Widebands.... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-21-2013, 06:38 PM   #11
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
Widebands....
Originally Posted by Basselisk View Post
well mixed replies heh, I suppouse its then just a matter of personal preference?
about the location, I have an ORP, iirc the wideband can be placed where the secondary O2 sensor was right? I got it removed because well... ORP...
or where should I place it?
I think putting it there should be a good spot. I have mine close to the first o2 sensor.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 08-21-2013, 08:43 PM   #12
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,597, Level 62
Points: 8,597, Level: 62 Points: 8,597, Level: 62 Points: 8,597, Level: 62
Level Up 49% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
IIRC You want it as close to where all the exhaust is collected as possible. But also read that about 1 meter from the exhaust valves is also a good rule of thumb. I think you may want it as close to the flange of the header as possible. But a few inches may not matter.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 08-21-2013, 09:02 PM   #13
clownymb
clownymb's Avatar
Fan#: 116722
What I Drive: 2003 Silver SVT
FF Reputation: 1 clownymb Good Standing Member
I am going to just install my PLX wideband where the primary o2 sensor goes since it will also send a narrowband signal to the ecu. No having to cut or weld is nice. :D
clownymb is offline
Old 08-21-2013, 09:21 PM   #14
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 374, Level 7
Points: 374, Level: 7 Points: 374, Level: 7 Points: 374, Level: 7
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 6%
FF Reputation: 1 GhostTribute Good Standing Member
Innovate has the same functionality. The Innovate also has 2 analog outputs that can be setup for ether 0-1v (OE narrow) or 0-5v (wide) outputs!
This is just one of the reasons that Innovate has been my choice for AFT monitoring and tuning hardware..... the LM Programmer and Log works software are also very straight forward to use and setup.
GhostTribute is online now
Old 08-21-2013, 09:42 PM   #15
Basselisk
Fan#: 102662
What I Drive: 2003 CD Silver SVT
Points 516, Level 10
Points: 516, Level: 10 Points: 516, Level: 10 Points: 516, Level: 10
Level Up 32% Completed
FF Reputation: 1 Basselisk Good Standing Member
So can I just replace my front o2 sensor with the innovate one? without having to cut or weld anything at all?
Basselisk is offline
Old 08-21-2013, 10:30 PM   #16
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
No you need the front o2 sensor.
Old 08-21-2013, 10:44 PM   #17
GhostTribute
Fan#: 107929
Points 374, Level 7
Forum Activity 6%
Yes you can use the stock O2 bung, no cutting or welding required. You have to wire/solder one of the Innovates analog wires up to the OEM O2 signal wire to the ECU.
It takes the place of the OEM primary O2 sensor.
Old 09-11-2013, 11:34 PM   #18
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,780, Level 54
Points: 6,780, Level: 54 Points: 6,780, Level: 54 Points: 6,780, Level: 54
Level Up 15% Completed
Forum Activity 47%
Activity: 47% Activity: 47% Activity: 47%
Buy-Sell-Trade Rating: (23)
From what I have researched, it is best for the wideband sensor to go as close as possible to the 12 o'clock position.
Anyone else?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 09-12-2013, 12:03 AM   #19
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
It is.
I've been using PLX for a few years now. I'm very happy with it.
So does PLX.
Only difference is you don't get the tuning software (which many don't know how to use anyways)
No you don't.
If you use the Analog NB output from the WBO2 to the ECU it'll run just fine ... or better than stock if you have the same results as me.
iminhell is offline
Old 09-12-2013, 12:45 AM   #20
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,554, Level 100
Points: 52,554, Level: 100 Points: 52,554, Level: 100 Points: 52,554, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (28)
If you want to make your life simple add a bung and install something like the AEM like on C-F-M web site and be done with it
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
