Tire Pressure Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-29-2013, 12:04 PM   #1
tmumolo
tmumolo's Avatar
Fan#: 117776
What I Drive: 2012 Ford Focus Se
Points 1,990, Level 26
Points: 1,990, Level: 26 Points: 1,990, Level: 26 Points: 1,990, Level: 26
Level Up 90% Completed
FF Reputation: 1 tmumolo Good Standing Member
Just got a 2012 Ford Focus SE Hatch dual clutch auto; (yes I love it) Ford recommends 35psi cold tire pressure which seems a little stiff. 98 percent of the time I drive alone so there is never much weight in the car. Does anyone run tire pressure different than recommended. I'm thinking 34 instead of 35psi; Obviously steering and handling is a bit crisper at 35psi but the ride is not as smooth.
Any thoughts would be appreciated.
tony
tmumolo is offline
Old 08-29-2013, 12:49 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,357, Level 77
Points: 14,357, Level: 77 Points: 14,357, Level: 77 Points: 14,357, Level: 77
Level Up 77% Completed
Forum Activity 19%
FF Reputation: 15 Elizabeth Great Standing Member
I have 39/40 rear, and 45/46 front.
I like my tires to be inflated.
Elizabeth is offline
Old 08-29-2013, 03:20 PM   #3
tmumolo
tmumolo's Avatar
Fan#: 117776
After some experimenting I decided 35psi as per Ford's recommendation provides the best overall performance. Inflating the tire 10 psi over what's recommended by Ford is, I believe, verging on over inflating the tires which is not good either.
That being said; under inflation is worse.
tmumolo is offline
Old 08-29-2013, 03:41 PM   #4
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,304, Level 95
Points: 25,304, Level: 95 Points: 25,304, Level: 95 Points: 25,304, Level: 95
Level Up 96% Completed
Forum Activity 7%
Oh sweet, another tire pressure thread! Everybody draw your swords!!!
I run 42/39, f/r
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 08-29-2013, 04:05 PM   #5
joecicalese
Fan#: 105573
What I Drive: 2001 Black ZTS
Points 1,221, Level 19
Points: 1,221, Level: 19 Points: 1,221, Level: 19 Points: 1,221, Level: 19
Level Up 21% Completed
FF Reputation: 4 joecicalese Good Standing Member
I run 42/39, f/r
Ditto. I ran the opposite when I had a rear wheel drive car.
joecicalese is offline
Old 08-29-2013, 06:44 PM   #6
Arizona
Arizona's Avatar
Fan#: 104429
What I Drive: SE Sport, MT & Lotus Europa TC
Points 738, Level 14
Points: 738, Level: 14 Points: 738, Level: 14 Points: 738, Level: 14
Level Up 38% Completed
FF Reputation: 7 Arizona Good Standing Member
Could be worse; could be an oil change interval thread. I'm in the overinflation camp.
Arizona is offline
Old 08-29-2013, 09:12 PM   #7
Browningguy
Fan#: 94520
What I Drive: 2003 Red ZX3
FF Reputation: 1 Browningguy Good Standing Member
As everyone has mentioned the ford recommendation is a good compromise of handling and ride comfort. In my opinion under inflation is a bigger problem than over inflation though. I'm more into handling so I'm higher than recommended, 38/36 in the 2013 and 42/36 in my ZX3.
Browningguy is offline
Old 08-29-2013, 09:25 PM   #8
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Forum Activity 19%
Yeah the handling is where higher pressures help. If all you want it to get to work, then stock is fine. In fact one pound down is not problem is all you want is comfort.
I like to be able to go around corners with NO body lean..
So high pressures really help to corner at much faster speeds and feel good doing it.
If you drive like you grandma in her Buick, then none of that matters.
Old 08-29-2013, 10:00 PM   #9
Arizona
Arizona's Avatar
Fan#: 104429
Yep, but if you drive like grandpa in his Lotus (I do) THEN it matters.
Arizona is offline
Old 08-30-2013, 03:50 PM   #10
wheelstudio
FF Affiliate
wheelstudio's Avatar
Fan#: 116213
What I Drive: 2013 Lexus CT200h
Points 3,143, Level 34
Points: 3,143, Level: 34 Points: 3,143, Level: 34 Points: 3,143, Level: 34
Level Up 62% Completed
Forum Activity 4%
FF Reputation: 1 wheelstudio Good Standing Member
tony
Run what you like. 1-3psi isn't a huge difference in terms of daily driving. You may loose 1-2mpg, if anything, but if the comfort is worth it then go for it.
Also, in theory, tire wear is slightly accelerated. But keep in mind tire pressure fluctuate regardless within 1-4 psi from driving and the tires heating up.
Your OFFICIAL Focus Aftermarket Wheel Experts
Avant Garde | Klutch| TSW
Questions? chat now or (562) 219 2525
Facebook
Jason@GetYourWheels.com
wheelstudio is offline
