Auto X Setup - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 12-13-2004, 02:53 PM   #1
Templar
Templar's Avatar
Fan#: 795
What I Drive: Pitch black '03 Ford Focus ZX3
Points 3,912, Level 39
Points: 3,912, Level: 39 Points: 3,912, Level: 39 Points: 3,912, Level: 39
Level Up 75% Completed
FF Reputation: 4 Templar Good Standing Member
Buy-Sell-Trade Rating: (6)
Auto X Setup
I know a few people on here auto cross...
Would you mind sharing your set up? I am going to start going to the local crosses here and wanted to get some experianced input on some things. I ahve read all the rule books and the start up guides. I am just interested in basic setup tips and tricks...
"Logic is a way of saying that anything which didn't happen yesterday won't happen tomorrow"
- Robert Heinlein
Glory Road
"The question is, do you possess the constitution, the depth of faith, to go as far as is needed?"
- Boondock Saints
Templar is offline
Old 12-13-2004, 09:46 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
I currently run H&R Sport Springs, Koni Adjustables, Progress rear sway bar, some polyurathane bushings, and some Hankook R-compounds (Used to be Azenis).
Its a nice setup, but I could go for a stiffer spring.
Now comes the quesion on how much do you want to spend to be competative. Konis or Spax adjustibles are an excellent damper for autocross, but cost more than something like Eibachs. The beauty is you can dial in how much rotation you need, without having something crazy for the street.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 12-14-2004, 11:02 AM   #3
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
What class do you want to be in? I am getting adjustable Konis before next season, and some Azenis, but cannot do much else unless I leave G Stock (which I don't want to do yet). I would suggest a good performance alignment (as much camber as you can get and some toe-out in the rear to get more rotation). If you have, or will have, coil-overs I would suggest the alignment and getting corner-weighted. Then take it out to a wide open space and play with it, and see what settings suit your style the most.
I would personally love to get my rear end looser. I have a hard time getting it to rotate and therefore am struggling with understeer throughout the course. But i am not sure what more to do and stay in G stock...
Carrera26 is offline
Old 12-14-2004, 09:05 PM   #4
Templar
Templar's Avatar
Fan#: 795
I plan on running STS. I added some eibach sportlines before I got interested in Auto X so now I am saving for the Koni adjustables... I was wondering about camber angles and tire presures... Does anyone adjust their own alignment...?
- Robert Heinlein
Glory Road
- Boondock Saints
Templar is offline
Old 12-15-2004, 05:15 PM   #5
Carrera26
Carrera26's Avatar
Fan#: 12237
Not without some equipment. Get it aligned, and then go out and do a few races without really dialing it in. 95% of your improvement is going to have to come from your own driving, and you are just going to be shooting in the dark if you try to do this before you actually race. After you go a few times, you will get a real idea of what you WANT to change, and how MUCH you want it to change. Resist the urge to [:)][:)][:)][:)][:)][:)]** with it for a while, and you will end up much better.
Old 12-15-2004, 07:09 PM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^^Good Suggestions^^^^
Get it aligned, and run what ya got.
Once you get a few events under your belt, and a really good feel for the car,
then you can decide whether you want to "mod" the suspension any further or not.
Biggest thing to start off with is tire pressures.
I ran GS all year, and this is what I found that works for me.
These are "cold temps", before a run.
Short course, like a parking lot, with a lot of tight turns:
49front/31rear
Long course, like at an airport with higher speeds:
47front/32rear
Just have fun, and don't push it too hard.
If you're getting tire squeeling like mad, and pushing in the turns.....SLOW DOWN!
WD40 is offline
Old 12-15-2004, 11:53 PM   #7
liquid01
Fan#: 252
What I Drive: ZX3 S2 modded--Just a touch
Points 2,759, Level 32
Points: 2,759, Level: 32 Points: 2,759, Level: 32 Points: 2,759, Level: 32
Level Up 6% Completed
FF Reputation: 3 liquid01 Good Standing Member
Tire pressuers are going to change with the style of tire you have on the car...With a standard sportlines andfalkens I was up in the 50`s front--Then into total eibach suspension with hoosiers into the mid40-45`s front. The back I always ran about 5-10 pounds less. As stated before depending on the size of the course.
For Sale (sleeper)
liquid01 is online now
Old 12-16-2004, 12:04 PM   #8
Templar
Templar's Avatar
Fan#: 795
good stuff, good stuff...
- Robert Heinlein
Glory Road
- Boondock Saints
Templar is offline
Old 12-16-2004, 12:07 PM   #9
Carrera26
Carrera26's Avatar
Fan#: 12237
It's also going to change with the surface. Some of the courses we run on are fairly slick, and/or rough. This is going to call for a different tire pressure than when we are at the high grip events. Track temp makes a difference too. I'd say to start, use the shoe polish trick on your tires to see what you need to do.
If anyone does not know, you put 3 shoe polish dots on your tires, trying to get the center to be right at the edge of the shoulder. There will be a little arrow pointing towards the tread on the shoulder, and the tip of the arrow is where you should center it.
Old 12-16-2004, 03:39 PM   #10
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
The shoe polish / talk technique is a way to measure tire roll. You put it on the near the edge, make a run, and see how much of the polish gets rubbed off. It should just take off the outer edge, on the tread-portion of the tire. Too much rubbed off means you are really rolling the tire over; Bad for the tire, and handling. Add more air. If none was rubbed off, you aren't deflecting at all; not bad, but you have some room to let some air out.
Try doing a search on the internet for a better explaination. I suck at explaining it.
Egz is offline
