Sluggish performance - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2013, 08:54 PM   #11
comcast.net
comcast.net's Avatar
Fan#: 117212
What I Drive: 2013 Performance Blue 5Spd SE HB
FF Reputation: 1 comcast.net Good Standing Member
You might want to disconnect the battery and "reboot" your car...Back in the day when I had a 1995 Mercury Mystique with the Duratec 2.5 V6/5spd combo, if I made any changes to the car like intake/exhaust, I would in essence wipe the ECU to create a new map...I wonder if that's relevant today.
comcast.net is offline
Old 08-05-2013, 09:51 PM   #12
Timkainu
Fan#: 117474
What I Drive: 2012 Sterling Grey Metallic SE
FF Reputation: 1 Timkainu Good Standing Member
I did disconnect the negative battery and "reset" the ECU, twice I think? First time when I installed the CAI, second time a week later for the heck of it.
I brought the car into the shop a month ago because the check engine light came on, and the car bogged down. Apparently it was something with the transmission that threw the car into limp mode. The shop reset the codes, and made the car go through a "relearning process" but he said there's still a chance the light may come back on.
But, I guess there's a TSB for it, the shop said. The DTC code was P2837. So, in the instance the problem happens again, they said to bring my car to the dealer and give this TSB report to them so they can reprogram my car.
Anyways, I hope this tuner helps me out. The car does seem to run rich or something. Definitely not how my girlfriends car runs.
Thanks again for all the help, guys!
Timkainu is offline
Old 08-10-2013, 04:44 AM   #13
MG_MK3
MG_MK3's Avatar
Fan#: 114522
What I Drive: 2013 Blue Candy Focus Hatchback SE
Points 500, Level 9
Points: 500, Level: 9 Points: 500, Level: 9 Points: 500, Level: 9
Level Up 50% Completed
Forum Activity 4%
FF Reputation: 0 MG_MK3 Newbie
Very odd....
2013 "Blue Candy" Focus Hatchback SE/DCT
AEM CAI | Steeda RMM | ST wing | TTR UMM
2.5 inch straight pipe | 3SDM 0.05 18"x8.5J | KSport Kontrol Pro's
Instagram @miKeyGilmore #MK3SLöCUS
MG_MK3 is offline
Old 08-10-2013, 07:11 AM   #14
roswelltop
Fan#: 83279
What I Drive: 2014 Ruby Red Titanium Hatch
Points 2,414, Level 29
Points: 2,414, Level: 29 Points: 2,414, Level: 29 Points: 2,414, Level: 29
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 14%
FF Reputation: 1 roswelltop Good Standing Member
My 2 cents on this, call Aron at Injected Engineering and talk through the issues that you're having with your car. I have the IE tune and am totally happy with the result, BUT my car was running perfectly (I.e. OEM style with the K&N CAI) before the tune was installed.
Here's the thing, and maybe my thinking is wrong, if there is something wrong with your car now AND the tune doesn't correct it, you are going to be even unhappier.
Hope you get your car running right because this engine just performs so beautifully.
Good luck.
roswelltop is offline
Old 08-10-2013, 09:16 AM   #15
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
Ordering the tune was a great choice. However, take the car in to have the current tsb done to it (software update & strut bearings). Are both of your cars automatics?
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 08-10-2013, 05:21 PM   #16
Timkainu
Fan#: 117474
Yeah, I wish I could bring it in and have the TSB applied to it. However, the Ford dealer I called up said I would have to wait until the light came on again to apply it. Is there a way I can have them do it without waiting for the light?
And thanks for the suggestions. I will call Aron and see what he has to say. I just tuned my car with the 93 octane tune and it seems a little better. Still doesn't seem as quick as my girlfriends. We both have automatics.
I always used 87 octane. Just recently went through my first full tank of 93. Would unplugging the negative wire from the battery again do any good, or would it be useless? Should it be done after a tune?
Thanks again for all the help, everyone.
Timkainu is offline
Old 08-10-2013, 05:34 PM   #17
Irondemon
Fan#: 117201
What I Drive: 2013 tuxedo black se
Points 602, Level 12
Points: 602, Level: 12 Points: 602, Level: 12 Points: 602, Level: 12
Level Up 4% Completed
FF Reputation: 1 Irondemon Good Standing Member
Just a thought, do both cars have the same size wheels/tires and are bothe optioned the same? Just trying to help narrow it down.
(Edit) just reread one has the sport package and one doesn't.
2013 tuxedo black se hatch. Tinted, smoked,custom xcal tune, steeda cai,magnaflow catback,header, 18"black ford racing wheels, eibach pro kit springs,steeda front and rear sway bar, motor mounts, red badge overlays.
Irondemon is offline
Old 08-10-2013, 08:45 PM   #18
Timkainu
Fan#: 117474
Yes, she has the sport package. We both have the same size wheels and tires. Hers is flex fuel compatible.
Wish I knew what it was. I'm still wondering why the spark plugs look like they do. Perhaps it's normal.
I observed where my car is slower. It's around 1300-1500 RPM and around 25-35 MPH. If I stomp on the throttle, it's sluggish to get to 45-50. That's where it seems like I get sluggish performance.
Timkainu is offline
Old 08-11-2013, 09:11 AM   #19
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
That spark plug looks perfectly normal to me. You're always going to have a light carbon film as a by-product of combustion. If it was thick and crusty, there would be reason for concern.
Hatch Nation #90
TboneZX3 is offline
Old 08-11-2013, 09:51 PM   #20
VonKaiser
VonKaiser's Avatar
Fan#: 26749
What I Drive: 2013 Ford Focus SE sedan
FF Reputation: 1 VonKaiser Good Standing Member
Anyone got a YouTube video of the off the line acceleration with the Injected tune for us DCT automated manual owners?
2013 Ford Focus SE Sedan
2012 Ford Fusion SE I4
1990 Chevrolet Camaro RS V8 [sold]
VonKaiser is offline
