Can the SVT handling package be installed on the 2010 SES? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2013, 03:00 PM   #1
Bugwhacker
Fan#: 117535
What I Drive: 2010 Silver SES
FF Reputation: 1 Bugwhacker Good Standing Member
My struts are blown from too much high speed driving on crappy highways so its time for new struts. I have been reading the Forums trying to figure out a good replacement for them that is better then stock SES but not super expensive. I was wondering if the SVT package from Ford motorsports will fit it and what part numbers I really need.
Bugwhacker is offline
Old 08-05-2013, 03:08 PM   #2
cmmike1
cmmike1's Avatar
Fan#: 63736
What I Drive: 2008 Silver Coupe SES
Points 1,061, Level 17
Points: 1,061, Level: 17 Points: 1,061, Level: 17 Points: 1,061, Level: 17
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 1 cmmike1 Good Standing Member
not without the massive omni kit.
cmmike1 is offline
Old 08-05-2013, 03:14 PM   #3
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
The FRPP kit will bolt right in(=
Galatians 6:14
crice8 is offline
Old 08-05-2013, 03:17 PM   #4
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
Upgrading to a performance strut will only make the ride worse on a bad highway and if that's where most of your driving is done... it may be something to consider.
This is a complicated area because all the parts from all Focus years will fit with the right modifications, but some struts are not compatible with some springs.
If you buy the SVT struts, you would need the "Omni kit" to mount them as well as matching springs as the 08+ springs won't fit.
You can buy the 06-07 FRPP kit, but that only works with 06-07 springs and it lowers the car 1.5" so the factory alignment cannot be corrected without additional parts. (Alternatively, you can use your 08+ springs with the factory top hats, but some people do not recommend reusing these parts. It's up to you)
My suggestion would be to call or click tousleyfordparts.com and order direct replacements. They're pretty cheap and if you want to go high-performance later on you'll be under less pressure to do it quickly so you can do it right.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 08-05-2013, 03:54 PM   #5
Bugwhacker
Fan#: 117535
I don't drive that road anymore and I do about 25,000 miles a year in my car on almost all good roads. The SVT kit is cheap even with the adapters if that what it needs. It lowers about 1" at the most - is what I understand and is at a reasonable price.
Old 08-06-2013, 10:53 AM   #6
Bugwhacker
Fan#: 117535
So using the M-3000-ZX3 Ford Racing kit + the Massive OMNI-KIT Suspension Adapter + new top-hats for the front struts from 2005?
$250 - M-3000-ZX3
$ 95 - Massive OMNI-KIT Suspension Adapter
$ 25 - 2 NEW 2005 top spring seats
$370 + shipping.
What other parts would I need to convert over to the SVT suspension?
I am not looking for ultra low just an improvement without spending a mass of money.
It will cost me about $200 just to replace the struts and shocks with OEM.
Old 08-07-2013, 02:46 AM   #7
Red Jay 918
Red Jay 918's Avatar
Fan#: 79277
What I Drive: 2010 Focus SE
Points 9,428, Level 65
Points: 9,428, Level: 65 Points: 9,428, Level: 65 Points: 9,428, Level: 65
Level Up 26% Completed
Forum Activity 4%
FF Reputation: 7 Red Jay 918 Good Standing Member
if you're going w/ Ford Racing parts i'd just go w/ the ZX3B stuff. you won't need an adapter or anything like that so long as its 06-07. if i'm not mistaken that would be cheaper than $370 from Tousley.
Red Jay 918 is offline
Old 08-07-2013, 10:24 AM   #8
crice8
crice8's Avatar
Fan#: 84830
this^
You only needs the springs and the shock and struts. No omni-kit is needed.
Galatians 6:14
crice8 is offline
Old 08-07-2013, 10:48 AM   #9
mac.mogul
mac.mogul's Avatar
Fan#: 90409
You can use part M-18000-ZX3B ($160) with your factory springs and factory top-mounts, but those struts are designed to be used with M-5560-ZXM1 lowering springs so using factory springs would put the struts outside of their designed operational range. It's likely you wouldn't have any issues for many thousands of miles, but as far as I know, nobody has used those struts on stock springs.
This thread: http://www.focusfanatics.com/forum/showthread.php?t=275709 will tell you all you need to know about your suspension options on 08+ models.
Edit: That thread seems to be missing some posts? Where's the big Mk2 suspension thread that explains all the differences in suspension from year to year??
Old 09-17-2013, 12:02 PM   #10
Bugwhacker
Fan#: 117535
Well I decided to go with M-5560-ZX3B springs and M-18000-ZX3B damper kit with a set of K100009 camber bolts for the rear. They are supposedly being shipped and on the way so we will see if I get the right springs. I ordered them from Fordracingparts123 and they said they had them in stock.
So the question is since I am dropping 1.5" what else do I need to complete this install? Front camber plate?
