5 Minute throttle response/DCT solution? - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-15-2013, 10:36 AM   #101
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 933, Level 16
Points: 933, Level: 16 Points: 933, Level: 16 Points: 933, Level: 16
Level Up 33% Completed
Forum Activity 2%
FF Reputation: 5 novus Good Standing Member
Originally Posted by bsp_53 View Post
I'm loving those penguins ... I'm such a coward for not using my daughter's moustache duct tape!!
It was that or duck tape with lips etc on it.
Plus I'm sure the penguins added 10HP
Originally Posted by gkirk View Post
I'm pretty sure the technical term for that tape is Penguin Tape.
Also, thanks for the pics :)
You're welcome. And you're correct, penguin tape.
Originally Posted by redzone View Post
is the bottom side sealed? or should we try and wrap all the way around.
Originally Posted by dan50 View Post
You can probably see in the photos that the bottom half is supported by a pretty wide rubber part. I expect this seals pretty well when the strap is secured so taking care of the top may be enough, at least for starters.
As dan50 stated, the bottom seems fine, it's only the left tube. There is a tiny gap on the right tube, but the rubber looks as if it holds it fine as it's tighter there.
Originally Posted by slybarman View Post
I figured I might as well wrap the whole thing. All you stand to loose is $.10 worth of tape. Can't hurt anything.
Sent from my Galaxy Note 2 using FF Mobile.
Ran out of Penguin Tape or I would have. My niece decided to use up all the tape for little duck tape projects...
novus is offline
Old 08-15-2013, 11:26 AM   #102
OhFFS
OhFFS's Avatar
Fan#: 114209
What I Drive: 2013 Ingot Silver Focus SE
FF Reputation: 1 OhFFS Good Standing Member
I'm going to do this.
Does anyone know where you can buy duct tape that looks like Band-Aid material?
OhFFS is offline
Old 08-15-2013, 12:05 PM   #103
bsp_53
bsp_53's Avatar
Fan#: 87580
What I Drive: 2012 FF Titanium HB, Yellow Blaze
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Level Up 38% Completed
FF Reputation: 1 bsp_53 Good Standing Member
As many prints as there are for duct tape, this is the closest I've seen ...
http://www.shoplet.com/3m-Duct-Tape-.../MMM52020/spdv
Gold Nugget: '12, 400A, Wintr Pckg, Yellow Blaze HB
Mods: Llumar Tint:35 / 20; K&N fltr + Snrkl Del.; Splashgrds; Grill Pinstripes
Hatch Nation #174
bsp_53 is offline
Old 08-15-2013, 04:47 PM   #104
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,077, Level 34
Points: 3,077, Level: 34 Points: 3,077, Level: 34 Points: 3,077, Level: 34
Level Up 18% Completed
Forum Activity 3%
FF Reputation: 12 dan50 Great Standing Member
Originally Posted by mr_cassandra View Post
Dan, I think you should pm this to Crystal and also "eric at ford" over at the ford focus facebook page. I think you may have hit on something
Crytstal has made her supervisor aware of this thread and will watch it to see if it gains traction. I suppose that means there's a microscopically small chance it could get to someone in Ford engineering if it looks like it helps others. So if you've tried this and it does (or does not) help, please respond in this thread. I suspect Ford needs more than a handful of supporters to take the suggestion seriously.
Thanks!
dan50 is offline
Old 08-15-2013, 04:51 PM   #105
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
LOL - heaven forbid ford engineers waste 5 minutes and a foot of duct tape.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 08-15-2013, 04:56 PM   #106
MetalMuffins
MetalMuffins's Avatar
Fan#: 107135
What I Drive: 2013 Tuxedo Black Focus SE Hatch
Points 547, Level 10
Points: 547, Level: 10 Points: 547, Level: 10 Points: 547, Level: 10
Level Up 94% Completed
FF Reputation: 3 MetalMuffins Good Standing Member
I did this at lunch today to take care of my very small gap, which was probably 1mm on one site to 3mm on the other. I will see if it does anything, although I doubt such a tight clearance to begin with will show much of a change.
Like everyone has been saying though, it's not going to hurt anything, so might as well do it.
Also, on a side note, I will check a friends 2012 sedan and see what theirs looks like gap wise, as well as do some taping
2013 HB MTX, Tux Black w/ Black Pack - Steeda RSB, Snorkel DLT, K&N Drop in, E-Focus RMM, Redline Tuning Hood Struts, Custom Al. Skid-plate, 180 Stat, Custom SCT Tune by Tom @ Focus-Power
MetalMuffins is online now
Old 08-15-2013, 09:14 PM   #107
Sparky12
Fan#: 98232
What I Drive: 2012 Ingot Silver Focus Ti HB
FF Reputation: 2 Sparky12 Good Standing Member
Originally Posted by Sparky12 View Post
I'm willing to give anything a try to fix my shuddering while accelerating from a stop during warm/hot conditions....
<<SNIP>>
I'll drive it for 3 more days back and forth to work (19 miles each way) and report back.
Well, no such luck for me. I had the same lurching and shuddering. I'm thinking the clutch(es) is the source of my problem. My car's behavior is almost exactly like the descriptions in that thread.
Back to the dealer for the THIRD time...
Sparky12 is offline
Old 08-15-2013, 10:29 PM   #108
MetalMuffins
Fan#: 107135
Well, just an update with some data. I have been doing some logging after adding the tape, and it looks as if this has some merit. I will say two things first; I have a K&N drop in filter in my car, and have done the snorkel delete. I also fabbed up a "ram air" through the grill with a piece of plastic. Second, my "before log" is from a month ago, but I am only comparing the difference from ambient temperature, so this shouldn't make a difference.
I checked my previous log, and ambient temp was 26C, intake temp was 30C. This is after approx. 15 min's of "light city" driving, cursing at about 100Kph / 60Mph.
Today, after doing this mod, I recorded an ambient temp of 24C and an intake of 24-25C, under the same driving conditions.
So, some semi-scientific data on this mod / fix. As for SOTP feel about the whole thing, I can't notice too much of a difference, but I think there is some, if only a slight improvement. Also, my car is a 5 speed, so the DTC might exemplify the good and bad of the before / after more than mine does. Anyone else who is planning on doing this should try to do a before / after log to compare.
Old 08-15-2013, 10:48 PM   #109
Sholando
Fan#: 117246
What I Drive: 2013 Focus TI HB 2003 Mustang Cobra
Points 9, Level 1
Points: 9, Level: 1 Points: 9, Level: 1 Points: 9, Level: 1
Level Up 17% Completed
FF Reputation: 1 Sholando Good Standing Member
Subscribing.
Sholando is offline
Old 08-16-2013, 07:32 AM   #110
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
I don't have that much of a gap but will try it anyway if anything just to make Ford's life more difficult if they have to remove it, I can hear them no you just voided your warranty.... LOL
Seminoles is offline
Tags
dct fix , powershift fix
