Simple Focus Mk3 audio upgrade - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-15-2013, 09:00 PM   #31
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2013 Tuxedo Black Focus SE Hatch
Points 548, Level 10
Points: 548, Level: 10 Points: 548, Level: 10 Points: 548, Level: 10
Level Up 96% Completed
FF Reputation: 3 MetalMuffins Good Standing Member
Originally Posted by DoogieB View Post
The amp runs cooler than the HU directly above it. The amp has it's own internal fuse and is also fused with the HU through the wiring harness. Ask your "pro" why he thinks this is a problem.
Good, that's what I wanted to hear. I didn't think it would be a problem, and I walked out after he told me he had been installing car stereo's for 20 years, and the ford system was A) completely UN-upgradable and B) already sounds GREAT
Needless to say I won't be seeing my "pro" anytime soon
2013 HB MTX, Tux Black w/ Black Pack - Steeda RSB, Snorkel DLT, K&N Drop in, E-Focus RMM, Redline Tuning Hood Struts, Custom Al. Skid-plate, 180 Stat, Custom SCT Tune by Tom @ Focus-Power
MetalMuffins is online now
Old 10-19-2013, 05:52 PM   #32
mwalt2
Fan#: 118464
What I Drive: 2013 Silver SE Hatch
Points 373, Level 7
Points: 373, Level: 7 Points: 373, Level: 7 Points: 373, Level: 7
Level Up 46% Completed
FF Reputation: 1 mwalt2 Good Standing Member
Search for "FOR-11CK" on Ebay.
Thanks for the suggestion on what to search for on ebay. I am planning on doing a similar install in my Focus and your thread will be great help. Where did you attach the remote wire for your amp?
mwalt2 is offline
Old 10-19-2013, 08:00 PM   #33
wylee
Fan#: 116984
What I Drive: 2013 ST1
FF Reputation: 1 wylee Good Standing Member
If you're going to use the little Alpine amp, it turns on automatically by sensing the high signal input. What should've been the remote wire in the Parrot harness did not work for me. I'm using the GTO of the LC2i for my sub amp.
wylee is offline
Old 10-19-2013, 08:03 PM   #34
wylee
Fan#: 116984
Originally Posted by fanoftheliving View Post
I have a question about the Parrot harness. Does it provide power to the alpine amp, or did you have to run a separate wire to the fuse box? Thanks a lot.
That depends on who you ask; I ran a separate line from the battery.
wylee is offline
Old 10-20-2013, 07:34 PM   #35
Lite12
Lite12's Avatar
Fan#: 118069
What I Drive: 2013 Race Red Focus SE 5dr
Points 131, Level 2
Points: 131, Level: 2 Points: 131, Level: 2 Points: 131, Level: 2
Level Up 62% Completed
FF Reputation: 1 Lite12 Good Standing Member
Step one done (Alpine amp installed), Freaking awesome!
Parrot harness, no turn on wire, stock HU power source, Hi pass set @80Hz.
Hope the stock speakers last till I can put in my replacements
In original stock form the bass seemed to cut out at about 18 so I set the gains just a few degrees above min and it's plenty loud, I may notch it up a bit after I replace the stock speakers but for now it's a HUGE upgrade.
Next chance I will wire up my powered alpine sub, then swop out stock door speakers.
VERY happy with the added power right now though!
2013 SE 5dr w/sport appearance, race red, 5mt
Amber LED frt markers, LED backups
Lite12 is offline
Old 10-21-2013, 04:34 PM   #36
DoogieB
DoogieB's Avatar
Fan#: 101748
What I Drive: 2012 Red Candy SE Sport
Points 1,000, Level 16
Points: 1,000, Level: 16 Points: 1,000, Level: 16 Points: 1,000, Level: 16
Level Up 50% Completed
FF Reputation: 2 DoogieB Good Standing Member
I've been powering the KTP-445U through the HU harness since the end of August without a problem. You can clearly see the wiring in the one picture.
Pin 2 in the big plug of the harness is "Power antenna" and what you want to use for a remote (blue) wire. It's marked if you look inside the socket and in the Parrot harness it's the orange/black wire.
Just finished the sub install this weekend and I had to tap that wire and send it through the KTP-445U so the sub amp would trigger on and off.
DoogieB is offline
Old 10-26-2013, 08:38 PM   #37
mwalt2
Fan#: 118464
Points 373, Level 7
Thanks. I tapped that wire in the parrot harness and it works great for remote turn on.
mwalt2 is offline
Old 11-10-2013, 07:10 PM   #38
mavic
mavic's Avatar
Fan#: 120115
What I Drive: 2012 ford focus SEL white 5sp M
Points 619, Level 12
Points: 619, Level: 12 Points: 619, Level: 12 Points: 619, Level: 12
Level Up 38% Completed
Forum Activity 2%
FF Reputation: 1 mavic Good Standing Member
My setup is just about finished, and almost identical to yours:
Car: 2012 Ford Focus SEL w/6 speakers
what I currently have ( but not installed/ waiting to be installed)
Subwoofer:
Pioneer TS-SWX251 10" 4-ohm (200w rms 800w peak)
AMP: Boss Audio CER1200M 375w rms @ 4 ohms
Speakers:
Front: kenwood kfc-p709ps 6.5" components ( 80w rms, 280w peak)
Rear: JL Audio C2-525X 5.25" 2 way coaxial ( 60w rms, 225w peak)
AMP: alpine power pack ktp-445u 45w rms x4
i'll be adding either an Audiocontrol LC6i (150$) or MOBILESPEC ms-6ch (lc6i knockoff for 50$)
mavic is offline
Old 11-10-2013, 07:34 PM   #39
mavic
mavic's Avatar
Fan#: 120115
Forum Activity 2%
heres a few pics of the gear i received so far,
still waiting on the alpine power pack, monoblock amp
and 6 channel rca line converter
mavic is offline
Old 11-10-2013, 07:37 PM   #40
mavic
mavic's Avatar
Fan#: 120115
Forum Activity 2%
if your looking to maximize your trunk space i highly recommend this sub enclosure, or the MTX equivalent, if 200 watts RMS isn't enough for you , pioneer makes a direct drop in replacement shallow mount that's 300 watts RMS
http://www.pioneerelectronics.ca/POC...nt/TS-SW2501S4
mavic is offline
