Recirculating a blow-through system? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-16-2013, 05:06 PM   #1
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
What I Drive: 2001 ZTS, 2002 SVTF Turbocharged
FF Reputation: 6 svtf1417 Good Standing Member
Buy-Sell-Trade Rating: (6)
Is anyone using a blow through setup, and recirculating their BOV? If I wanted to would I vent it to pre-turbo? I discovered the other day either my BOV is faulty, where my BOV is in relation to my MAF is no good, or I need to recirculate my BOV.
Backround story. Ive been having the HARDEST time getting my car to return to idle without stalling. Tom and I have been working on in for the past 2 months now. It would even stall revving it in the driveway. Anyways I noticed my BOV wasnt shutting very smoothly (brand new TiAL) so I unhooked it and plugged the vacuum line. It revved without stalling, and I could drive it around without stalling anymore.
Anyone else every experience these problems? Heres my setup
[#1417] 2002 Sonic Blue SVT Focus
Born on June 25, 2002
2001 Silver ZTS Sedan - "Ol' Reliable"
svtf1417 is offline
Old 08-16-2013, 05:23 PM   #2
Timmeh!
aka The Wizard
Timmeh!'s Avatar
Fan#: 27514
What I Drive: '87 Jetta GL, '82 Benz 300TD
Points 22,298, Level 92
Points: 22,298, Level: 92 Points: 22,298, Level: 92 Points: 22,298, Level: 92
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 3%
FF Reputation: 9 Timmeh! Good Standing Member
BOV should be farther upstream from what I can tell. what do you mean by it's "not shutting smoothly"?
BOV -> MAF should be at least 6" (IIRC... and more is always better tbh)... plus that coupler doesn't look good for flow. the MAF relies on laminar (straight and even) flow to get an accurate reading... dumping a bunch of air out sideways just before it makes it not happy.
can you get a MAF/tube that matches the charge pipe diameter? cause that will help.
my 6" estimation is corroborated here: http://www.performancetrucks.net/for...cement-500925/
proof i read too much of everything on the internet. I've built 0 boosted cars but I can identify 1 for sure and 1 potential problem here.
if your were recircing it'd be a diverter not a BOV (i know some can do both, it's not necessary when the valve is pre-MAF)
little info from Wikipedia
The type of flow occurring in a fluid in a channel is important in fluid dynamics problems. The dimensionless Reynolds number is an important parameter in the equations that describe whether flow conditions lead to laminar or turbulent flow. In the case of flow through a straight pipe with a circular cross-section, at a Reynolds number below the critical value of approximately 2040 fluid motion will ultimately be laminar, whereas at larger Reynolds number the flow can be turbulent. The Reynolds number delimiting laminar and turbulent flow depends on the particular flow geometry, and moreover, the transition from laminar flow to turbulence can be sensitive to disturbance levels and imperfections present in a given configuration.
When I look at your maf sitting between couplers... I keep seeing those words in bold jump out at me. Now under normal operation they may be (and it sounds like they are) fine. but once the BOV opens you're changing the whole game because the air pre-maf is now more turbulent, causing the MAF to read wrong (probably low, i doubt it would read high in that case, but i don't play with MAFs much) and your car to do funny things. (I.E. too low of a fuel... runs lean... stalls.
http://www.engineeringtoolbox.com/re...ber-d_237.html
^^ you can calculate the reynold's number there... not sure how applicable it is in this exact instance. I don't have my aero books on my desk at work (or on my normal desk at home, they're at my mom's) but when I get them I'll try to have a gander and figure it out.
^^^ those are the wrong formulas... I'll try to find the ones I/you need.
Otto - 82 Benz Turbo Diesel Wagon - cruiser
Mitzi - 87 VW Jetta - low n slow
CATIA is a dirty tramp, until you figure out its sweet spots, and how to make it moan. Then its easy as apple pie on a fall afternoon.
Last edited by Timmeh!; 08-16-2013 at 05:35 PM. Reason: I have edited this WAYYYYYYYYY too many times already. I think I hit all the bases though.
Timmeh! is offline
Old 08-16-2013, 05:46 PM   #3
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
move the BOV closer to the intercooler. And what spring do you have in that BOV?
That could be your problem.
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 08-16-2013, 11:03 PM   #4
tcorbs
Fan#: 108172
What I Drive: 2001 greenzx3
FF Reputation: 1 tcorbs Good Standing Member
Post
my blow off valve is located right to the drivers side of my intercooler behind my bumper, i have a greddy bov works just fine and its also down streem from the maf away from motor
2001 turbo zx3, h&r cup kit, eagle gt's, bbs rims, forged lower end, focus sport head package.
tcorbs is offline
Old 08-16-2013, 11:30 PM   #5
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 20,994, Level 91
Points: 20,994, Level: 91 Points: 20,994, Level: 91 Points: 20,994, Level: 91
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 9%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
your set up will be fine with atmospheric vent, just move the bov further from the maf. the bov you choose is up to you. any will work on a blow through maf set up. you can recirc if you want really doesnt matter. charge piping being smaller than maf housing will not hurt any thing either.
Tim
Turbo Turtle Garage
Mig and Tig fabrication, engine building
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is offline
Old 08-17-2013, 02:41 AM   #6
kwg2371
kwg2371's Avatar
Fan#: 82857
What I Drive: 03 screming yellow SVT #1841
Points 3,824, Level 39
Points: 3,824, Level: 39 Points: 3,824, Level: 39 Points: 3,824, Level: 39
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 3 kwg2371 Good Standing Member
Tim
this^^^^^^^^^^^^^
HatchNation #36
FF 13 best audio
FF 13 3rd place best in class SVT
FFW 13 best focus
FFW 13-14 best in class SVT
kwg2371 is offline
Old 08-17-2013, 09:14 AM   #7
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
Thanks everyone!! Now I just need to find someone with a tig welder, and see if my guy will re-powdercoat my pipes after I ruin them lol
svtf1417 is offline
Old 08-17-2013, 09:30 AM   #8
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,942, Level 100
Points: 51,942, Level: 100 Points: 51,942, Level: 100 Points: 51,942, Level: 100
Level Up 0% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
Buy-Sell-Trade Rating: (28)
I would loose the tial bov , I dont like tial and never did , if you bov is sticking like you said it was where you can see it close in steps then there is something wrong with it
You should see the bov snap open and snap closed , with it off you shouldnt be able to move the plunger when trying to push it in
You are a little close to the MAF but I am not 100% that being close is your problem
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-17-2013, 10:49 AM   #9
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
I'm taking it to them Tuesday morning it's under warranty. If anything is wrong they'll fix it or replace it on the spot. I'm not 100% either, I believe its a combination of things. Also, your guys are the ones who put that bov openning there.
svtf1417 is offline
Old 08-17-2013, 02:00 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 35%
I put it there on all my kits , I know my piping when I see it lol
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
