I really need help here!! No compression. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-27-2013, 08:32 PM   #1
dcraig1000
Fan#: 118290
What I Drive: 2003 orange svt 2.0 dohc
FF Reputation: 1 dcraig1000 Good Standing Member
Question I really need help here!! No compression.
Ok, heres the story. 2003 svt 2.0 DOHC. All I did this time was replace the ac compressor, rear motor mount, serpentine belt and front passenger steering knuckle. On the way back from the shop, the car died. I pulled over. the new serpentine belt shredded. why? no idea. the car wouldnt start. sounded like the timing belt snapped, just a zzzzzzzzzzz noise. had it towed back to the shop, let it sit overnight. back to the shop the next morning, jumped in the car, went to start it, and BOOM!! the intake manifold blew off the head(fuel sitting on the chamber all night). so i put the intake manifold back on, repaired the broken vac lines and tried to retime the engine. after several attempts at getting the timing set, and the car still not even attempting to turn over(pistons are moving up and down, crank is turning, cams are turning) just the same old zzzzzzzzzzzzzzz sound. did a compression test. NO compression on any cylinder!!! am I not doing something right? do i have bent valves? car did not make any noise before dying. thanks for your help.
dcraig1000 is offline
Old 08-27-2013, 09:40 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
If the belt shredded how hot did it get ?
pull the valve cover and check valve gap if you bent valves the gap will be hugh as you should be close to .012 if bent you will have .200+
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-27-2013, 09:47 PM   #3
dcraig1000
Fan#: 118290
didnt get hot at all. as soon as the serp belt shredded, i pulled over. belt was still on. dont have any idea how it shredded. will check gaps tomorrow...thanks
Old 08-27-2013, 09:52 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,442, Level 100
Points: 138,442, Level: 100 Points: 138,442, Level: 100 Points: 138,442, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (11)
Moved to the Technical Chat area
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 08-27-2013, 10:11 PM   #5
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
Back fires so bad it blows the intake manifold off. No compression. To me it seems the timing is seriously off and may have serious mechanical damage. I would bore scope or just pull the head.
Milton is offline
Old 08-27-2013, 11:17 PM   #6
Bozok
Bozok's Avatar
Fan#: 118216
What I Drive: 2000 Black ZX3
Points 114, Level 2
Points: 114, Level: 2 Points: 114, Level: 2 Points: 114, Level: 2
Level Up 28% Completed
FF Reputation: 3 Bozok Good Standing Member
My guess at why the serpentine belt shred has to do with replacing the AC compressor. If the compressor was replaced, you probably had the AC recharged too? Maybe if it was overfilled, or maybe if not enough oil got in with the refrigerant, the compressor might have locked up. If it did, that would explain the shredded serpentine belt. As far as the rest of it, I'd agree with what everyone else said about timing.
Bozok is offline
Old 08-27-2013, 11:37 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
The SVT is well known that why cranking it back fires and blows off the intake manifold
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-28-2013, 12:22 AM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
Yup, not the first SVT intake blowing off we've seen on here, that's for sure.
Moderator for
Technical Chat
Old 08-28-2013, 10:41 AM   #9
dcraig1000
Fan#: 118290
can i have the timing 180 out? if so how can i tell?
Old 08-28-2013, 12:23 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
Blowing off the intake has nothing to do with cam or ignition timing
Did you check the valve clearances yet ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
