5 Minute throttle response/DCT solution? - Page 4 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 08-10-2013, 07:09 AM   #31
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
FF Reputation: 1 Seminoles Good Standing Member
Originally Posted by bwh13 View Post
I decided to test my theory on the hot air affecting the driveability here in Phoenix. The temp today is 105, car was doing the shuddering just off idle when taking off from a light. I took the car thru a car wash where the air temp dropped to 81. Just like magic the car takes off without any shudder after pulling out of the wash. The outside air temp stayed at 81 for at least 5 minutes and the car definitely runs much better.
Although not a scientific method of determining the effect of cooler air intake on driveability, this info can help us figure out a way for better running when hot. Now we just need to figure out how to keep the intake air cooler.
http://www.focusfanatics.com/forum/s...&postcount=200
Seminoles is offline
Old 08-10-2013, 08:54 AM   #32
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
FF Reputation: 6 slybarman Good Standing Member
I tried this fix this morning. My initial impression is that idle and low end throttle response are improved. However, given this cars tendency to arbitrarily drive better / worse based on day of the week, temperature, humidity, daylight savings time, moon phase, high tide, etc., I will need a few days to be sure.
Sent from my Galaxy Note 2 using FF Mobile.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 08-10-2013, 09:09 AM   #33
F'nClassy
Eh!
F'nClassy's Avatar
Fan#: 97270
What I Drive: 2012 Tuxedo Black Ti Hatch
FF Reputation: 6 F'nClassy Good Standing Member
Originally Posted by peridigm View Post
I noticed similar symptoms after I installed my Steeda CAI. If I accelerate like a granny would it is sluggish and sounds like the car should downshift. This generally happens when I'm trying to keep the sound down when accelerating. If I drive it like a maniac it's fine.
Same thing happens with my car....and I don't even have a CAI. I can barely ever take off slowly from a stop without the car being stupid
HN#154
Sonic's MK3 Crew #07
Live together, die alone
Originally Posted by blackhillsken View Post
Instead of a "Dual Clutch", "Dual Personality" might be a better name.
F'nClassy is offline
Old 08-10-2013, 09:15 AM   #34
H2323
Fan#: 117432
What I Drive: 2013 Red Titanium HP
FF Reputation: 2 H2323 Good Standing Member
from what I understand the Ford cold air works on all MKIII's. Could be wrong. Its warranty approved as well
H2323 is offline
Old 08-11-2013, 12:19 AM   #35
technoshark
Fan#: 41397
What I Drive: '12 Titanium, Tuxedo Black
FF Reputation: 1 technoshark Good Standing Member
Pulled the strap & found sizeable gaps on both tubes. Sealed with duct tape. I've got a tank of premium in her right now, which makes it run real smooth under all conditions; I'll do the next fill with regular & see if the stumbling/lag is reduced. As it's quite warm where I'm at right now, if it was sucking warm underhood air I should notice a difference.
technoshark is offline
Old 08-11-2013, 01:43 PM   #36
ScooterCT70
Fan#: 98691
What I Drive: 2012 Ingot Silver Titanium Focus
FF Reputation: 1 ScooterCT70 Good Standing Member
Thumbs up
I did this mod a few days ago after reading this thread... after a few "long hot day trips" I had forgotten that I did this mod and was pleasantly surprised when I noticed my Focus had a lot more low end power when driving around the city. Took all of 2-3 minutes to complete. I used something called "Tarp Tape" http://www.sportys.com/ToolShop/product/17796 to seal the gap, works well and I keep a roll in my trunk organizer for emergencies.
ScooterCT70 is offline
Old 08-11-2013, 01:55 PM   #37
slybarman
Fan#: 105425
cool - I used some self adhesive weather stripping from the hardware store.
I am curious to see how the drive to work goes tomorrow (36mi in a lot of stop and go traffic).
Old 08-12-2013, 07:20 AM   #38
slybarman
Fan#: 105425
Unbelievable. Drivability in stop and go traffic was significantly improved. The dangerous throttle lag/hesitation seems to be gone. Low end power is more or less smooth and linear. As a result, the transmission did far less stumbling and bumbling and grinding.
OP - if this holds, you are a genius.
Old 08-12-2013, 07:53 AM   #39
mr_cassandra
Fan#: 95399
What I Drive: Mazda-3 , formerly a focus SE
FF Reputation: 2 mr_cassandra Good Standing Member
Originally Posted by dan50 View Post
In the 19,000 miles I've had my 2012 DCT-equipped Focus I've complained about lousy throttle response (bogging, surging,etc.) and DCT behavior (lunging at launch, mostly). I've stumbled upon a solution that eliminates 80% of my issues. Best of all, it only puts the car into the condition in which it was supposed to leave the factory and it's easy.
So those of you with these problems, try this. I'm curious if it will work for you:
1) Facing the car with the hood open, look on the right side and note the two intake tubes coming from the air filter compartment and going through the front bulkhead. (these tubes go through the bulkhead and attach to the intake horn located where cooler air is available for induction)
2) At the point where these two tubes meet the bulkhead, they are secured with a rubber strap that latches on the left side. Undo this latch.
3) You will see that the bottom of these 2 tubes are supported by a rubber base guiding them through the bulkhead. The top half of these tubes, though merely butt up against the bulkhead.
4) The top of these 2 tubes are supposed to be sealed by the rubber strap. In my car, not only was there a 1/8 inch gap between the intake tube and the bulkhead, the rubber strap didn't fit securely enough to creat a seal.
5) Thinking this was not what Ford intended, I sealed the gap with a little duct tape and overlaid that with a layer or two of adhesive felt, then reinstalled the rubber strap.
6) To my surprise, my driveability issues largely went away. My car now behaves the way it should, with much better throttle response at launch and greatly diminished surging, bogging and lunging.
It doesn't make complete sense to me why this is so. However, as suction devices like an intake tube typically draw air first from the closest source and getting air from the intake horn is a bit "uphill" anyway, the car was probably ingesting a lot of warm, engine compartment air, particularly at a stop. When acceleration is asked for, it will suddenly start to ingest the much cooler air from the intake horn. If the PCM had adjusted the fuel mixture to suit the less-dense warm engine compartment air, a sudden introduction of colder air could make the engine run lean for a few seconds. What is a classic sign of a lean mixture? Surging.
So, this may be wishful thinking. However, it could explain why some cars are great and others aren't. It could also explain why some have improved throttle response by removing the intake box cover - while the intake air is hot at least its temperature doesn't suddenly change.
In any event, if you have these symptoms, undo the strap and take a look. If you have a gap or the strap doesn't seem to seal well try filling the gap with tape. Again, all you're doing is putting the car in the condition Ford intended. Apologies in advance if this is no help to others.
thats very interesting, I have scoured the internet about the multiple problems owners experience with the DCT transmission and never seen this mentioned. Nice work
Maybe Ford needs you as a consultant.
mr_cassandra is offline
Old 08-12-2013, 10:16 AM   #40
slybarman
Fan#: 105425
I forgot to mention that after plugging up this gap, I also disconnected the battery for a bit so the ecu would go through a re-learn.
Tags
dct fix, powershift fix
