Aftermarket Sub and Amp - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST Interior Mods & Upgrades
Focus ST Interior Mods & Upgrades The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the 2013-Current ST Focus.
Old 08-11-2013, 02:05 PM   #1
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What I Drive: Slammed S-10
Points 8,062, Level 60
Points: 8,062, Level: 60 Points: 8,062, Level: 60 Points: 8,062, Level: 60
Level Up 56% Completed
FF Reputation: 7 Chaos09 Good Standing Member
I have a 13' ST2 with the factory amp and subwoofer. What would be the easiest way to install an aftermarket amp? Is there a connector that will plug into the stock wires that i can use to power my amp? Would I have to run a new power and ground? Any help would be awesome.
Sonic's MK3 Crew #9 Chaos!
Chaos09 is offline
Old 08-11-2013, 06:28 PM   #2
FamousMassacre
Fan#: 104066
What I Drive: 2013 Performance Blue Hatch
Points 1,845, Level 25
Points: 1,845, Level: 25 Points: 1,845, Level: 25 Points: 1,845, Level: 25
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 FamousMassacre Good Standing Member
Hey Chaos, my name is Chase and I will be assisting you today.
I am not familiar with the factory amp of a 2013 Focus ST, but I do have extensive knowledge in car audio.
What you want to do is unhook the subwoofer from the amp so it no longer turns on, you can do this by pulling out the speaker wires that go into the amp from the subwoofer.
How much power are you trying to run? For anything above 1500rms I would recommend 1/0 gauge wiring as well as a big 3 upgrade and an extra battery. Anything over 2500rms I fully recommend an extra alternator so you do not blow your stock alternator.
Installing an amp is fairly straight forward, you'll need an LOC(Line out converter) if you do not have an aftermarket head unit.
I recommend this: http://www.sonicelectronix.com/item_...AC-SOEM-T.html
DISCONNECT YOUR BATTERY: Negative off first and when reattaching, negative on last.
1. Attach about 12" of cable to your battery positive and into a fuse
2. Run the other 16 or so feet from your fuse to the amp
3. Find a good spot near amp to run a ground wire to. At this spot you want to make sure it's properly sanded down to bare metal, making sure there is no paint and then attach it to the amp.
4. I HIGHLY HIGHLY HIGHLY recommend having an enclosure made specifically for your subwoofer.
5. Make sure the subwoofer is wired down to 1 ohm
6. Run pos and neg from enclosure to amp.
What are you going for? Better sound quality or SPL(loudness) or SQL(loud with sound quality)
What's your budget?
I would be pleased if you messaged me back so I can help you throughout this install.
~ Chase
FamousMassacre is offline
Old 08-11-2013, 07:46 PM   #3
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
What's your budget?
~ Chase
I already have a sub, box and amp. Just wanting to hook it up to the existing wiring.
Chaos09 is offline
Old 08-11-2013, 08:03 PM   #4
FamousMassacre
Fan#: 104066
What sub and amp?
Also who made the box? Sealed or Ported?
Old 08-11-2013, 08:26 PM   #5
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
It's a fusion 1000watt amp with a Memphis mojo 12" sub in a ported box.
Chaos09 is offline
Old 08-11-2013, 08:32 PM   #6
FamousMassacre
Fan#: 104066
It's a fusion en1502 1000watt amp with a Memphis mojo 12" sub in a ported box.
That amp won't work with that sub.
That amp is a 2 channel amp that is only bridgeable at 4 ohms even then you're only getting 150rms if that amp put out proper power, which it doesn't so you're looking at around 100rms.
It will not give it anywhere near rated power, probably not even enough to move the sub.
Not trying to rain on your parade bro.
Old 08-11-2013, 10:18 PM   #7
Chaos09
Sonic Crew #09
Chaos09's Avatar
Fan#: 95090
I have had this same sub and amp combo in a Tahoe. It will beat your brains out. Thanks for the help.
Chaos09 is offline
Old 08-12-2013, 12:13 AM   #8
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
The only way to hook a after market amp and sub is to use a (loc) there is no way to hook up the factory wiring it literally is tied into about everything on this car
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 08-12-2013, 12:50 AM   #9
FamousMassacre
Fan#: 104066
You must have never been in a real system. I'm talking 150+db.
I'm going to upgrade my alt soon and get 5000rms in my focus :D:D.
I should be getting around 153db.
Loudest truck I've been in:
YouTube Video
It's crazy.
Old 08-12-2013, 04:47 AM   #10
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,753, Level 24
Points: 1,753, Level: 24 Points: 1,753, Level: 24 Points: 1,753, Level: 24
Level Up 53% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 5 StingRay Good Standing Member
I think you'll have to run a new power and ground, and tap into the factory sub wiring for signal. The stock ST amp wiring has a ton of other stuff wired into it (or so it looks) so you probably don't want to completely remove it from the system.
StingRay is offline
