Where can I buy a ITB? - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-18-2013, 07:16 PM   #51
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 344, Level 6
Points: 344, Level: 6 Points: 344, Level: 6 Points: 344, Level: 6
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 6%
FF Reputation: 1 GhostTribute Good Standing Member
Originally Posted by iminhell View Post
Originally Posted by 1turbofocus View Post
LOL LOL
Care to share what you find so funny?
GhostTribute is online now
Old 08-18-2013, 07:44 PM   #52
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,930, Level 100
Points: 51,930, Level: 100 Points: 51,930, Level: 100 Points: 51,930, Level: 100
Level Up 0% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
Sure face in palm post by iminhell
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-18-2013, 07:54 PM   #53
GhostTribute
Fan#: 107929
Points 344, Level 6
Forum Activity 6%
Oh.....IC Great feed back, thanks!
So anyone else have any input?
Old 08-19-2013, 12:00 AM   #54
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,689, Level 86
Points: 18,689, Level: 86 Points: 18,689, Level: 86 Points: 18,689, Level: 86
Level Up 68% Completed
Forum Activity 18%
Buy-Sell-Trade Rating: (4)
Originally Posted by GhostTribute View Post
Here are a couple shoots of the live data on my scan tool.... No CEL... however it will come on for the DPFE and EGR as they have both been removed. For those who say that the stock ECU will not idle over 700-850RPM... here it is @ 1200 RPM. The IAC is hooked up and running. In case anyone is wondering, the IAC valve is pretty much completely closed at idle @ these RPMs.
I don't believe anyone ever said the stock ECU won't idle over 700-850rpm. In fact I know no one ever has.
Personally I idle at ~900rpm because I have to, vacuum fluctuates too much if I go lower.
To add to that, the IAC can control up to near 3,000rpm idle if desired.
Speaking of, if the IAC is not open at idle, your throttle stop is set wrong or you have a vacuum leak.
As you can see it is running a bit on the warm side and the ECU is really attacking the fuel trims....
19.2% throttle and a really good IAT and flow reading from the MAF. It's quite obvious that the 4 throttles suck air much faster than a single throttle body. The 65mm throttle body @ 1000RPM was reading @ 2.8 g/s.
At what load/ignition timing?
To say that they suck more is a conundrum.
If they actually did, you'd see it reflected by load and spark. Calculated load is based off both and to increase one will reflect on the other.
Simply reading air flow #'s will get you nowhere and without inclusive data is meaningless. It also does not reflect any aspect of air moving faster.
I will also try and see what I can do to keep the ECU from trimming so much fuel on the ST & LTFT.
Maybe reading the MAFS might help that?
iminhell is offline
Old 08-19-2013, 12:43 AM   #55
GhostTribute
Fan#: 107929
Points 344, Level 6
Forum Activity 6%
I was told that without tuning software you couldn't get the engine to idle above 850 unless you have a vacuum leak or the engine wasn't running properly. And You hit the nail on the head. about being set wrong.... except it's not my throttle stop. That is adjusted perfectly. It's my idle air adjustment (throttle sync) that is off. I still have to sync these throttles.
This is the first time they have ever run since I built them. This initial installation and run was to see if they would even run on a stock ECU. and to make sure that everything fit and functioned smoothly. I was actually surprised that it even started to be honest with you.
Yeah I noticed that the load is also higher at the same RPM as well. I was shocked that the ignition is still 0 though??? I was just speaking generally when I said they sucked more.
That being said. This set up is a fully tapered tuned induction system vs the stock straight diameter pipe and cone filter I had on it previously. It should be helping velocity in this manner.
- 3" velocity stack
- 3" pipe into 2.25" pipe
- Into the resonant air box (tuned for 3500-7500 rpm operation)
- inside the box there are 60mm velocity stacks on each throttle
- The throttles then taper from 50mm down to 46mm @ the throttle plates carried into the stock head and intake valves.
I am in the process of making an EEC-V plug and play harness connector for my MegaSquirtIII.
Once I get that up and running I will definitely take a look at those MAFS. Thank you for the input, much better than a face palm! ...
Old 02-16-2014, 05:17 AM   #56
photn02
Fan#: 116617
What I Drive: Silver
Points 535, Level 10
Points: 535, Level: 10 Points: 535, Level: 10 Points: 535, Level: 10
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 1 photn02 Good Standing Member
Sorry for thread revival here,
But im a bit confused and was hoping Tom could answer the question.
If i put ITB's on my Zetec engined Focus 2.0 could the standard ECU be used to tune it?
taking into account any other mods such as PNP head, Cams, higher CR?
photn02 is offline
Old 02-16-2014, 10:41 AM   #57
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
If you have an intake over the ITB and ran that through a mass air then yes you could use the stock ECU
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-16-2014, 03:09 PM   #58
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 18%
There is that guy from South America (Argentina IIRC) and his car is newer and MAP based. It's odd for most newer Fords to be that way in the USA.
But if you would swap to that style ECU then you wouldn't need a plenum around the ITB's. But I'm not sure if Tom can tune it for you. Offer help maybe.
I see the guy pop in from time to time on the tuning site I'm on. I can ask him to stop in here if you want.
iminhell is offline
Old 02-16-2014, 08:02 PM   #59
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 34%
Yes I can tune that ECU code for MAP based Foci I have done a good bit of them
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-18-2014, 05:30 PM   #60
photn02
Fan#: 116617
Forum Activity 2%
So there is no way to change the 2003 ECU to MAP instead of MAF?
photn02 is offline
