E85/N2O Gulping 13:1 compression Crazy NA Build - Page 25 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-13-2014, 02:54 AM   #241
UltegraSTI
UltegraSTI's Avatar
Fan#: 466
What I Drive: 2001 Yellow Honey
Points 1,612, Level 23
Points: 1,612, Level: 23 Points: 1,612, Level: 23 Points: 1,612, Level: 23
Level Up 12% Completed
FF Reputation: 1 UltegraSTI Good Standing Member
Wonder if any1 ever did convert an svtf to a 5spd. Maybe this explains ur slow 1/4mi ?? Get ur box sorted and install diff with the box out. Good luck. R
2001 EggYolk Yellow Focus
14.90 @90.24mph
Best Trap: 91.75mph
2014 Cloud 9 White Focus ST
UltegraSTI is offline
Old 05-13-2014, 11:04 AM   #242
blk00gtvert
Fan#: 76622
What I Drive: 2003 White ZX5,2004 Red SVT Focus
Points 2,032, Level 27
Points: 2,032, Level: 27 Points: 2,032, Level: 27 Points: 2,032, Level: 27
Level Up 22% Completed
FF Reputation: 2 blk00gtvert Good Standing Member
i would think it wouldn't really be that hard other than i guee the tooth count for the crank senor would be different. so you would have to have a mtx clutch and flywheel but with a svt trigger wheel on it. other than that i would think it would bolt in...
2003 SVT focus, forged rods,forged Je pistons, 13:1 compression, E85, ported head,vct delete,sheet metal intake,custom direct port nitrous (150jetting) 170whp on motor spray tba: )
14.97@94 NA so far.
blk00gtvert is offline
Old 05-15-2014, 04:47 PM   #243
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,337, Level 29
Points: 2,337, Level: 29 Points: 2,337, Level: 29 Points: 2,337, Level: 29
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 6%
FF Reputation: 3 Juicedz Good Standing Member
So what became of the clutch situation with Spec?
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 05-17-2014, 04:03 PM   #244
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
ive always disliked spec clutches
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 05-18-2014, 03:22 PM   #245
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
Me and him are running about the same 1/4 times and trap speeds. So I'd say it's not a trans issue. More one the grip side of the equation. I can't get a good 60' or 330' to save my life. 1st is just wheel spin so I have to peddle or limit it. And no matter what I do, spin or limit, my time comes out pretty close to the same.
Tooth count is the same. Actually the CPS is the same.
Nearest I can tell, there's maybe some wiring differences, the axles and the shift cables. Other than that it should be a straight forward swap.
Maybe the Pilot Bearing is different, but I doubt it.
OH, you're not playing dumb ...
iminhell is offline
Old 05-18-2014, 04:44 PM   #246
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
I know some use SVT blocks in their ZX3 and is all the same but for the oil squirters and of course rods and pistons.
What you guys need is LSD, slicks and stiffer suspension.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is online now
Old 05-18-2014, 04:52 PM   #247
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
Check, need, and check.
Still the same thing. SO it's tires more than anything I'd say.
You're launch is a different case than most turbo guys, but you have to keep in mind that the throttle response of my car is better than a turbo car. I don't have any wait time. It's spin right now at any RPM vs spin once boost hits, so keep boost low.
I'm sure you've driven cars with decent N/A power and can relate.
Problem with more grip is there is also greater rolling resistance. My 60' might come down a lot, but my time and MPH might not follow if the tires are sucking lots of power on the big end. Right now the MPH is my only saving grace.
iminhell is offline
Old 05-18-2014, 06:18 PM   #248
gun_runner
gun_runner's Avatar
Fan#: 91693
What I Drive: 2000, Dirt Metallic, Kona ZX3
Points 1,959, Level 26
Points: 1,959, Level: 26 Points: 1,959, Level: 26 Points: 1,959, Level: 26
Forum Activity 3%
FF Reputation: 1 gun_runner Good Standing Member
Just something to consider. Aluminum flywheels are generally a very bad choice for a drag race car. With a steel flywheel, you have much better retained momentum, which means you can launch with lower rpms, and not lose as much traction. This is very important on low displacement engines.
Weight savings are important everywhere inside the engine as it will reduce drag, and reduce momentum of moving parts which makes a world of difference on part wear. BUT this is the exact opposite effect that you want on the flywheel. Many drag race cars often use a heavier than stock flywheel to keep more momentum on the roll out.
I've seen some if the top posted times on here and the other board, and to be honest, for the hp these cars are putting down, the times are pretty slow, and I have noticed that a common factor between them is that they are running aluminum flywheels.
I am not alone on this opinion, my dad builds 400+ hp turbo dodges, and one guy wanted to convert his road race car to drag race. After switching to a stock heavy flywheel, he gained .4 seconds on the 60' and almost a second on the 1/4. It is the same general concept of why you don't shift at your peak power band, you spin past it to retain more momentum going into the next gear.
Hope I could help.
I can re-drill the hubs and rotors/drums on your mk1 or mk2 focus to accept 5x108 or 4x100 wheels for only $120!!! http://www.focusfanatics.com/forum/showthread.php?t=323550
gun_runner is offline
Old 05-18-2014, 06:43 PM   #249
gun_runner
gun_runner's Avatar
Fan#: 91693
Forum Activity 3%
Just because rolling resistance leeches power, don't think that is going to take away mph. In fact, with that much power, you are also probably losing traction throughout the gears, even if you don't notice it. The extra traction will pull you to a higher mph, much quicker and more efficiently. The max width of the slicks on our cars don't really allow for all that much rolling resistance anyways. That is more of a problem for the rwd guys that tub their car and put WAY too much tire for their engine. My dad used to be a street race legend around SoCal, and his biggest advantage was surprise. He knew the engineering behind weight distribution and traction, so he only ran an 8 1/2 wide slick on his 67 nova, yet would run mid 9s. That is how he got three five page articles in hot rod magazine, and two with his vega. Now he drives an 11.5 second 85 Dodge Omni that smogs (IN CALIFORNIA!!!!) and has full interior, a/c, cruise control, and stuff. That car made a five page article in "Sport Compact Car Magazine" where they named him King of Cheap Speed. Just look up "ugly old omni" on YouTube. It's mostly 1/8th mile runs though.
Sorry about the two rants, but I just want you to know that what I'm saying comes from very proven knowledge, and I'm tired of getting shot down on fwd car forums by people that are clueless or just book smart. I wish I could afford to build a car like yours, but for now, I'll just share my passed down knowledge.
Old 05-18-2014, 10:22 PM   #250
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
No offense taken in the least, and I never disregard experience based knowledge.
I do have a stock FW I can swap back to to test, although the work isn't something I look forward too. If the engine goes kaput, I surely will though.
But I do think you might be onto something. Conservation of Momentum should play a large roll with our cars.
iminhell is offline
