5 Minute throttle response/DCT solution? - Page 26 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-23-2014, 10:00 PM   #251
danbfree
danbfree's Avatar
Fan#: 159706
What I Drive: '13 Tuxedo Black SE Hatchback DCT
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
FF Reputation: 3 danbfree Good Standing Member
Originally Posted by skiboarder119 View Post
Engineers don't drive automatic transmissions.
LOL... ok, that makes sense now. My apologies... but leave the tape on, it can only help, especially as it gets warmer out... Have you tried using premium fuel? I know it's only $.20 more a gallon where I live but it definitely helps with driveability. The PCM can take advantage of the higher octane and not have to retard timing as much.
danbfree is online now
Old 05-24-2014, 06:45 AM   #252
mjsparky363
Fan#: 93058
What I Drive: 04 f150/2012 SEL/2014 Ti
Points 347, Level 6
Points: 347, Level: 6 Points: 347, Level: 6 Points: 347, Level: 6
Level Up 94% Completed
FF Reputation: 1 mjsparky363 Good Standing Member
In my case I'm starting to think it is a shift software problem. I have 2 DCT Focus' a 2012 and a 2014 and the 2012 went in for clutches and seals last month (totally corrected the shutter). At that time they installed the latest software upgrade for the PCM. Before this both cars had the hesitation. I did snorkel delete and K&N on both and tried the duct tape fix. Kind of gave up and figured it was my driving style, as my wife didn't notice it, or the variable valve timing. Well after we got the 12 back with the new clutches and stuff, no hesitation at all on that car. I tried to get some info from Ford about release dates and things but they just told me to take it to the dealer. I'm to busy right now but will get there sooner or later. Just wondering if others that had the clutches and seals done recently, in 2014, have noticed the hesitation is gone. Anyway, safely enjoy your Focus and have a good Memorial Day.
mjsparky363 is offline
Old 05-24-2014, 11:43 AM   #253
danbfree
danbfree's Avatar
Fan#: 159706
Forum Activity 57%
The hesitation definitely usually goes away after the computer is cleared during a repair. Make sure to "get on it", at least a bit "off the line" when safe and the computer will learn that you need that acceleration and will be more likely to keep it responsive for you. Also, the latest repairs DO seem to be working pretty well, mine has 2000 miles since mine and no degradation at all so far... Good luck and enjoy the long weekend too!
Old 06-07-2014, 11:14 AM   #254
JSB33
JSB33's Avatar
Fan#: 146314
What I Drive: 2014 Titanium Performance Blue HB
Points 260, Level 5
Points: 260, Level: 5 Points: 260, Level: 5 Points: 260, Level: 5
Level Up 20% Completed
Forum Activity 3%
FF Reputation: 3 JSB33 Good Standing Member
Here is the gap on my 2014.
Nothing much to speak of and I am sure the rubber strap seals off the little gap when its closed anyway. Just in case i did cover it with some electrical tape.
JSB33 is offline
Old 06-11-2014, 07:11 AM   #255
tmumolo
tmumolo's Avatar
Fan#: 117776
What I Drive: 2012 Ford Focus Se
Points 2,084, Level 27
Points: 2,084, Level: 27 Points: 2,084, Level: 27 Points: 2,084, Level: 27
Level Up 56% Completed
FF Reputation: 1 tmumolo Good Standing Member
Count Me In
I had the D series clutch pack replacement done on my 2012 with DCT and I haven't had any more problems with it. But the other day in 104 temps I noticed the throttle lag issue. I came to the forum to see if I was alone and found this thread. I tried this fix and unless I'm deluding myself there is a definite improvement in throttle response at all temps but especially when temps were around 100 here in the high desert Apple Valley ca. I've only driven it one day since the fix so we'll see how it goes but so far I'm a believer.
It's hard to believe that at this point in car technology something this seemingly insignificant could make such a difference. How could Ford miss this weak link? I think they might have avoided a lot of negative blow back if this problem had been caught and addressed in the original design.
Hot air in the engine compartment getting sucked into the engine. Duh!
tmumolo is offline
Old 06-11-2014, 07:28 AM   #256
mr_cassandra
Fan#: 95399
What I Drive: Mazda-3 , formerly a focus SE
Points 341, Level 6
Points: 341, Level: 6 Points: 341, Level: 6 Points: 341, Level: 6
Level Up 82% Completed
Forum Activity 7%
FF Reputation: 2 mr_cassandra Good Standing Member
its really not insignificant.
there is a whole import tuner subculture which has been using cold air intakes for many years now.
I have driven one and seen the difference.
any gas motor will be gain efficiency the cooler the incoming air is.
you can get more cool air into the combustion chamber than hot
that gap people have found defeats the above concept because it allows just the opposite
Revision "F" looks like the answer everyone has been waiting for for over 3 years
mr_cassandra is offline
Old 06-11-2014, 11:05 AM   #257
danbfree
danbfree's Avatar
Fan#: 159706
Forum Activity 57%
I also did the snorkel delete and run premium fuel and the combination of these 3 things helps significantly in the heat for sure... then again it's only gotten up to mid 80's for far up here in Portland... I'm driving down to visit my son in Orange County for 4th of July, I'll have to see how it is then.
Old 08-19-2014, 11:40 PM   #258
kennyh3
Fan#: 182753
What I Drive: 2014 ruby red focus
Points 8, Level 1
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Level Up 15% Completed
FF Reputation: 1 kennyh3 Good Standing Member
I wonder why Ford hasn't responded yet......maybe because they don't wont to fix it !!!!!
kennyh3 is offline
Old 08-20-2014, 02:26 AM   #259
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 933, Level 16
Points: 933, Level: 16 Points: 933, Level: 16 Points: 933, Level: 16
Level Up 33% Completed
Forum Activity 2%
FF Reputation: 5 novus Good Standing Member
Probably because it's not much of an issue.
Hatch Nation #118
novus is offline
Tags
dct fix , powershift fix
