5 Minute throttle response/DCT solution? - Page 13 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 08-19-2013, 12:25 PM   #121
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2013 Tuxedo Black Focus SE Hatch
FF Reputation: 3 MetalMuffins Good Standing Member
Originally Posted by supernova1 View Post
I found the same gaps on the air intake tubes. I used some clear silicone adhesive to create a seal around the tubes
That's funny, I was going to do the same thing on my lunch today, until i realized i didn't have a socket to get the cover off
I am planning on doing this some time anyways, I'm sure it can't hurt anything.
Last thing, I wonder what the comparison would be now between a SRI / CIA vs a K&N drop in along with snorkel delete and having the factory box properly sealed on the intake runners / box....
2013 HB MTX, Tux Black w/ Black Pack - Steeda RSB, Snorkel DLT, K&N Drop in, E-Focus RMM, Redline Tuning Hood Struts, Custom Al. Skid-plate, Custom SCT Tune by Tom @ Focus-Power
MetalMuffins is offline
Old 08-20-2013, 05:25 AM   #122
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 Gray se, 2014 Blue Candy ti
FF Reputation: 1 Seminoles Good Standing Member
Originally Posted by kam327 View Post
On the other hand you've been clean out of punctuation for a while now....
Seminoles is online now
Old 08-20-2013, 05:27 AM   #123
Seminoles
Seminoles's Avatar
Fan#: 98405
I found the same gaps on the air intake tubes. I used some clear silicone adhesive to create a seal around the tubes (I had to remove the rubber gasket and clean it up prior to the adhesive application).
Result - a bit smoother take off (hard to say anything definite). On the other hand, I drive about 20 miles on the back roads with 20-40 MPH, and the car MPG has increased by about 2 MPG after the modification (to > 35MPG). I did not notice sizable increase while driving on the highway - it is still about 35MPG.
It looks to me that the car engine is sensitive to the incoming air temperature - I will check the filter box for any noticeable gaps.
I am glad that somebody reported this find to the Ford rep - it seems to me like a such simple fix for improving the car economy and drive-ability.
Only one problem, If you or someone has to remove the filter box it will have to be cut off he rubber seal.
Old 08-20-2013, 05:31 AM   #124
Seminoles
Seminoles's Avatar
Fan#: 98405
Not the lid!!! How would you change/clean the filter later on. Just the tubes under the rubber band.
Read the sticky thread on snorkel delete will explain it.
http://www.focusfanatics.com/forum/showthread.php?t=297795
Old 08-20-2013, 06:14 AM   #125
MetalMuffins
Fan#: 107135
I know that, already done on my car. By sealed box, i meant simply sealing at the end of the tubes into the rad support and sealing where the tubes go into the box. I agree that sealing the top and bottom of the box would be idiotic at best
Old 08-20-2013, 06:18 AM   #126
Seminoles
Seminoles's Avatar
Fan#: 98405
My bad when you said you didn't have a socket thought you were going to do the lid, forgot about the tube on the bottom.
Old 08-20-2013, 07:14 AM   #127
MetalMuffins
Fan#: 107135
It's all good. I did this last night and actually sealed both tubes from the inside of the box, and also pulled the tape off of the intake runner and sealed that with silicone as well.
I only had my drive to work with it this morning, so it's to soon to say if there is any change.
Old 08-20-2013, 07:26 AM   #128
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
FF Reputation: 3 slybarman Good Standing Member
I ended up using mortite rope caulk to seal mine. Goes on easily and can be removed if necessary.
Sent from my Galaxy Note 2 using FF Mobile.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is online now
Old 08-20-2013, 10:48 AM   #129
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
FF Reputation: 11 kam327 Great Standing Member
I duct taped my 1mm gap last Thursday night. Still had uneven acceleration on Friday.
Then I did the 5 full throttle accelerations over the weekend. Accelerations have been much smoother this week. I still swear by that tactic.
kam327 is online now
Old 08-20-2013, 11:10 AM   #130
mr_cassandra
Fan#: 95399
What I Drive: Mazda-3 , formerly a focus SE
FF Reputation: 2 mr_cassandra Good Standing Member
I had seen that posted and tried it as well. Though I don't think its a good long term practice, its my opinion that it burns some glaze off the clutches.
mr_cassandra is online now
Tags
dct fix, powershift fix
