5 Minute throttle response/DCT solution? - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-20-2013, 10:05 PM   #141
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,487, Level 21
Points: 1,487, Level: 21 Points: 1,487, Level: 21 Points: 1,487, Level: 21
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 5 scott7278 Good Standing Member
Just did this easy mod today, although I did just get the car back from having a new clutch pack installed. There was indeed a gap, so it couldn't hurt...
Sent from my HTC One using FF Mobile 4.
scott7278 is online now
Old 08-20-2013, 10:22 PM   #142
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
More a repair than a mod in my estimation. Hope it helps.
Sent from my Galaxy Note 2 using FF Mobile.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 08-20-2013, 10:24 PM   #143
scott7278
Fan#: 100021
You are correct. Thank you!
Old 08-20-2013, 10:35 PM   #144
scott7278
Fan#: 100021
I think I may go back and caulk it, though, then put black duct tape back over it.
Old 08-23-2013, 02:49 PM   #145
WizardSkills
WizardSkills's Avatar
Fan#: 100116
What I Drive: 2012 White Platinum SEL 303A 5-door
Points 715, Level 14
Points: 715, Level: 14 Points: 715, Level: 14 Points: 715, Level: 14
Level Up 15% Completed
FF Reputation: 3 WizardSkills Good Standing Member
Just looked at my 2012 and under that rubber grommet, low and behold, there were significant gaps between both intake tubes. They also seem to move about rather easily. So I too ya'lls advice and used some black duct tape to seal them up right. I can't be sure but I think it helped. I'm about to drive down to LA from SF so I'll let you know if I see a difference. Good call gents!
Posted via FF Mobile
WizardSkills is offline
Old 08-25-2013, 08:53 PM   #146
Kamikaze2
Fan#: 107901
What I Drive: 2012 Titanium + Ingot Silver
FF Reputation: 1 Kamikaze2 Good Standing Member
I have checked the parts you guys mentioned. That is before the sensor so it should not have any impact. Can explain further how does it help ?
Kamikaze2 is offline
Old 08-25-2013, 09:21 PM   #147
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Take a look at the first post in this thread. Yes, it is before the sensor, but the theory at least is that at idle the car will ingest hot, engine compartment air via the gap in the intake tube.
The PCM will adjust the fuel mixture to this temperature. When acceleration is asked for, much cooler outside air will be present. The PCM can't adjust to the temperature change instantly, so a lean mixture results for a few seconds with consequent surging and driveability problems.
If you have a gap, try sealing it: it can't hurt and maybe you'll notice a difference.
dan50 is offline
Old 08-25-2013, 10:08 PM   #148
ScooterCT70
Fan#: 98691
What I Drive: 2012 Ingot Silver Titanium Focus
FF Reputation: 1 ScooterCT70 Good Standing Member
I still feel like taping the gap has worked for me. Makes taking off from a stop so much easier and less scary!
ScooterCT70 is offline
Old 08-28-2013, 01:58 PM   #149
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,022, Level 33
Points: 3,022, Level: 33 Points: 3,022, Level: 33 Points: 3,022, Level: 33
Level Up 82% Completed
Forum Activity 12%
FF Reputation: 15 PratoN Great Standing Member
I'm getting my car back for about a week while they order the clutch kit. I'll be sure to try this mod after the clutch is replaced - just in case.
EDIT: I'll check my gap beforehand, but I don't want the dealer to think anything fishy is going on with my tape on the car.
PratoN is offline
Old 08-29-2013, 12:03 PM   #150
gkirk
Fan#: 91903
What I Drive: 2012 C.Red Focus SE Sport Package
FF Reputation: 3 gkirk Good Standing Member
Also, there isn't any real seal between the parts, everyone will have some kind of gap. Mine looked small, but I could easily move the parts around to make a bigger or smaller gap. This might happen as the car is being bounced.
Thanks for this explanation, i had missed the part about how the PCM couldn't adjust fast enough. That makes possible improvements a lot more believable.
Also there was a post where someone measured the actual temps w/ a scan gauge and there was a difference.
edit: Also i just taped mine, it will be interesting to see if it makes any difference.
gkirk is offline
Tags
dct fix , powershift fix
