5 Minute throttle response/DCT solution? - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-16-2013, 07:57 AM   #111
mr_cassandra
Fan#: 95399
What I Drive: Mazda-3 , formerly a focus SE
Points 331, Level 6
Points: 331, Level: 6 Points: 331, Level: 6 Points: 331, Level: 6
Level Up 62% Completed
Forum Activity 3%
FF Reputation: 2 mr_cassandra Good Standing Member
Originally Posted by Sparky12 View Post
Well, no such luck for me. I had the same lurching and shuddering. I'm thinking the clutch(es) is the source of my problem. My car's behavior is almost exactly like the descriptions in that thread.
Back to the dealer for the THIRD time...
Sparky, if the dealer is no help, many owners here have gotten great results when they reached out to Crystal, the ford CS rep, here at this board. She gets their cases escalated and I've seen a lot of good outcomes posted here.
mr_cassandra is offline
Old 08-16-2013, 09:47 AM   #112
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Originally Posted by Seminoles View Post
I don't have that much of a gap but will try it anyway if anything just to make Ford's life more difficult if they have to remove it, I can hear them no you just voided your warranty.... LOL
That looks really good - just like Ford intended. Some have gaps of 4-5mm on one side or another.
dan50 is offline
Old 08-16-2013, 06:16 PM   #113
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Just looked at the 2012 lots of gap on both tubes good thing I have a full roll of black duct tape...
Seminoles is offline
Old 08-18-2013, 02:47 PM   #114
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
Did my first full tank fill-up post-fix. I got 31.81 mi/gal. My average since owning the car is 30.89. I would say this is within the margin-of-error. It may or may not have helped a bit, but certainly did not hurt.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 08-18-2013, 03:02 PM   #115
mr_cassandra
Fan#: 95399
Points 331, Level 6
Forum Activity 3%
Originally Posted by 84Camaro_L69 View Post
If this works across the board then I hope Ford is monitoring this and comes out with a TSB.
It has been reported to Crystal, the ford CS rep on this board, and she has passed it up the chain of command.
Old 08-19-2013, 08:07 AM   #116
kam327
-----<M>-----
kam327's Avatar
Fan#: 94700
What I Drive: '14 Ruby Ti w/ Handling Pkg
Points 7,279, Level 56
Points: 7,279, Level: 56 Points: 7,279, Level: 56 Points: 7,279, Level: 56
Level Up 65% Completed
Forum Activity 13%
FF Reputation: 13 kam327 Great Standing Member
On the other hand you've been clean out of punctuation for a while now....
kam327 is offline
Old 08-19-2013, 10:50 AM   #117
slybarman
Fan#: 105425
I discussed this with the service manager at my dealer this morning. He seemed pretty intrigued. Meanwhile they are diagnosing my transmission.
Sent from my Galaxy Note 2 using FF Mobile.
Old 08-19-2013, 11:06 AM   #118
mr_cassandra
Fan#: 95399
Points 331, Level 6
Forum Activity 3%
quote from slybarman-I discussed this with my dealer, he seemed pretty intrigued
I would think so. It doesn't always have to be a complicated high tech issue.
Cold air intakes are used the world over and the gap desricbed by dans posts and pictures, would be allowing hot air in from the engine compartment.
Last edited by mr_cassandra; 08-19-2013 at 11:09 AM. Reason: added slybarman quote
Old 08-19-2013, 11:35 AM   #119
Emmortal
Fan#: 92957
What I Drive: 2012 Sterling Grey Focus Titanium
Points 21, Level 1
Points: 21, Level: 1 Points: 21, Level: 1 Points: 21, Level: 1
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 1 Emmortal Good Standing Member
Subscribed.
Car is currently in getting the transmission/clutch looked at (and hopefully repaired) but will definitely be trying this once I get it back.
Emmortal is offline
Old 08-19-2013, 01:09 PM   #120
supernova1
Fan#: 107060
What I Drive: 2012 Ford Focus SEL HB Red Candy
Points 28, Level 1
Points: 28, Level: 1 Points: 28, Level: 1 Points: 28, Level: 1
Level Up 56% Completed
FF Reputation: 1 supernova1 Good Standing Member
I found the same gaps on the air intake tubes. I used some clear silicone adhesive to create a seal around the tubes (I had to remove the rubber gasket and clean it up prior to the adhesive application).
Result - a bit smoother take off (hard to say anything definite). On the other hand, I drive about 20 miles on the back roads with 20-40 MPH, and the car MPG has increased by about 2 MPG after the modification (to > 35MPG). I did not notice sizable increase while driving on the highway - it is still about 35MPG.
It looks to me that the car engine is sensitive to the incoming air temperature - I will check the filter box for any noticeable gaps.
I am glad that somebody reported this find to the Ford rep - it seems to me like a such simple fix for improving the car economy and drive-ability.
supernova1 is offline
Tags
dct fix , powershift fix
