5 Minute throttle response/DCT solution? - Page 17 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 08-31-2013, 08:33 AM   #161
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Originally Posted by slybarman View Post
How much gap did yours have?
Sent from my Galaxy Note 2 using FF Mobile.
A small gap about like what every one else is saying , My point was that I took the rubber all the way off and had a hugh gap all the way around between the air box and snorkel and it make no difference
A big gap , no gap , small gap has no bearing on any sensor or reading the ECU sees to make a change in any fueling or timing
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-31-2013, 08:33 AM   #162
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
FF Reputation: 11 dan50 Great Standing Member
Originally Posted by 1turbofocus View Post
I took the rubber all the way off mine both before the dyno (35-40 miles) dynoed it on and off then drove it another 50-60 miles more with it all the way off , No change in performance on or off the dyno or driving with it on or off
Im not sure why some think this helps as there is nothing that this would change at all in the electronics or what the ECU sees , the intake air temps only changed by .5 to 2 deg with it all the way off ????????
But like Smokey says if it makes you feel better then do it
Not saying this is a cure-all or will help everyone. But:
1) I wouldn't expect this to make a differnce on the dyno. The theory is that, if a large gap is present, application of throttle after idling will draw in cooler outside air creating a lean condition for a couple seconds until the PCM adjusts.
2) By removing the rubber completely, you've created a good-sized spot in the radiator bulkhead for outside air to enter so the underhood environment isn't as closed as it otherwise would be.
Again, the issue is not hot intake air versus cold, it's the abrupt transition from one to the other.
To me, fixing this assembly problem (if it's present in an individual car) is no more than putting it in the condition in which it should have left the factory. It can do no harm and might be helpful. As I've expressed, it made a noticeable difference for me after driving the thing for 19,000 miles; certainly more helpful than most of the suggestions coming out of Dearborn.
dan50 is offline
Old 08-31-2013, 09:39 AM   #163
xwhit3devilx
xwhit3devilx's Avatar
Fan#: 86578
What I Drive: 2014 Hyundai Veloster Turbo
FF Reputation: 2 xwhit3devilx Good Standing Member
This seems to help things a little, but it still doesn't fix all the slipping of the DCT after sitting in stop and go traffic for half an hour. I'm still convinced that the problem is one of heat and that Ford should have made the DCT a wet-clutch design. (And not an accidental wet clutch due to gasket failure )
xwhit3devilx is offline
Old 09-02-2013, 09:36 PM   #164
gkirk
Fan#: 91903
What I Drive: 2012 C.Red Focus SE Sport Package
FF Reputation: 3 gkirk Good Standing Member
after driving mine on a road trip this weekend, I think it handles take offs better with the gap taped. It could still be placebo effect, but i haven't noticed as much hesitation or shudders at low speeds.
Could be observation bias, now on each success i attribute it to the mod. So who knows? Given that it takes 5 seconds to do, why not?
gkirk is offline
Old 09-02-2013, 10:41 PM   #165
FamousMassacre
Fan#: 104066
What I Drive: 2013 Performance Blue Hatch
FF Reputation: 1 FamousMassacre Good Standing Member
We could test it to the extreme.
Completely unhook it and drive for a bit and then seal it up.
FamousMassacre is offline
Old 09-03-2013, 01:12 PM   #166
PratoN
PratoN's Avatar
Fan#: 88058
FF Reputation: 10 PratoN Great Standing Member
I'm not saying that this fix does (or doesn't) work, I'm just putting my data point into the pool that I have a gap and even when I push the parts together, there is still a gap (albeit small) near the middle.
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.6 91k miles and counting...
PratoN is online now
Old 09-03-2013, 02:17 PM   #167
gkirk
Fan#: 91903
Are you going to tape it? I've been slowly following your saga, and I'm curious if it will matter at all.
gkirk is offline
Old 09-03-2013, 02:48 PM   #168
PratoN
PratoN's Avatar
Fan#: 88058
I appreciate the I dedication!
I will be taping it as a safety precaution, but I'm also getting my clutch replaced within a week. I think it's kind of moot to try to rush any experiments - especially if the warm weather and my stop-and-go driving don't really coincide.
Old 09-11-2013, 04:29 PM   #169
Arco-Zakus
Arco-Zakus's Avatar
Fan#: 101658
What I Drive: 2014 SGM SE Sport Pkg Sedan 5sp-man
FF Reputation: 10 Arco-Zakus Great Standing Member
More duct tape
Originally Posted by dan50 View Post
In the 19,000 miles I've had my 2012 DCT-equipped Focus I've complained about lousy throttle response (bogging, surging,etc.) and DCT behavior (lunging at launch, mostly). I've stumbled upon a solution that eliminates 80% of my issues. Best of all, it only puts the car into the condition in which it was supposed to leave the factory and it's easy.
... I sealed the gap with a little duct tape ...
To my surprise, my driveability issues largely went away. My car now behaves the way it should, with much better throttle response at launch and greatly diminished surging, bogging and lunging. ...
I always knew that the ultimate solution to some of the Mk3 Focus's "early production issues" would involve duct tape. Sometimes even just a little bit, when applied correctly, does wonders.
Originally Posted by novus View Post
... This is what everyone is talking about.
... (Stole some of my nieces duck tape since mine went missing...)
(Glad I didn't have any food in my mouth.)
Originally Posted by Kabigon View Post
Rather than repeating the WOT accel for an arbitrary number of times, it would be better to simply do it on a regular basis.
More fun, too.
Arco-Zakus is online now
Old 09-11-2013, 05:23 PM   #170
FX4life
FX4life's Avatar
Fan#: 99227
What I Drive: 2012 White Platinum Titanium
FF Reputation: 1 FX4life Good Standing Member
Alrighty, did this mod today. Don't have any real issues with the car yet except crappy throttle response, but this is just cheap insurance. Used whatever I could find within 10 feet of the car, which happened to be 3M double sided tape. Left the red backing on so as to not leave a mess. Decided to use something with some thickness to it, for better..insulation or something, or some other reason that I've been trying to think of for the past 10 minutes to make myself look like a smarty-pants.
Nope, I was just lazy. Don't think i have any duct tape around. I like these little free mods that may have some method to madness, I may try stuffing my Sony sub with polyfill like the F-150's yet.
I'll report on any changes to the drivability tomorrow. If this doesn't liven up the throttle response from Eco-freako tendencies, an SCT tuner will.
2012 White Platinum Titanium Hatchback - Loaded - 35% tint, Bridgestone Blizzak WS70 winter tires
2013 Oxford White F-150 FX4 5.0 Supercrew - Loaded - Tint-to-match, Wheel-well liners, 3M Protection, Spray-in bedliner
FX4life is offline
Tags
dct fix, powershift fix
