Re-drilling hubs and rotors to 5x108 and 4x100 - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Deals > Group Buys & Hot Deals!
Group Buys & Hot Deals! This section is the place you'll find Hot Deals and Special Vendor Discounts offered by our Vendors and Approved Group Buy Sellers.
Old 10-14-2013, 09:51 PM   #21
Slw-Fo
Fan#: 119746
What I Drive: 2002 Maroon (need new paint) ZX3
FF Reputation: 1 Slw-Fo Good Standing Member
Originally Posted by gun_runner View Post
5x100 is the easiest to do and probably the strongest. As far as the 4 bolt patterns go, I'm not sure what I can do quite yet. I need to see the different hub center sizes
I would like more information on hub sizes as well before I make a final decision on which pattern to go with. If the hub size on the wheel is larger then the 63.4 on the Focus running a "Hub ring" won't be an issue, if it is smaller I'm not sure if I would be willing to subject my brand new wheels to a hub "boring" even if they were the cheapest wheels ever.
As far as my set up goes, the wheels I want would be 16x8 4x100 25ET with a 73.1 hub. Hub rings are easy to come by from 73.1 to 63.4. But if an easier solution can be found with the correct bore size on a 5x100 I may change my decision. If it is the strongest and most reliable pattern.
Slw-Fo is offline
Old 10-14-2013, 11:08 PM   #22
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,505, Level 100
Points: 35,505, Level: 100 Points: 35,505, Level: 100 Points: 35,505, Level: 100
Level Up 0% Completed
Forum Activity 6%
How the hell are you going to fit et25 on a focus?
TheGlassMaker is online now
Old 10-14-2013, 11:23 PM   #23
Slw-Fo
Fan#: 119746
Very carefully my friend...
Slw-Fo is offline
Old 10-15-2013, 08:56 AM   #24
gun_runner
gun_runner's Avatar
Fan#: 91693
What I Drive: 2000, Dirt Metallic, Kona ZX3
Points 1,959, Level 26
Points: 1,959, Level: 26 Points: 1,959, Level: 26 Points: 1,959, Level: 26
Level Up 59% Completed
Forum Activity 3%
FF Reputation: 1 gun_runner Good Standing Member
I made a mistake with what i was saying. The easiest pattern for me to drill is 5x108. To do 5x108, i can use an existing hole. Re-drilling in a different size five bolt pattern causes a lot of complications because i have to fill a hole with weld, and machine it flat. I have a drilling jig i made specially for doing that. Doing a 4x100 or 4x114.3 is no big deal, you just have to be sure that the hub bore in the wheels is the same, or larger than the hub bore on the focus (63.4mm). If it is larger, that is no biggie at all, hub rings are widely available.
Here is a nice guide to hub bores and bolt circle sizes
http://adaptitusa.com/referencebook.htm
I can re-drill the hubs and rotors/drums on your mk1 or mk2 focus to accept 5x108 or 4x100 wheels for only $120!!! http://www.focusfanatics.com/forum/showthread.php?t=323550
gun_runner is offline
Old 10-15-2013, 09:32 AM   #25
Slw-Fo
Fan#: 119746
That's a pretty decent guide man thanks for sharing that. So if I were to go to 4x100 like originally planned, There should be no issue with strength or reliability correct? Sorry for all the questions just not that familiar with redrilling the hubs and I've been looking for a way out of 4x108 land. Also are you offering any type of guarantee with this or is just "you get what you get"?
Slw-Fo is offline
Old 10-15-2013, 08:44 PM   #26
gun_runner
gun_runner's Avatar
Fan#: 91693
Forum Activity 3%
I'll replace or repair the hubs if they are done bad or if i mess them up.
There will be no strength issue with the second bolt pattern being drilled into the same hubs and brakes. My dad has been running the same set or redrilled hubs for about 10 years on his 400hp Dodge omni with no issue. Probably over 1000 drag launches on them, never had any issues. Check it out http://www.youtube.com/watch?v=AhmAp6kgI_0
Lastly, just remember that i can only do a 4x100 bolt pattern if your wheels have a hub bore of 63.4mm or larger.
Old 10-16-2013, 11:34 AM   #27
Slw-Fo
Fan#: 119746
PM ed
Slw-Fo is offline
Old 10-16-2013, 11:38 AM   #28
gun_runner
gun_runner's Avatar
Fan#: 91693
Forum Activity 3%
PM ed
Didn't get anything from you.
Old 10-16-2013, 12:11 PM   #29
Slw-Fo
Fan#: 119746
Should have it now. First one didn't send for some reason.
Slw-Fo is offline
Old 10-16-2013, 05:34 PM   #30
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,960, Level 79
Points: 14,960, Level: 79 Points: 14,960, Level: 79 Points: 14,960, Level: 79
Level Up 22% Completed
Forum Activity 11%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
damn i keep coming back to this thread. i tell myself no but i get drawn back anyway. 5x114.3 is what i would want to go with. mustang wheels would then fit along with STI and evo wheels. those wheels commonly come in 17x8/17x9 size out of the factory with offsets ranging between 35mm and 55mm. those would fit a focus very well. i would like to run some of the new ST wheels in 5x108 cause they are the right width and offset for me but they are 18s. and unfortunately im being a cheap bastard as much as possible and tires for those are much more pricey than for 17s.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
