My 2009 focus is overheating. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 08-24-2013, 11:07 AM   #1
Siide
Fan#: 117412
What I Drive: 2009 Focus SE Black
FF Reputation: 1 Siide Good Standing Member
I checked the thermostat and its working, the fan sometimes kicks on but most of the time it does not.
I am out of ideas here. I have checked the radiator as well just to make sure its not cracked.
Any idea why its doing this?
Siide is offline
Old 08-24-2013, 03:05 PM   #2
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 328, Level 6
Points: 328, Level: 6 Points: 328, Level: 6 Points: 328, Level: 6
Level Up 56% Completed
FF Reputation: 10 Milton Great Standing Member
Fan system not working properly
Water pump not working properly
Airflow to radiator blocked
Thermostat not working properly
Clogged coolant system
Radiator cap not working properly
Air in coolant system
Low coolant level
Milton is offline
Old 08-24-2013, 09:19 PM   #3
Siide
Fan#: 117412
Low coolant level
Thermostat is working properly.
Cooling fan sometimes kicks on, sometimes does not come on. (possible relay? )
Coolant is fine. Radiator cap is fine.
Siide is offline
Old 08-24-2013, 09:40 PM   #4
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
Bad headgasket ??
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 08-25-2013, 08:53 AM   #5
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 1 AllCarFan Good Standing Member
when you say overheating....describe it.
Is it hot....then you turn the car off and start it back up and it stays hot? Or do you turn it off, sit for about 10 seconds and the car is not hot? Have you burped your system?
how did you test your thermo? are you seeing water circulate if you remove your reservoir cap?
The most common (other than a bad thermo) issue that I have seen over the years is a small air bubble in the coolant that passes over the temp sensor giving a real, but false indication of overheating.
AllCarFan is offline
Old 08-25-2013, 02:31 PM   #6
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
When does it overheat? At idle or cruising down the road?
And how are you testing the t-stat? You are certain its opening?
jetrinka is offline
