Svt head question - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 08-13-2013, 03:16 PM   #11
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
Originally Posted by Magus2727 View Post
Trouble with that is if its a daily driver. most machine shops will take a week or two to work on it. so you need to find another car to drive while you are working the single head. That's where the "turn key" option is desirable.
How is it "desirable" to pull the head if not needed?
MannKind Corp. (MNKD)
NJSVTGUY is offline
Old 08-13-2013, 03:37 PM   #12
Magus2727
Magus2727's Avatar
Fan#: 62897
^^? the poster i was quoting said he had a machine shop rebuild his head for $300. I was pointing out that to do that it means your car is with out a head and obviously undrivable while the work is being done. This was nothing to say that OP needed to replace the head. I was just pointing out the obvious. And sometimes its easier for the person to do a wide sweeping "repair" to fix it all rather than do it one at a time. its all in the persons priorities and where they lay value.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 08-13-2013, 03:57 PM   #13
WU644
WU644's Avatar
Fan#: 36081
What I Drive: 2004 SVT BLK
FF Reputation: 2 WU644 Good Standing Member
When u say fix is broken ? Or you mean adjusted or do i need springs etc ? I'm looking at it like this the car now has 78453 miles runs strong but that ticking sounds is annoying .. So why not pull the head replace some springs valves port an polish while in there wrap it up and call it a day . What do you think ?
WU644 is offline
Old 08-13-2013, 04:05 PM   #14
Magus2727
Magus2727's Avatar
Fan#: 62897
I am using fix in a general term. I do not know what you need. All we are going off of is: "light tapping sound which i think its the valve springs". all I am saying is a "new" reworked head would be the mighty all encompassing "fix" it may be nothing. or it may be the last thing you try ti fix in the long list of things to do.
it depends what is worth more to you? do you have the spare $300 to drop on having a shop rework the head, and the cost, time, and tools to replace the head? if not then doing smaller items may be best. some people value there time and money differently. to 1 person it may be worth it to just take it to a shop and say fix it and have it done the next day. others they rather spend the month or two slowly trying to track down the problem. the first person spend more $ but the second person spent more time.
Hatch Nation #42
Old 08-13-2013, 04:52 PM   #15
WU644
WU644's Avatar
Fan#: 36081
Well with that said i find myself saying im the one who can drop 300 bucks or so on it.. I can honestly say i 99% its probably the lifters/springs/valves.. I know i dont have a slipped bearing so between me and my pops its got to be the parts i mentioned.. So which leads me to say i want it done and i dont see anything wrong with a port and polish and also looking to upgrade to better/stronger parts. Something that is going to benifit me and the performance of the car to some degree.. All help is Appreciated from all.
WU644 is offline
Old 08-15-2013, 02:47 PM   #16
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
Hey it's all good, just an internet thing. Saw your build post pretty neat. I see my SVT as just a DD and only replace on failure, like you said "all in the persons priorities and where they lay value"
Dan
NJSVTGUY is offline
Old 09-14-2013, 10:05 PM   #17
termi-on
Fan#: 118731
What I Drive: 2003 cobra, 2003 svtF
FF Reputation: 1 termi-on Good Standing Member
...^+1
termi-on is offline
Old 09-15-2013, 04:00 AM   #18
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
Valve springs don't make noise, if they did then broken and motor about to blow up. The tappet clearance gets loose to make noise just like someone else already said. I find it humorous that someone who thinks the springs make noise also talks about the buzz words 'port and polish' and pretty much lost as no one pretty much does that any more. Polishing almost always LOSES horsepower and pretty much wasted on a multiport injected motor anyway. Porting can do the same, I've seen far more hack jobs in porting that cost power than ones that made it. You really need a flowbench to port properly. Why another expert around here advocates not touching the head at all as far as porting, and for d-mn good reason.
amc49 is offline
Old 11-14-2013, 11:29 AM   #19
newtofocus's2002
Fan#: 117343
What I Drive: black 2002 focus svt
FF Reputation: 1 newtofocus's2002 Good Standing Member
What is a SVT head worth anyways? like how much does a used one cost?
newtofocus's2002 is offline
Old 12-04-2013, 11:03 PM   #20
SquiresSVT
Fan#: 103075
What I Drive: 2004 Silver ZX5
FF Reputation: 1 SquiresSVT Good Standing Member
Tom and others that said check valve tappet or "bucket" to cam lobe clearances are spot on. You've probably got some out of tolerance buckets.
SquiresSVT is offline
