5 Minute throttle response/DCT solution? - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-14-2013, 11:40 AM   #61
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
Originally Posted by gkirk View Post
I'm still curious if the reports on here are placebo or not. ?
gk
Try it and let us know.
My experience is that it does not cure the underlying DCT issues like grinding and slipping, but it does fix the throttle lag, improves low end power, and diminishes those DCT symptoms that were exacerbated by poor low end power like some of the herking and jerking at low speed.
Sent from my Galaxy Note 2 using FF Mobile.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 08-14-2013, 11:45 AM   #62
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,034, Level 33
Points: 3,034, Level: 33 Points: 3,034, Level: 33 Points: 3,034, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
i looked at mine quickly and it had enough of a gap that i could push the whole thing together and close it up a little. I'm still curious if the reports on here are placebo or not. I know that on my bimmer, a leak in the intake system would cause rough idling and other very weird effects, but those were closer to the engine if that makes sense.
Still though, I'll tape mine up later. In my quick inspection it looked a little tricky to get to the underside. Is it?
gk
The underside could be hard to get at, but the large and deep rubber support for the intake tubes may do a decent job of sealing there. I'd suggest just doing the top and see if you notice a difference.
If this helps, I'm sure there are plenty of ways to effect a more permanent and, um, professional fix than duct tape. For now, this is a really, really cheap and quick test.
As this leak is upstream of the air filter, I imagine this would not cause the same symptoms as you noticed in your BMW. I suspect the issue here is drawing in hot engine compartment air at idle with a too-quick transition to cooler air when the throttle is opened. The PCM can adjust to changes in intake air temp, but not instantly. And with active grille shutters and the bottom "aeroshield" underhood temps on the Focus probably get pretty high.
dan50 is online now
Old 08-14-2013, 12:25 PM   #63
Kabigon
Fan#: 88299
Points 4,391, Level 42
Points: 4,391, Level: 42 Points: 4,391, Level: 42 Points: 4,391, Level: 42
Level Up 21% Completed
Forum Activity 13%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by slybarman View Post
I forgot to mention that after plugging up this gap, I also disconnected the battery for a bit so the ecu would go through a re-learn.
That's not a good idea.
FWIW, the PCM is always "learning".
I am Kabigon and I approve this message.
Kabigon is online now
Old 08-14-2013, 01:08 PM   #64
slybarman
Fan#: 105425
So the car can't ever have the battery disconnected? I guess It better be a long life battery.
Old 08-14-2013, 01:16 PM   #65
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
What he means is that whether you disconnect the battery or not, the ecu is going to relearn based on your driving.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 08-14-2013, 01:28 PM   #66
mr_cassandra
Fan#: 95399
What I Drive: Mazda-3 , formerly a focus SE
Points 331, Level 6
Points: 331, Level: 6 Points: 331, Level: 6 Points: 331, Level: 6
Level Up 62% Completed
Forum Activity 3%
FF Reputation: 2 mr_cassandra Good Standing Member
I can tell you for sure that my ECU left the school building when I turned on the AC and any time I had extra passengers. It never did "learn".
only time it worked right was cold weather.
mr_cassandra is offline
Old 08-14-2013, 01:36 PM   #67
redzone
Fan#: 114512
What I Drive: 2013 Blue Candy Hatchback SE
Points 769, Level 14
Points: 769, Level: 14 Points: 769, Level: 14 Points: 769, Level: 14
Level Up 69% Completed
FF Reputation: 1 redzone Good Standing Member
so am i right in assuming you cant do this if you do the snorkel delete?
2013 Focus Hatch Se
Blue Candy
Build Date: 03.02.2013
Stock for now
redzone is offline
Old 08-14-2013, 01:37 PM   #68
slybarman
Fan#: 105425
"doesn't work" is different than "not a good idea", but ok.
Old 08-14-2013, 01:43 PM   #69
underbird10
underbird10's Avatar
Fan#: 88103
What I Drive: 2014 ST3
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 3 underbird10 Good Standing Member
Perhaps a better description would be "default the ECM". It doesn't hurt a thing, and it would seem to make sense when you're trying any A/F mod.
I am a believer in this mod. I have had it in-place now for a few days and can vouch for the smoother launch at high temps. This is one of the only concerns I've had with my June 2011 MFD Focus and it IS now what I expected the 2.0 w/DCT to be all along.
My step-by-step procedure was:
1) Fix the induction tube, clean and re-oil K&N DIF
2) Drive/Test (results were: smoother launch, smoother idle, lower tone of induction system under throttle)
3) Reset ECM
4) Drive/Test (results were: firmer shift points, higher RPM between 1-2, 3-4 shifts)
5) Run throttle calibration process (described previously)
6) Drive/Test (results were: couldn't tell any difference)
7) Reset gas mileage calculation to test for gain/loss (will post results later)
UB10
2014 ST3 - Tuxedo Black with Full Leather Recaros, Sunroof, Nav-Sync-MFT
My other rides -2006 Performance White Mustang GT Coupe, 2004 40th Anniversary Edition Mustang Coupe, 2013 Edge Limited
underbird10 is offline
Old 08-14-2013, 08:06 PM   #70
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
Thumbs up
I too am a believer in this mod. After throwing on some grill pin stipe flair: http://www.focusfanatics.com/forum/s...&postcount=259, I thought, why not service the drop in (it wasn't all that dirty but it had been 28K since I installed it) and work the simple intake gap seal fix (mine was about 5mm as well).
What struck me initially was the deeper induction tone ... cool! My car is over 36,000 miles now and her habits are quite familiar to me. I was a doubting Thomas a little on this one, but what the heck, I've got tape and stuff galore. Just like most others, my shifting, while not all that bad anyway in Maine's cooler temps, is improved and throttle response at low rpm's is better too. Kudos to Dan50 ... whooda thunk it!!!
Drinks are on me, Dan ...
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
Tags
dct fix , powershift fix
