How to Clean the engine - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Auto Washing, Detailing & Paint Protection
Auto Washing, Detailing & Paint Protection Discuss wax, polish, chamois, microfiber towels, simple cloth towel, scratch repair and paint protection. Use this Forum to discuss your cleaning tricks and techniques.
Old 08-26-2013, 04:19 PM   #1
mightykeys
Fan#: 117182
What I Drive: 2012 Grey Ford Focus SE
Points 488, Level 9
Points: 488, Level: 9 Points: 488, Level: 9 Points: 488, Level: 9
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 mightykeys Good Standing Member
does anyone know how to clean the engine?
just simply a power washer?
kind of dirty
Last edited by mightykeys; 08-26-2013 at 04:39 PM. Reason: not what i wanted to post
mightykeys is offline
Old 08-26-2013, 05:02 PM   #2
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
There's an "Auto Washing, Detailing & Paint Protection" forum on this site that will serve you well for that type of information.
Hatch Nation #90
TboneZX3 is offline
Old 08-26-2013, 06:27 PM   #3
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,018, Level 96
Points: 26,018, Level: 96 Points: 26,018, Level: 96 Points: 26,018, Level: 96
Level Up 67% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Moved to Auto Washing, Detailing & Paint Protection.
Fwiw, I simply use a mixture of Simple Green and water along with assorted brushes to get nooks and crannies. It is preferable to do it at home while the engine is cold. If you take it to a car wash, then you need to leave your engine running during the wash and use low pressure. If I'm at the car wash I will hit it with the pre-soak, wheel cleaner, and then the rinse without using full pressure. Try to avoid spraying your fuse box and alternator, and keep it light around the spark plugs. Rinse, rinse, rinse, because Simple Green and associated chemicals are usually corrosive.
Ensure that you leave your car running-I cannot stress this enough. That will assist in keeping the engine at a normal temperature while spraying it and avoid possible issues of rapidly cooling the heat-soaked aluminum.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 09-12-2013, 11:11 AM   #4
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
This is my engine bay that FSWerks uses as their picture to show the engine cover. I cover the electrical components with aluminum foil and spray the rest of the engine bay with a medium pressure flow. You can use a designated engine bay cleaner to break loose dirt and use brushes to agitate it. DO NOT USE SIMPLE GREEN!! It will cause aluminum to oxidize and corrode over time. After you rinse the engine bay very well to remove all soap or cleaners let it dry completely and totally. I then use Sonus Engine kote let it dry for 20 minutes then use another coat of it. This is a great product and actually repels dirt and dust and keeps the engine bay clean so washing it less often still maintains awesomeness(=
Hope this helps!
Galatians 6:14
crice8 is offline
Old 09-12-2013, 11:14 AM   #5
crice8
crice8's Avatar
Fan#: 84830
Here is a link to to Sonus Engine kote:
http://www.autogeek.net/sonus-trim-motor-kote.html
Galatians 6:14
crice8 is offline
