Turbo oil feed line - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Forced Induction
Old 08-31-2013, 12:22 AM   #1
emgrock1
Fan#: 74349
What I Drive: 2002 Infa-red SVT focus
FF Reputation: 1 emgrock1 Good Standing Member
Turbo oil feed line
Some questions about the oil feed. I'm running a mitsu teo4h turbo and have the oil feed line off the plug next to the coil. What sort of restrictor should I use if any? I've been hearing a lot about -3 but I have no idea what that really means. Any help would be appreciated.
emgrock1 is offline
Old 08-31-2013, 12:24 AM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 49,779, Level 100
Points: 49,779, Level: 100 Points: 49,779, Level: 100 Points: 49,779, Level: 100
Level Up 0% Completed
Forum Activity 13%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
if tis journal bearing turbo u need.065
FF MODERATOR
RISE AGAIN EGGYOLK130 WHP 124 WTQ ZETEC CREW #271
RIFF CREW
TURBO DYNO COMING SOON
ZXthrizzle05 is offline
Old 08-31-2013, 12:40 AM   #3
emgrock1
Fan#: 74349
Its a journal bearing turbo. Any suggestions on where to buy said fitting?
emgrock1 is offline
Old 09-06-2013, 02:17 PM   #4
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 898, Level 15
Points: 898, Level: 15 Points: 898, Level: 15 Points: 898, Level: 15
Level Up 98% Completed
FF Reputation: 3 forddorf Good Standing Member
-3 is the size of the line. According to comp turbos, using a -3 line doesn't require a restrictor with a journal bearing turbo. Other companies may be different. I ran a comp turbo with a -3 feed line with no restrictor had no problems.
forddorf is offline
Old 09-06-2013, 02:20 PM   #5
forddorf
Fan#: 31248
Atpturbo sells restrictors etc.
forddorf is offline
Old 09-06-2013, 02:31 PM   #6
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 13%
ATP is where I got mine from and Idc if they say do or don't I run mine so it doesn't blow through seals
FF MODERATOR
RIFF CREW
Old 09-06-2013, 02:54 PM   #7
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: Miata, STi, GSXR1k
Points 20,500, Level 90
Points: 20,500, Level: 90 Points: 20,500, Level: 90 Points: 20,500, Level: 90
Level Up 30% Completed
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
if you are running a restrictor and your turbo was designed to be ran with out one you will damage the bearings in the turbo from having to little oil pressure. precision turbos for example are designed with the proper restrictor built in and do not require one. like stated above most journal bearing turbo's with a -3an feed line do not require a restrictor.
since you are using a factory turbo i would look at the car the turbo came off of and if it doesnt use a restrictor then i wouldnt use one
Tim
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
