Oil Getting Past Compressor - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-01-2013, 12:02 PM   #11
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
no.....if you think about it oil is traveling from your feed set up aka the head or the oil press sending unit on the block then travels down into the turbo to lubricate the bearings wih then returns into the pan to start the cycle all over again right? well if its getting past your compressor and you ruled out the oil seals to the bearings themselves then my only non expertise opinion would be the restrictor is allowing far to much oil to go into the dbb turbo. btw do you have a oil pres gage set up carl?
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 09-01-2013, 02:15 PM   #12
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
I don't have an oil pressure gauge, Sean, but it's on my list. I've ordered a new oil return line and restrictor so I can check that block.
Tom, I sent you a datalog.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 09-05-2013, 11:36 AM   #13
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Originally Posted by 1turbofocus View Post
I wouldnt try a lighter oil you at 10-20 now , I would never run that low of any oil in a performance engine , I feel you should be at least a 30wt if not a 40 , I never run anything lower then a 50wt in mine
So, something like 10w-30 or 10w-40?
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 09-05-2013, 12:33 PM   #14
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,584, Level 100
Points: 52,584, Level: 100 Points: 52,584, Level: 100 Points: 52,584, Level: 100
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
Buy-Sell-Trade Rating: (28)
I would run a higher wt oil when running boost , I feel anything is better then 20wt , 30 or 40
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 09-07-2013, 02:41 PM   #15
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Ran a compression test. Tested each cylinder three times and took the average. Spark plugs were clean. Starting on the passenger side and working toward the driver's side, the compression readings were:
#1-144psi
#2-145psi
#3-148psi
#4-146psi
Are these numbers within normal limits?
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 09-07-2013, 06:22 PM   #16
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
stock duratec? whats the ratio of a stock duratec? with my built 9:1 zetec normal is in the 180 range
FF MODERATOR
RIFF CREW
Old 09-08-2013, 08:14 AM   #17
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Yes, stock internals. 10:1 ratio, if I remember correctly. Tom informed me that these are normal readings.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 09-18-2013, 05:21 PM   #18
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Well, ladies and gents, after all the troubleshooting I've done on the GoKart, the oil issue is finally resolved. Got her fixed. Sadly, though, with all of the troubleshooting I've done, the last thing I did was replace the gaskets on the inlet manifold and throttle body. I should have done that WAAAAAAYYYY earlier.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 09-18-2013, 06:28 PM   #19
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
ouch! I got a y2k manifold yesterday and I am DEFINATELY putting new gaskets in there before I stuff her back there for good
FF MODERATOR
RIFF CREW
Old 09-18-2013, 07:23 PM   #20
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
I'm highly recommending it. LOL.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
