Adding aditional interior LEDs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 08-09-2013, 07:16 PM   #1
Michaelc1220
Michaelc1220's Avatar
Fan#: 93834
What I Drive: 2012 Grey Focus SE hatchback Sport
FF Reputation: 2 Michaelc1220 Good Standing Member
I want to add additional LEDs to the rear seats, and possibly a few other locations inside the car. Does anyone know if there is a spot in the fuse box that gets power when the ignition is turned on? I don't really want to tap into the existing footwell lights because they shut off when you close the doors. If there's a way to link them to the parking lights from the fuse box that would be even more beneficial, but I don't want to get into something more than i can handle. Any information would help! Thanks -Mike
Michaelc1220 is offline
Old 08-09-2013, 08:24 PM   #2
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,749, Level 53
Points: 6,749, Level: 53 Points: 6,749, Level: 53 Points: 6,749, Level: 53
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 3%
FF Reputation: 9 SilverPony2001 Good Standing Member
I'm assuming you don't have factory ambient lighting?
SilverPony2001 is online now
Old 08-09-2013, 08:53 PM   #3
Michaelc1220
Fan#: 93834
I have factory lighting in the footwells, thats it. There is one light on each side which i've already changed to LEDs. I don't have the ones that are in the door panels or anything.
Old 08-09-2013, 09:10 PM   #4
SilverPony2001
Fan#: 27073
Forum Activity 3%
I did this in a escort. Used the Cigarette lighter/power point fuse. Has 12v when acc or ignition is on.
See here:
http://www.focusfanatics.com/forum/showthread.php?t=320587
EDIT: I think the 12v on the focus it hot all the time, unless it goes off after that 30 minute period when your radio still works. You probably can't tap into that. But something like the power windows should work.
Old 08-09-2013, 10:42 PM   #5
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 968, Level 16
Points: 968, Level: 16 Points: 968, Level: 16 Points: 968, Level: 16
Level Up 68% Completed
FF Reputation: 5 dbenney Good Standing Member
make sure you do the calculations to figure out the resistor needed or you will burn out the leds fairly quickly. I would just figure out what the resistance is for your factory footwell lights are and wire your new ones in paralell with a resistor to lower the voltage from 12v to the required for the leds you use.
dbenney is offline
Old 08-09-2013, 10:44 PM   #6
SilverPony2001
Fan#: 27073
Forum Activity 3%
Or just buy prewired LED's with resistors already wired in.
Old 08-10-2013, 02:14 AM   #7
Nickel
Fan#: 114934
What I Drive: 2012 Black Focus SEL Hatchback
FF Reputation: 2 Nickel Good Standing Member
From my experience The 12v outlets power off at some point after turning off the car, and then regain power when I open the door.
Nickel is offline
Old 08-10-2013, 02:28 AM   #8
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
I used the windshield wiper fuse when I did mine. only gets power when the car is on, and the wipers are hardly used so not alot of power is really added to the fuse
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 08-11-2013, 07:50 PM   #9
Michaelc1220
Fan#: 93834
I actually tapped into the pos and neg on my sub amp that is under my passenger seat. As it is, it pulsates to the bass so its pretty awesome actually, but i'll see how I like it.
Old 08-12-2013, 01:34 PM   #10
Rownan
Rownan's Avatar
Fan#: 103249
What I Drive: 2013 Ford Focus ST
FF Reputation: 1 Rownan Good Standing Member
I used the below guide for my footwell LEDs. I used an add-a-fuse to make it nice and easy. They come on as soon as the ignition is on.
http://www.focusfanatics.com/forum/showthread.php?t=297198
Rownan is offline
