level 20
Points: 1,391, Level: 20 Points: 1,391, Level: 20 Points: 1,391, Level: 20
Level Up 91% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
FF Reputation: 1 ItsMcCoy Good Standing Member
I like it All these new vehicles do not have just a simple head unit surrounded by a bezel anymore. It awesome you kept the factory look with such an improvement!
ItsMcCoy is offline
Old 12-29-2013, 11:22 PM   #49
ospreyfe55
Fan#: 114283
Thanks Lite12! So you ended up wiring in the LC2I after the alpine indash amp? Did you tap off the rear speaker outputs out of that amp? Or did you tap in the rear door area? Im still not sure if ishould use the LC2I or the high level inputs on my amp. But I think the sound would be better with the LC2I.
Old 12-30-2013, 12:03 AM   #50
Lite12
Lite12's Avatar
Fan#: 118069
Points 118, Level 2
I just split the output of the dash amp with a set of crimp on connects (prewired) for later use(that I have now used) to run to the sub amp. I just ran the wires from the HU/dash amp along the door sills while I was running the amp wiring to the rear.
Lite12 is offline
