5 Minute throttle response/DCT solution? - Page 22 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2014, 02:11 AM   #211
evilO
evilO's Avatar
Fan#: 118681
What I Drive: 2014 Tuxedo Black Focus SE
Points 1,442, Level 21
Points: 1,442, Level: 21 Points: 1,442, Level: 21 Points: 1,442, Level: 21
Level Up 43% Completed
FF Reputation: 2 evilO Good Standing Member
Originally Posted by bama_focus View Post
Had my gap taped for over 10k miles and I don't believe it has made any difference at all.
This. After installing a Steeds CAI I don't believe a gap would make one bit of difference. Tolerances in these vehicles just aren't that tight. Let alone a tolerance of air flow at the intake creating a vehicle that jerks, stutters, bogs, etc.
evilO is offline
Old 04-30-2014, 09:18 AM   #212
raptor1956
Fan#: 97725
What I Drive: 2012, Sonic Blue, Focus Titanium
Points 4,355, Level 42
Points: 4,355, Level: 42 Points: 4,355, Level: 42 Points: 4,355, Level: 42
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 2%
FF Reputation: 1 raptor1956 Good Standing Member
I just noticed this topic, don't know how I missed it this long...
One thing that might be at play here is a flexing as the engine is revved during acceleration causing whatever gap to open or close. If the gap was fixed there would seem to be less surging effect and only a reduction in power due to higher air temp, but if there is flexing then the ECU might have problems maintaining proper mixture due to rapid changes in air temp and air flow resistance.
The proper design would have had rubber boots to connect between the airbox and snorkel an clamped for better seal -- the design for this connection is pretty pathetic if you ask me.
I suspect I have minimal gap issues as I've had no performance issues like this, but I will investigate and see what gap I have. If I find a gap I'll likely use a rubbery tape so there's some compliance in case there is a flexing effect when the engine is revved.
Brian
2012 FF Ti HB Sonic Blue, Built 5/7/12, 401A + Parking Technology Package and MFT w/NAV 3.0.2 -> 3.2.2 -> 3.5.1 -> 3.6.2
raptor1956 is online now
Old 04-30-2014, 09:24 AM   #213
mr_cassandra
Fan#: 95399
What I Drive: Mazda-3 , formerly a focus SE
Points 338, Level 6
Points: 338, Level: 6 Points: 338, Level: 6 Points: 338, Level: 6
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 4%
FF Reputation: 2 mr_cassandra Good Standing Member
many people here have closed that gap and reported significant improvement, but the question everyone needs to confront is why is everyone but the factory trying to fix the new car they are paying their hard-earned money for?
mr_cassandra is offline
Old 04-30-2014, 09:32 AM   #214
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
In the heat of summer it makes a noticeable difference. In cooler or winter months, not so much. Dan's theory was the engine was sucking in hot air from the engine compartment and it was screwing up the mixture/timing. Sounds plausible as anything to me.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 04-30-2014, 09:33 AM   #215
wavsine
wavsine's Avatar
Fan#: 118470
What I Drive: 2013 Focus SE Oxford White Hatch 5m
Points 20,192, Level 89
Points: 20,192, Level: 89 Points: 20,192, Level: 89 Points: 20,192, Level: 89
Level Up 69% Completed
Forum Activity 10%
FF Reputation: 16 wavsine Great Standing Member
The problem is that we don't know what size gap you had before you taped it. If you already had a relatively tight seal, then I would not expect any change.
The tolerances on these cars vary greatly. Dan knows his stuff and the theory behind the improvement is sound. Owners with a significant gap are drawing in warm air from under the hood.
In addition, the torque as you launch off the line may cause the motor to move and the gap may widen as you first take off.
Use a Motorcraft FL-400S filter to increase filtration media and oil quantity. (Drop in for FL-910S)
Synthetic oil in GDI engines
www.focusfanatics.com/forum/showthread.php?t=324396
wavsine is online now
Old 04-30-2014, 09:29 PM   #216
larz27
Fan#: 131129
What I Drive: 2014 Char Gray Ford Focus SE HB DCT
Points 251, Level 5
Points: 251, Level: 5 Points: 251, Level: 5 Points: 251, Level: 5
Level Up 2% Completed
FF Reputation: 1 larz27 Good Standing Member
I just did this today on a 2014. Put some black duct tape over the gap, sealed it up with the plastic wrap and I definitely noticed less jerky acceleration at low speeds and take off. It didn't cut my 0-60 in half, but this certainly helped me with a smoother ride especially at low speeds. The car drives like it should now. Honestly, I'm impressed by this literal patch. Seriously, this needs to be the first thing that pops up when people visit the mk3 thread for the first time. I've been around here for months and I've never seen this mentioned before. Sticky this stuff guys, or put it in the DIY section.
larz27 is offline
Old 05-01-2014, 12:19 AM   #217
Logos
Fan#: 149698
What I Drive: 2013 Black Ford Focus Titanium
FF Reputation: 1 Logos Good Standing Member
My car always bogged down and was hesitant accelerating when coming to a stop after having exited the highway. I always wondered why it was only after driving on the highway!
Well, I checked my air inflow and my car has 4-5mm gap. Can't wait to tape it up and test it out! Thank you!
Logos is offline
Old 05-01-2014, 01:06 PM   #218
bama_focus
bama_focus's Avatar
Fan#: 117648
What I Drive: 2012 focus sedan sel
Points 264, Level 5
Points: 264, Level: 5 Points: 264, Level: 5 Points: 264, Level: 5
Level Up 28% Completed
FF Reputation: 2 bama_focus Good Standing Member
How's this for throttle response? Put your foot down sooner.
2012 Focus SEL sedan tuxedo black
2005 GMC Envoy XUV
bama_focus is offline
Old 05-01-2014, 03:46 PM   #219
slybarman
Fan#: 105425
Not so good.
Old 05-02-2014, 05:24 PM   #220
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Hatchback SE RR DCT "Fiona"
Points 5,986, Level 50
Points: 5,986, Level: 50 Points: 5,986, Level: 50 Points: 5,986, Level: 50
Level Up 18% Completed
Forum Activity 79%
Activity: 79% Activity: 79% Activity: 79%
FF Reputation: 2 Jburks Good Standing Member
So i decided to check and see if i had the gap on mine this morning. I have a 2014 SE. I pulled back the rubber flap and defintely had a noticable gap. I used some electrical tape to cover it up. I have only driven about ten miles since doing it so i havent seen a huge difference but will report back after i have put some more miles on it.
Green Filters drop in-Snorkel Delete-Steeda RSB-Fswerks RMM insert-Focus Power Tune.
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is online now
Tags
dct fix , powershift fix
